01-17-2020, 06:44 AM | #45 |
Rep 176
I kept trying to calculate e50, but I was finding the inconsistencies in gasoline was making this a complete crap shoot, when blending E85 and 93.
Frustrated, I decided to instal the fuel it! Bluetooth analyser.....it works great and has taken the guess work out of it. Now I'm really intrigued about the possible MHD flex fuel option coming. |
ZM22827.50 |
01-17-2020, 01:05 PM | #46 | |
Rep 278
For the interim, we're planning to do the very same thing (bluetooth 'e' analyzer) . Our hope is that when the MHD FF module is released, it will properly integrate (e.g. direct or supplemental harness) with the existing in-line ethanol analyzer.
Since we have the electronic steering wheel (outside my/our knowledge level here), we're not sure if it will interfere with the MHD FF module due to CAN bus. We've seen this with other products (incompatibility) so fingers crossed. Quote:
Raymondo123467.50 |
01-17-2020, 03:56 PM | #47 | |
Rep 7,470
Raymondo123467.50 |
01-17-2020, 03:58 PM | #48 | |
Rep 7,470
Raymondo123467.50 |
01-17-2020, 08:43 PM | #49 | ||
Rep 176
01-17-2020, 09:44 PM | #50 | ||
Rep 176
01-18-2020, 10:05 AM | #51 |
Rep 278
01-18-2020, 10:33 AM | #52 |
Rep 278
I've done some limited searching (N54) and I don't see any mention of CAN bus issues when pairing the electronic wheel with the MHD FF module. I'll keep looking though.
If there is a conflict, well .. The wheel goes. We need a solid fuel system for the turbo upgrade and since we have an abundance of e85 in the area, it's a no brainer. Question is, will MHD provide us with a means to identify the ethanol content (regardless of adaptability) via their app (or iDrive) since we'd be forgoing the BT analyzer OR is this merely a moot point. |
01-18-2020, 12:30 PM | #53 | |
Rep 7,470
01-19-2020, 03:39 AM | #54 |
Rep 7,470
Update:
Dorch engineering's HPFP for the n55 will be released on Feb.4 as per their website, pricing is also available and it is significantly cheaper than the rest of the competition. Their stage 2 HPFP is cheaper than XDI's stage 1....
detroitm22431.50 |
01-19-2020, 07:45 AM | #55 | |
Rep 2,526
01-19-2020, 08:46 AM | #56 |
Rep 3,703
Hmm...do you think Dorch Stage 1 is enough for a PS2 and E50 in the winter time?
01-19-2020, 01:35 PM | #57 |
Rep 7,470
That's a pretty hard question to predict, but it really depends on how much power you plan to have and afr you plan to target, altitude, mods, conditions etc. If you want to Max out ps2 then you might be pushing the hpfp to it's edge and it may not be sufficient. If you plan for maybe 450 whp (again hard prediction) you probably will be able to meet that goal on E50. Again this is mostly trial and error. You can probably compare this hpfp to the xdi-35 and look at what those guys are able to achieve on E50.
ZM22827.50 |
01-19-2020, 01:43 PM | #58 |
Rep 278
I'm noticing that these vendors are bundling either nylon reinforced/braided or SS/PTFE braided lines. Might be worth discussing pros/cons. We have a question out to Spool whether or not their lines (SS/PTFE) are conductive or non-conductive. We also asked them to confirm that the ethanol sensor is Continental. Will update once we receive an answer (they generally respond within 24 hours).
01-19-2020, 02:26 PM | #59 | |
Rep 7,470
I personally like the SS lines with the PTFE interior, but prefer the viton stuff that improved racing sells (cloth exterior). The pros of the stainless lines are virtually zero degradation over time, the con is they're quite rigid. The pros of nylon is that it is more flexible, but the cons is that it is slightly less durable. Conductivity of the lines shouldn't matter since they're ptfe cored. I can confirm since I asked them this along time ago, they use the smaller version of the genuine continental/GM sensor. Like this: https://www.summitracing.com/parts/n...7429/overview/ random question: why do you refer to yourself as "we", are you speaking as part of a shop or race team? Just curious.
///Monika186.50 |
01-19-2020, 02:35 PM | #60 | |
Rep 278
My husband and I. He does all the difficult work on our cars, I do all the research. It just works (house and vehicle projects).
koastal375.50 |
01-19-2020, 03:15 PM | #61 |
Rep 7,470
I see, that makes sense now.
01-19-2020, 08:23 PM | #62 | |
Rep 2,658
Log on 1-9 - http://www.bootmod3.net/log?id=5e17279dc090c6601b7d1f19 Log on 1-16 after some tune adjustments - http://www.bootmod3.net/log?id=5e17279dc090c6601b7d1f19 Was told to check my EKP module as well for faults. At some point I have to pick up a new HPFP but am unsure which route to go at this point.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
01-19-2020, 09:09 PM | #63 | |
Rep 7,470
01-20-2020, 05:05 AM | #64 | ||
Rep 2,658
01-20-2020, 08:40 AM | #65 | |
Rep 282
to clarify certain thougths , ive ranboth hdp5evo and hdp6 ( installed ) . so i have a little xp with them . a few pros and cons HDP5evo pros : same height for in and output compared to oem . better orientation of the connector . cons : is only marginally better compared to oem , doenst support ps2 and Emix . base plate is thinner , but thats not a con actually . Hdp6 : Pros much more flow available , ps2 and emix ,no problem . thicker baseplate twice of the hdp5evo cons ; orientation of the connector , needs some work to have clearance with intake manifold . The in and output sit a feww mm higher compared to oem . you will need to adjust the HP line to have it fitted without stress . Both pumps dont require extra programming because bosch hardware . both fired right up after install all in all go for the hdp6 right away , a little more work but much more worth it
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
01-20-2020, 10:00 AM | #66 | |
Rep 3,703
The other pumps have drop in fits without modification and the baseplate mod for the HDP6 is my biggest concern. I need everything to be very robust for the track, and I would be constantly concerned/checking the HDP6 fitment. Right now I’m leaning towards Dorch Stage 2 to bc they’re supported in BM3 (B58 so far, N55 coming they say), and it’ll give me plenty of headroom to run E50 with a PS2 in winter and occasionally full E85 at the track. |
