05-06-2021, 07:11 PM | #24 | |
Rep 259
05-06-2021, 08:09 PM | #25 | ||
16570
Rep 8,427
Of course BMW only intended for it to handle stock boost levels
05-06-2021, 09:15 PM | #27 |
Rep 875
Drives: ///M2
70k miles is insane! I'm at 45k
4
05-07-2021, 04:41 AM | #28 | ||
Luxury at the redline :)
9105
Rep 7,563
Let me take a wild guess, you're one of those zealous aftermarket metal chargepipe advocates I occasionally encounter here. Here's a reality-check; everything under the hood of an automobile will eventually wear out and fail, you can set your watch to that; it's not a matter of how but when. Some parts give up faster than others, such as plastic or rubber components #Duh.. It's not a surprise nor a mystery but the nature of a tangible product. Hell, even the pyramids didn't last forever.. Even If I get 50k miles of useful life out of the OEM charge pipe, I'm ok with that, over the alternative of stuffing some aftermarket, heak-soaked metal pipe into my vehicle. My revised chargepipe with the enhanced lip is holding up fine, going on two years and counting. If it fails again, I have an extended warranty, so the dealer will replace it, with no cost to me, while I go do burnouts in their brand new, free loaner car. https://www.bimmerpost.com/forums/sh...php?p=26491684 This N55 chargepipe failure is overblown issue on these forums, shit fails, replace it and move on - then end. I drove my car for seven days, even went on a date and did my regular errands, even after my chargepipe ripped off from the flange, yet my car is still fine to this day. It really wasn't the end of the world that the chargepipe fear-mongers have made it out to be but more so a minor inconvenience that comes with any general vehicle usage. |
05-07-2021, 07:16 AM | #29 | |
Rep 289
Heatsoak is a non-issue BTW, so be careful with fear-mongering in the other direction. |
05-07-2021, 12:50 PM | #30 | |||
16570
Rep 8,427
Absolutely nothing is worse then "Fear Based Sales Tactics"
05-07-2021, 01:13 PM | #31 |
6637
Rep 4,145
Drives: '18 M2 6MT
We haven't seen forever...yet. I suspect they will finally burn when our dwarf sun goes red giant in 5B years. Of course, had they been made from Roman concrete they would have lasted longer still, if only for a few moments.
Roman concrete FTW. |
05-07-2021, 01:29 PM | #32 | |
9105
Rep 7,563
So will every other plastic and rubber consumable components underneath the hood.. I'm already dealing with a bunch of coolant hoses and possible the belt wearing out and gradually failing one by one. https://www.bimmerpost.com/forums/sh...php?p=27192761 https://www.bimmerpost.com/forums/sh...php?p=27149518 It's a machine that withstands brunt loads, at various temperature, all throughout the year. Stuff is going to wear out and eventually fail over time, that's just the nature of the beast. As long as I have some sort of third-party warranty for someone else to cover the bill or the technical know-how to replace it myself, I'm not going lose a minute of sleep over this.. |
sevenmarc71.50 |
05-07-2021, 01:47 PM | #33 | |
6637
Rep 4,145
Drives: '18 M2 6MT
I don't have an issue with the first, second, or metal charge pipes, as none of them make any appreciable difference to anything. While it's on BMW's dime I'll leave the stock one, but will be getting the ER with their IC once the warranty is out. |
05-07-2021, 02:00 PM | #34 | ||
9105
Rep 7,563
My defenses is always up when discussing touchy subjects as these, where everyone alway assumes that their opinion is bond and some will even attempt to subliminally attack you, simple because your train of thought doesn't align with their views. I will say that I totally understand why folks swap out the plastic charge duct for a metal pipe but the OEM unit, with its perfect fit and finish, covered under warranty, works just fine for a lot of us also, so either/or is kosher. That's all I was attempting to convey.. |
sevenmarc71.50 VisualEcho6636.50 |
05-07-2021, 02:04 PM | #35 |
Rep 906
I'm not bothered by this much either...
But I also recognize that a plastic charge pipe is a simple cost cutting move at the expense of reliability. Given that many N55 engines are located in climates with a lot of hot/cold weather cycles, in addition to the constant stress and pressure put on the charge pipe during driving, it's a little disappointing that BMW would opt for a material whose structural integrity would have a risk of failure before the car reaches 75k miles. But it's a couple hundred dollars to perform preventative maintenance on this one, and once out of warranty I'll be doing so. Happy driving!
2009 328i xDrive 6MT (Retired and I miss her)
2015 335i xDrive 6MT (Retired and I dont miss her) 2018 M2 6MT (Never retiring) |
Poochie9104.50 |
05-07-2021, 02:53 PM | #36 |
Rep 7,431
Lol no need I'm glad I could have helped!
VisualEcho6636.50 |
05-07-2021, 03:01 PM | #37 | |
9105
Rep 7,563
Every penny counts, I guess . |
05-07-2021, 03:15 PM | #38 |
Rep 3,696
Depends on the use case.
If you hit the track, waiting for this to fail is an amateur move. Letting it blow with a sudden drop in speed and no brake lights is a great way to cause an accident. Personally, I think it’s also an amateur move not to upgrade it even for a daily driver while you’re under the hood doing other work. Who wants to get stuck on the side of the road away from home when it’s inconvenient and have to get a tow? I’ve seen too many of these let go in person. Just bc yours hasn’t yet doesn’t make you a clairvoyant genius. You’re just delaying the inconvenient inevitable, unless you don’t plan to keep the car and just want to gamble. |
05-07-2021, 03:35 PM | #39 | |
Rep 7,431
ZM22813.50 VisualEcho6636.50 |
05-07-2021, 03:42 PM | #40 | ||
16570
Rep 8,427
Insane 💥
Poochie9104.50 |
05-07-2021, 04:37 PM | #41 | ||
Rep 906
Fun fact on Ferrari though. Cheers
Poochie9104.50 |
05-07-2021, 05:09 PM | #42 | |||
9105
Rep 7,563
The main reason these pipes are all being made out of composite plastic is due to ABS plastic having a lower heat retention than of aluminum and it's not because BMW are necessarily cheap bastards for using a wearable component such as plastic over aluminum. An aluminum pipe sitting between the intercooler and intake pendulum is going to heat up the air way more than plastic piece, with can produce a power loss due to the inherent heat-soak. The counter argument to this is, in theory, air travels through the intercooler before entering the chargepipe at such a fast pace that any change in air intake temperature should be minimal but in practice, anyone with a N55 motor and has put it through the paces knows very well that it is very sensitive to rising temperatures, especially since the ECU retards power upon sensing higher intake temperature to prevent detonation or piston pinging. Anything to reduce any possible heat soak, such as plastic over aluminum would be beneficial. So your aluminum pipe might last until the end of time but it ain't exactly doing you any favors when it comes to overall performance. I think we should all personally weigh the pros and cons of each option and respect each other's decision for using what they feel best suit their needs. BTW, another fun fact is the B58/S58 uses all ABS plastic pipes and it seems to be holding just fine. I guess BMW engineering are just a glutton for punishment. |
05-07-2021, 05:23 PM | #44 | |
Rep 3,696
Do you think the air just sits around in the charge pipe and heats up? The majority of that airmass is flowing fast enough thru the piping that whether it’s metal or plastic makes no difference. If you think I’m wrong, provide some logs showing this temp impact you’re believing to be the case. And the fact that you drove around for a week with a busted charge pipe pretty much sums up your credibility on this topic. |
F87source7253.50 CalAcacian549.50 |
