05-06-2024, 09:52 PM | #1 |
Rep 507
Drives: 2018 M2 6MT
first time: stuck entering driveway
Navigating the entrance to my driveway is seemingly the trickiest bit of driving I do. It'll eat my bumper alive if I come at it straight on, so I have to go at it as parallel to the entrance as I can. The more parallel: the faster I can take the entrance without issue.
One of the rear wheels lifts momentarily no matter how I navigate the driveway entrance. If I approach too quickly, the wheel lifts and lowers fairly violently, which I imagine can't be good for the suspension. If I go too slowly, well, I don't make it up and over the transition from road to driveway. And there isn't much difference between too fast and too slow. Usually, if I go too slowly, the car rolls back down the incline and I try again. Today, the trash receptacles were out on the street. So I had to take a much more perpendicular approach than I'm accustomed to. I went slow. Real slow. I could anticipate hearing the bumper scraping along the driveway entrance and wanted to avoid that at all costs. As I eased the car up over the transition, I could tell I wasn't going fast enough. I expected the car to roll backward so I could give it another try. Instead the car settled mid-transition with one rear wheel off the ground. I put the car in reverse: the mid-air wheel spun. I put the car in first gear: the mid-air wheel spun. I had to get out of the car and push it back down the transition so that I could give it another go. I'd been wondering when this day would come. The day was today. I've love to redo the the incline on my driveway, but that's for another time. And no way I can go lower than stock until such a time. |
05-07-2024, 01:53 AM | #3 |
22134
Rep 8,720
05-07-2024, 09:17 AM | #4 |
Rep 507
Drives: 2018 M2 6MT
05-11-2024, 09:44 AM | #8 |
Rep 507
Drives: 2018 M2 6MT
Admittedly, this was the first time getting stuck on the dreiveway in my two years of ownership of the car. So I suppose that’s not too bad. And it’s certainly part of the reason why I’ve wanted to avoid the expenditure on a Bridjit or similar. Even so, it certainly wasn’t a good feeling to have to get out and push the car off the driveway.
05-11-2024, 09:55 AM | #9 |
Rep 448
I have the same issue coming into my driveway. (And why I'll never be able to have a front splitter on my car. )
I'm surprised that the LSD didn't lock up and push you through. Depending on angle/speed, my right rear tire often comes off the ground. I can hear the LSD motor zipping and get a clunk as it almost violently locks the diff up so I can maintain traction. Thought something was breaking the first few times I heard it. I try to avoid it though, as I can't imagine a hard slam lock like that is good for the diff clutch packs. My son has an FRS, and the same issue for him. But that car has a Torsen diff, which handles this much better than a clutch type diff like we have. |
///M TOWN22133.50 |
05-11-2024, 04:47 PM | #10 | |
Rep 507
Drives: 2018 M2 6MT
However, I had the clutch fully engaged in both 1st gear and reverse and the car moved nowhere. Just the rear wheel in the air spun. I did engage the clutch without any throttle/accelerator pedal. Maybe that’s part of it? I wonder if there would’ve been a difference if I’d given it a little gas? |
05-15-2024, 02:19 AM | #11 |
Rep 1
Any update? a few days ago I asked for help with an assignment but it didn't help. I found a solution for this. This is a website called https://domypaper.com/ DomyPaper. They are a writing service provider and will write for you if you pay them. I use them to get rid of that lean work. If you want to do that too, go and check out their website..
