01-30-2019, 04:04 PM | #46 | |
IG @bmwF9xG80
3813
Rep 7,593
60-130mph 6.5s X4M #HCP
01-30-2019, 05:28 PM | #47 |
Rep 1,348
Nice ! Is this the kit built using David's car? SWEET!!!
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 01-30-2019 at 05:33 PM.. |
02-06-2019, 01:01 PM | #48 |
Rep 449
Saving this for later so I don't throw away my warranty just yet. OP great job on all the research and write up. Curious what you do for a living being so organized lol.
nothingman522.00 |
02-25-2019, 09:22 PM | #49 |
Private NumNuts
522
Rep 321
We have a new addition from BP-Engineering using a hybrid dual ball bearing turbo and an inconel material turbine wheel; which is the same material used in the Garrett GTX turbo series. This should mean super fast spool-up but the kit isn't cheap @$6,500 USD!!
02-25-2019, 09:31 PM | #50 | |
Rep 7,431
02-25-2019, 09:55 PM | #51 | |
Private NumNuts
522
Rep 321
02-25-2019, 10:03 PM | #52 | |
Rep 7,431
Hope they can drop the cost though, $6500 is really expensive.
03-04-2019, 11:51 AM | #53 |
Rep 99
Here is a comparison between original and tte550
Original TTE 550 Last edited by Rondavouz; 03-04-2019 at 02:06 PM.. |
10-20-2019, 06:55 PM | #55 | |
Rep 30
10-20-2019, 07:15 PM | #56 |
Rep 7,431
It's still in testing phases/development, I've heard the stage 3 doesn't have an ETA yet.
10-20-2019, 07:22 PM | #57 |
Rep 30
Ok thank. I've got a sneaking suspicion that it will be the best turbo out of them all
10-20-2019, 08:18 PM | #58 | |
Rep 7,431
The gtx 3076r CHRA that VTT is using is good, but tbh I don't think it'll be able to outspool an EFR with its titanium blades and what likely may be the best ball bearing core in the turbo industry. Plus speedtech's manifold has better collectors and a smoother merge point imo, and from what I heard VTT has been having issues boosting past ~2X psi apparently due to their manifold.
10-23-2019, 08:13 AM | #59 | ||
Rep 30
So any insight on the technical Side of it will be appreciated. The only reason I said it would be better is due to fitment. As the exhaust housing looks identical to stock location. My understanding is the issue with the N55 turbo it's the exhaust housing and manifold being restrictive. I've heard that pure turbo have had failures due to this down the grapevine.. |
10-23-2019, 08:58 AM | #60 | |
Rep 7,431
Edit- this is normal with development of a turbo from the ground up, they are just ironing out the kinks just relax and wait.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 10-23-2019 at 09:30 AM.. |
11-10-2019, 01:20 PM | #61 |
Rep 361
Is anyone aware of any speedtech kits installed on an N55 M2? From Speedtech website: “Unfortunately, we have not fit up our kit on the M2, though it looks that most PN's are common between our F30 kit, with the exception of the RH motor mount support (this would have to be fabricated by the end user), and subframe.”
11-11-2019, 09:28 PM | #62 | |
IG @bmwF9xG80
3813
Rep 7,593
11-22-2019, 10:52 PM | #63 |
Rep 112
Drives: 2017 BMW M2 - Mineral Gray
Wow Charlie! Havent visited the M2 forums in a while. Saw this thread, amazing! Awesome job here
nothingman522.00 |
01-05-2020, 01:31 PM | #64 |
Rep 361
Which St1 turbo is the best choice? Or are they basically the same?
I’m really all over the place trying to decide which turbo to buy from settling for st1 all the way to st3 or trading for an M2c. In a perfect world, I would like 450whp on 93oct without touching the hpfp or increasing lag. I think the tte460 would get me closest to my goal but the 6 week turn around is unacceptable. Any suggestions? |
01-07-2020, 02:21 AM | #65 |
Rep 354
That's why you should for a Ball bearing turbo kits (bigboost), if you want performance, without additional lag. Having upgraded HPFP is not a bad thing at all as you can then run stronger E mixtures. E30-50 as well.
01-08-2020, 10:54 AM | #66 |
24201
Rep 190,807
Thank you
