M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Remus Exhaust + Fabspeed Sport Cat Review
      03-16-2018, 01:06 PM   #23
mike@x-ph.com
mike@x-ph.com's Avatar
Originally Posted by mrmjk View Post
Wow, great write up. Definitely helped me a lot as I'm just deciding between Remus and MPE.
REMUS easily!
https://x-ph.com/sale/
Phone number 702-494-9435
      03-16-2018, 05:17 PM   #24
F87_LCI
F87_LCI's Avatar
1787
Drives: 2018 LBB F87
Can someone with this exhaust post a quick video inside the car (windows UP, radio off)?? I would like to hear specifically if there is any drone around the 3K RPM range. Preferably someone WITH Fabspeed Sportcat. I'm one headache away from ripping out my MPE!!
      03-16-2018, 06:38 PM   #25
AGM2
AGM2's Avatar
Drives: M2 LBB 17
Here is my video to compare. Windows closed, valves closed and sport and sport+. The drone is lower from the first day, like I said I drive with closed valves and this sound much better than the stock with open valves, deeper
:l ove: ( POW,POW,POW)
Fabspeed DP & M Exhaust flaps Open
wassy497.50
      03-26-2018, 07:54 AM   #26
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Here you go. 6th gear down to 5th In Comfort mode with valves shut. 6MT. Approx 65mph at 3k rpm. Windows up, radio off, ASD delete. If you're just cruising there isn't any drone. If you floor the gas pedal in 6th without downshifting then yeah, you might get some resonance. That's to be expected with the sport cat no matter what exhaust you're running. It doesn't drone under normal driving conditions and you could most definitely drive it all day without getting a headache.
      03-26-2018, 10:56 AM   #27
F87_LCI
F87_LCI's Avatar
1787
Appreciated AC. If I drive in Comfort with valves shut, it isn't that bad. But switch to traction with valves open and the drone is numbing at 3K rpm. It's too bad, because the rest of the time this combo sounds really good. Waiting on results of another member putting their resonator back on to see if that helps...otherwise I'll likely be changing exhausts.
      03-26-2018, 04:54 PM   #28
mike@x-ph.com
Thank you for the videos
AndrewC198910931.00
      03-26-2018, 07:03 PM   #29
AndrewC1989
Here's traction mode w/ valves open in 1st, 2nd and 3rd gear:
There's a little drone but not much. It really doesn't translate well through video. There's only so much a cell phone clip can show you about an exhaust. You really need to hear it in person to decide if it's better than what you have and if it's worth making the switch. If i were you i'd hit the regional forum and see if anyone in your area has this set up so you can hear it in person.
I hope you sort your issue out one way or the other. Best of luck.
      03-29-2018, 05:51 PM   #30
18EM2
Public Last Class
18EM2's Avatar
Drives: 2018 M2 DCT LBB
2018 BMW M2  [0.00]
Anyone experiencing drone with DP and stock exhaust?
      03-29-2018, 08:28 PM   #31
BMWPWR18
Drives: 87' 535is, 18'M2 (sold)
No, I didn't notice any drone with stock exhaust sport cat.
      04-23-2018, 05:10 PM   #32
Turbo_addict
Drives: 2017 MG M2
Well I had quite the Sunday afternoon.
I drove from Philly to Montclair NJ to meet up with Andrewc89 and listen to this exhaust setup.....
MY GOD....
It was everything I hoped for and more!
I already have the sport cat so I wanted to hear the Remus and sportcat combo, I was blown away. The sound is crisp and has a beautiful deep tone unlike most of the exhaust systems out for the M2. I have not had the luxury of hearing many other exhaust systems but I have heard the Akrapovic. In my honest opinion the Remus sounds worlds better than akrapovic and for half the cost.
Andrews videos are great but it sounds even better in person. It’s always difficult to capture the sound on a phone which is the reason I drove two hours. Anyone that’s on the fence about this combo rest assured, it’s incredible and worth the money.
I am convinced and ready to order.
I will update this thread as soon as I get mine.
Thanks again Andrew!
AndrewC198910931.00
      04-23-2018, 05:25 PM   #33
AndrewC1989
MY GOD....
No problem Matt, It was nice meeting you! Glad the long trip was worthwhile
      04-23-2018, 06:04 PM   #34
mike@x-ph.com
MY GOD....
Lets do it!
      04-24-2018, 04:37 PM   #35
Benef1cient
Benef1cient's Avatar
Poland
287
Drives: '18 LBB M2 LCI 6MT
Who can ship these cats outside USA?
Is there a Fabspeed vendor somewhere in Europe?
      04-24-2018, 05:02 PM   #36
mike@x-ph.com
We can
      09-28-2018, 08:23 PM   #37
nioh_lbbm2
nioh_lbbm2's Avatar
1717
andrewc89 could you make a quick video showing the differences between closed valve and open valve? I'm trying to see if it's worth it to purchase the CG module since I have the same exhaust setup as you.
I know you have the two separate videos showing cold start but it's hard to gauge the differences in volume in two separate recordings.
      09-29-2018, 02:04 PM   #38
AndrewC1989
I like the valve controller very much and I highly reccomend it but you have to understand it isn't going to make a big difference in volume during your cold starts. They are going to be brutally loud regardless.
(The easiest way to combat this is to put your foot on the throttle after you start the car and raise your rpm's 100-200 while you're in neutral. The car quiets down a ton right away. Hold for 30 sec and you're good.)
Where the valve controller DOES make a big difference is when you're driving or revving outside of the cold start. It changes the sound your exhaust makes quite substantially. Opening the valves in Sport+ makes a bunch of noise and closing them in comfort makes the car sound almost stock. Very convenient when you're hungover or have the wife/gf in the car.
That being said here's a quick 2min clip of a cold start I just made starting with the valves open. You can hear the sound/volume change as I open and shut them every few seconds. You'll have to forgive the audio cutting out for a few moments during the video. It's so loud that my iPhoneX couldn't even record it properly. The 4K 60fps sure does look good though.
After the cold start sequence is over I open and shut the valves a few times and then rev it in Sport+; again, alternating between open and closed. Sorry I didn't have time/patience to add annotations indicating what the valve position is but I'm sure it's very obvious/easy to tell when they're shut vs when they're open. Hope this helps.
      09-29-2018, 02:10 PM   #39
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Thank you man! This was exactly what I wanted to hear. I didn't care much for cold start noise but more for normal driving and you're right it is much lower in volume with the valves closed.
so the VSC-1 will do for us even though the Remus has two valves?
      09-29-2018, 02:17 PM   #40
AndrewC1989
Correct, the VSC-1 is what you want. The remus system already comes with the cable/harness connecting the valves so you don't need the VSC-2.
      09-29-2018, 02:21 PM   #41
nioh_lbbm2
nioh_lbbm2's Avatar
1717
much appreciated!
      09-30-2018, 09:43 PM   #42
bluem2
Drives: lbb m2
got the same set up as Andrew after reading his review last November. Pulled the trigger almost right away. As he rightfully mentioned ,the only downside is the early morning start ups, it is just pure nuisance. But just driving off with it is completely fine and kinda shortens the cold start procedure.
please let me know if you get a rattle on the rear deck around the speaker area under load once you install the set up !
      10-01-2018, 03:05 AM   #43
FIDDIE
Drives: M2 LCI
Someone has measured db level with the differents setups?
It will be very interesting
      10-01-2018, 05:06 PM   #44
nosbocaj
nosbocaj's Avatar
695
Drives: 2023 M3 Competition xDrive
Great thread! Your other thread really sold me on the Fabspeed Sport Cat and Dinan resonator delete. I was thinking about Dinan's exhaust, but I've heard the tips hang low, so I think Remus is now my first choice. Thanks for all of the videos!
Current: 2023 IOMG M3Cx
Past: 2018 AW M2, 2010 AW M3
M2 LCI European Delivery
AndrewC198910931.00
