M2 Technical Topics > Track / Autocross / Dragstrip > B-street setup
      12-30-2017, 12:39 PM   #45
CLH
CLH's Avatar
Drives: 2018 M2 LBB 6MT
Next question (which I can’t seem to figure out a definitive answer for from older posts): TPMS or no TPMS on the dedicated autox wheel/tire set?
From what I can gather from other posts, with no TPMS you can still turn DSC full off, but end up with comfort mode steering and throttle response. Can anyone confirm from actual experience?
Chris H. - In the sunny PNW!
My handy Speed-in-Gears calculator
      12-30-2017, 01:03 PM   #46
ZM2
Drives: 2017 LBB M2
This is definitely true for pre-LCI. I’m guessing it’s the same for LCI.
I think it would be tolerable for an MT car. I actually like comfort steering and throttle for more variable input, but it makes the shifting super slow on a DCT car.
CLH116.00
      12-30-2017, 07:24 PM   #47
ZM2
Drives: 2017 LBB M2
Originally Posted by jnoyes View Post
Thanks for the feedback.
I'm thinking 255/275 RE-71s may be my starting point with this car, along with a front Dinan bar (and I'll put the rear bar I can't use in BS in the closet.) If 255/285 will result in more understeer (I think you're right about that), then backing off to 275 in the rear would restore the factory balance but with more grip from the RE-71s and a little more width. I'll run the stock 19s to save a little money. And I won't have clearance issues no matter how hard I push.
After the 2018 AX season, if I choose to go bigger, then the "perfect" Apex 9.5/10.5" 18 inch setup with coilovers, camber plates, and more tire with way more camber would be in order.
Food for thought: 255/285 keeps the closest F/R tread width increase ratio, vs 255/275 or 265/285. It may be the way to go. Doubt my 4S’s will wear out until this time next year, so I won’t know for a while.
Also, while 71R’s are great on the track, here are my and others thoughts for the street: http://f87.bimmerpost.com/forums/sho....php?t=1441056
      12-30-2017, 08:35 PM   #48
jnoyes
Member
jnoyes's Avatar
Drives: 17 BSM M2 6MT Exec
Hmmm. Check my math here (rounding to three places):
Stock = 245/265 = .925
255/275 = .927
255/285 = .895
265/285 = .930
Sure looks like 255/275 Is nearly a dead ringer ratio-wise, 265/285 is pretty darn close too.
I don't track much, but have done enough autocross to cook a set of tires every year for the last 7 (in an E36 M3), so am confident saying the RE-71r is fantastic. The Rival S 1.5s I ran last year were great too, but not quite as good cool or wet as the RE71s. The ZII Star Specs and first gen Rivals I ran before that were very good, but not magic like the RE-71rs. In 19" 200 treadwear, I just don't see another tire right now that I'd consider for AX. I'll just live with the on-street poor wear in exchange for the off street performance.
On the TPMS issue: it costs a little more to have it, but I think worth the $. Better to be able to have access to what limited modes are available in the M2 (and they are too limited IMO, but that's how it is). I'll run all nannies off for AX, but it's nice to have a little computer backup if it's bombing rain or a friend is trying it out.
      12-30-2017, 08:58 PM   #49
ZM2
Drives: 2017 LBB M2
255/275 = .927
255/285 = .895
265/285 = .930
Agreed on keeping TPMS, plus it’s nice to see changes in temp and PSI on iDrive.
On the ratios, I meant the percentage tread width increase in the fronts and rears. Tirerack shows treadwidth measurements for each size and even if you give some of the measurements a couple extra tread width tenths bc of differing wheel sizes used by Tirerack vs OEM, the percentage change in the front and percentage change in the rear matches up best with 255/285.
      12-31-2017, 08:03 AM   #50
jnoyes
Member
jnoyes's Avatar
255/275 = .927
255/285 = .895
265/285 = .930
Agreed on keeping TPMS, plus itÂ’s nice to see changes in temp and PSI on iDrive.
Ah, I follow you now. Makes sense based on tread width or section width increase from stock. Just not sure if I want to get into height issues with the taller 285/35 on stock suspension either, and you can't get any 200 treadwear tire in a 19" 285/30. That'll have to wait til a move to 18". So within a narrow discussion of B-Street, things look a little different than if using the setup for other things.
      01-01-2018, 07:18 PM   #51
CLH
CLH's Avatar
I think ECS is going to get me with their email marketing ;-)
Their marketing email today had a blurb about a 25% sale off of Alzor wheels. I think I'm going to the pull trigger on these.
I'll need a spacer up front, but for the price I don't think I can go too terribly wrong.
      01-01-2018, 08:14 PM   #52
ZM2
Drives: 2017 LBB M2
Why those over the Apex’s that have a front offset closer to OEM and are 9.5” wide vs 9”? You can also get a 10.5” rear.
      01-01-2018, 10:35 PM   #53
CLH
CLH's Avatar
I need stock widths for street class. The price on the Alzor wheels is pretty compelling too. Since they’re only going to be used for auto-x, lower cost makes them easier for me to consider them expendable.
      01-01-2018, 10:46 PM   #54
ZM2
Drives: 2017 LBB M2
Ah, got it. You can get 18x9 and 18x10 Apex’s for $300-330/wheel. The rears are ET33, hopefully that wouldn’t stick out too far.
Edit: I’m now seeing that Alzor price is for four wheels. That’s cheap!
      01-02-2018, 11:15 AM   #55
CLH
CLH's Avatar
Indeed. That's why they're so tempting...
      01-02-2018, 11:34 AM   #56
CSBM5
CSBM5's Avatar
2733
Drives: 2019 M2 Comp, 2011 M3, etc
...probably don't want to use them for track events...
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
      01-02-2018, 07:27 PM   #57
CLH
CLH's Avatar
Nope, autocross only
      01-02-2018, 07:29 PM   #58
CLH
CLH's Avatar
I pulled the trigger today and ordered a set of Alzor 040 18x9/18x10 wheels and an H&R front bar from ECS. Now I need to grab a pair of 8mm or 10mm spacers and extended bolts for the front.
I'll post up some pics once I get them.
CSBM52733.00
      01-05-2018, 07:03 AM   #59
jnoyes
Member
jnoyes's Avatar
Hoping they have adequate brake clearance. Not all 18s do. Fingers crossed. The spacers may make the difference.
      01-06-2018, 02:24 PM   #60
young1
'17 M2 Mineral Grey
young1's Avatar
Drives: 2017 MG M2 6MT, 2002 E46 M3
Michelin Pilot Sport 4S 30 profiles?
There are a couple sizes that I am wondering would fit on stock wheels/suspension...
275/30-19 (f) & 295-30-19 (r)
They are very similar in diameter to the OEM tires, just wider. Will they fit/clear?
[Dedicated 18" wheels with RE71's in the future, but short-term need a new set of daily driver tires... fronts bald at outside edges at 7K miles thanks to several auto-x events]
      01-07-2018, 03:29 PM   #61
young1
'17 M2 Mineral Grey
young1's Avatar
fyi, I put a 295/30-19 tire from my E46 M3 CSL wheel on the M2 rear and it seems to clear fine. So... I just need to determine if a 275/30-19 tire will clear in the front. Thanks in advance for any shared experience... yo, Tirerack dude?
Here's a pict of 295/30-19 tire mounted on 10" CSL rim on my E46 M3 as requested... (one of the reasons I put a larger tire on this daily driver rim was to reduce the car-wash curb-rash). Since then, have found car washes with the new conveyor belt transport (GREAT improvement).
      01-07-2018, 07:45 PM   #62
rwalker
Drives: the wheels off
275 section width tire will fit (on a 10 inch wheel with et28 or lower), but will poke. See here:
http://f87.bimmerpost.com/forums/sho...&postcount=234
      01-08-2018, 03:11 AM   #63
Bee Pee
Bee Pee's Avatar
1784
Drives: AW M2 DCT
Isn't 295 width tyre too wide for OE 10" wheel ?
I'd read somewhere 285 was max width recommended for 10" wheel.
Please post up photos of OE rear wheel with 295 tyres on as curious to see how they look in reality.
Current '22 X3M LCI..
      01-08-2018, 07:20 AM   #64
CSBM5
CSBM5's Avatar
2733
Anything's game in street class. I ran 275s all around on my E90 M3, BFG Rivals, on 8.5/9.5 wheels. They were pinched a bit on the 8.5's, but they worked fantastically on course. The recommended range for a 275/35-18 is 9-11".
I've seen some crazy stuff over the years in stock class. A multiple national title winner in solo and pro solo here locally used to have an Integra Type R which required 6" stock width wheels, but he stuffed 275 Hoosier A6s on those.
In any event, a 295/30 is fine on a 10" wheel. In fact the TRA (tire and rim association), which maintains the industry standards, shows a recommended wheel width of 10-11" for a 295/30-19, so it is officially a recommended fitment (not that anybody in street class pays much attention to these, lol).
Regards,
Chuck
Current Stable:
      01-12-2018, 07:06 PM   #65
young1
'17 M2 Mineral Grey
young1's Avatar
So... has anyone tried a 275/30-19 front tire on a OEM front wheel? Or can someone report on amount of remaining tire clearance on a 265/30-35/19 tire?
Thanks!
      01-24-2018, 11:45 AM   #66
CLH
CLH's Avatar
I just got back into town from vacation and finally had a chance to test-fit the Alzors. Sadly, no go. Even the rears wouldn't clear. The shape of the barrels is such that they narrow too much toward the face of the wheel, causing them to hit the outside of the caliper before they seat on the hub.
I have an RMA from ECS, so they'll get shipped back for a refund. I should have known it was too good to be true.
At this point I think I'm just going to go with the EC-7s. They're known good and won't need any spacers.
