Classifieds Section > Sponsors Classifieds > Bootmod3 Custom Maps UP TO 580 WHP On Stock Turbo!
      10-19-2019, 03:23 PM   #1
mike@x-ph.com
mike@x-ph.com's Avatar
Talking Bootmod3 Custom Maps UP TO 580 WHP On Stock Turbo!
Custom Bootmod3 Maps By Jordan (Carythelabelguy) From Extreme Power House
S55 (Stock Turbos)
  • Full E85 Stage 1 S55 (Stock Turbos) 540+whp/550+wtq / 20-21psi Peak Boost
  • Full E85 Stage 2 S55 (Stock Turbos) 560+whp/570+wtq / 23-24psi Peak Boost
  • Full E85 Stage 2 Hybrid S55 (Stock Turbos) 570+whp/580+wtq / 25-26psi Peak Boost
  • Full E85 Stage 2+ S55 (Stock Turbos) 580+whp/600+wtq / 26-27psi Peak Boost / Max Effort Stock Turbo Tune
  • 93 Octane (98RON) S55 (Stock Turbos) 500-530whp/540+wtq / 23-34psi Peak Boost
  • 91 Octane S55 (Stock Turbos) 485-495whp/500+wtq / 23-24psi Peak Boost
N55 (Stock Turbo)
  • E30 N55 (Stock Turbo) 410-460whp (Depending on OEM HPFP vs. Aftermarket HPFP)
  • 93 Octane (98RON) N55 (Stock Turbo) 380-420whp (Depending on OEM HPFP vs. Aftermarket HPFP)
  • 91 Octane N55 (Stock Turbo) 360-390whp (Depending on OEM HPFP vs. Aftermarket HPFP)
Order Link
https://x-ph.com/bootmod3-flash-tune/
https://x-ph.com/sale/
Phone number 702-494-9435
      10-22-2019, 04:06 PM   #2
MyM2See
Drives: 2020 M2C
not for 2020, correct?
      10-22-2019, 04:39 PM   #3
mike@x-ph.com
Check with PTF direct for ECU compatibility
      10-23-2019, 09:25 PM   #4
MyM2See
Drives: 2020 M2C
Don't know how. Shouldn't you know this as a vendor?
      10-24-2019, 09:49 AM   #5
mike@x-ph.com
i dont know which ECU version you have, i also do not know all the ECU versions that are compatible.
Not to mention new versions are unlocked every month, PTF are the ones would know if yours is compatible and if not they will have an ETA on when it would be.
Here is their email
sales@protuningfreaks.com
      12-18-2019, 11:00 PM   #6
mike@x-ph.com
      01-29-2020, 12:23 PM   #7
mike@x-ph.com
bump
      01-29-2020, 12:57 PM   #8
MZWIE
•93 Octane (98RON) N55 (Stock Turbo) 380-420whp (Depending on OEM HPFP vs. Aftermarket HPFP)
Really!. With no other mods. Hmm......
      02-17-2020, 12:29 PM   #9
mike@x-ph.com
bump
      03-03-2020, 12:21 PM   #10
mike@x-ph.com
bump
      03-18-2020, 06:03 PM   #11
mike@x-ph.com
bump
      04-09-2020, 12:12 PM   #12
mike@x-ph.com
bump
      04-28-2020, 06:08 PM   #13
mike@x-ph.com
bump
      05-18-2020, 03:23 PM   #14
mike@x-ph.com
bump
      06-06-2020, 09:32 PM   #15
sab568
Drives: 2007 MB/SB 335i Coupe
I have a question about maps and octane. I live in Panama where we have access to 95 octane fuel and its what I regularly use in my M2. Does BM3 have 95 octane maps?
      06-07-2020, 11:54 AM   #16
mike@x-ph.com
It does not have a 95 Octane specific map, you can use the 93 octane map or get a custom map for 95
      07-01-2020, 12:09 PM   #17
mike@x-ph.com
      07-14-2020, 05:59 PM   #18
mike@x-ph.com
      08-07-2020, 12:05 PM   #19
mike@x-ph.com
      09-08-2020, 12:20 PM   #20
mike@x-ph.com
      10-06-2020, 12:13 PM   #21
mike@x-ph.com
      10-30-2020, 12:16 PM   #22
mike@x-ph.com
