07-13-2018, 02:38 PM | #199 | |
Rep 3,803
07-13-2018, 03:06 PM | #202 |
Rep 3,957
If let out a big fart while torqueing, its to tight.
Happy Motoring474.00 |
07-13-2018, 05:25 PM | #203 | |
Rep 2,197
If I get an error, I’ll just have to go under and do it again
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
08-30-2018, 11:46 PM | #204 | ||
Rep 132
Thanks
2011 BMW X1 28 (sold)
2013 BMW 328 Sportline (sold) 2018 BMW M2 LCI (current) |
08-31-2018, 02:13 PM | #205 | |
Rep 1,466
BMW recommends that you replace all the V-band clamps and the turbo to DP gasket. I didn't replace anything the first two times I changed my DP, and did the most recent time. I didn't notice any difference and I had no leaks re-using the clamps and gaskets, but it's your call.
2018 ///M2 LCI, LBB, 6MT...
08-31-2018, 02:15 PM | #206 | ||
Rep 132
08-31-2018, 08:32 PM | #207 | ||
Rep 132
I removed the vclamp from the exhaust and unscrewed the turbo.. but it still stuck there.. any idea?
08-31-2018, 09:07 PM | #208 |
Rep 391
Pry the clamps loose. It’s squished onto the flange on both ends. Once they pop free you can spin them easily. Too on for me was real tightly stuck. I used a long flat blade to work it free one side at a time. Some guys knock on it with a hammer. I keep a bolt loosely connected on the support bracket so it doesn’t fall into my head. If I recall correctly on the m2 there’s two supports on the stock pipe as well, one is a bit hidden.
08-31-2018, 09:11 PM | #209 |
Rep 391
Looks like your bottom clamp is released off flange, top one looks like it is still seated. I see the bolt hole from the brace. Is the other one off? I think it’s just a nut as the bolt part is welded onto the second brace on downpipe.
08-31-2018, 09:21 PM | #210 | |
Rep 132
08-31-2018, 10:11 PM | #212 | |
Rep 132
I m been 3hrs on it lol
09-01-2018, 01:09 AM | #213 |
Rep 132
Finally finished.. damn its hard!
However i m not yet fully happy with the sound on a catless dp with the stock exhaust. I feel like i lost some sound and i got more drone style noise. And at mid rpm i get a strange drone from the back . As if the exhaust vibrates..
09-01-2018, 06:27 PM | #214 | |
Rep 1,466
They're supposed to be tightened to a specific torque, and then further tightened by 90 degrees. If you re-use the bolts, you can damage the threads in the front sub-frame, because the old bolts will be stretched and therefore not the correct thread pitch any more, and you'll be effectively over torquing them because they're a already stretched. I re-used mine the first time and wish I hadn't. I doubt it's dangerous, but it's worse than reusing the exhaust clamps for sure.
09-02-2018, 12:19 PM | #215 | ||
Rep 132
The one bolted to the dp on the left? If so, the dp came with 2 regular screw with a stop nut. I only reused the two tuat we are supposed to loosen up
09-02-2018, 09:11 PM | #216 | |
Meh
928
Rep 781
Drives: M3CS & Cayman S
edit: also the low/mid-range rattle may be the wastegate vibrating. it's more audible now without the cat dampening the sound |
chief1richard383.00 |
09-02-2018, 09:13 PM | #217 | |
Rep 1,466
It has 8 torque to yield bolts holding it onto the front sub-frame, and a number of 8mm self tapping screws holding other plastic shields to it.
09-02-2018, 09:16 PM | #218 | |
Rep 132
Note my car is 2mth old and 1200km I had to use an hammer to unscre the o2 sensors.. they were stuck. No way i could unscrew them hanging in that tight space. Overall you guys are lucky to do that job in 30mins .. if everything would go well, i could do in 2-3 hrs but no way 30mins
09-02-2018, 09:17 PM | #219 | ||
Rep 132
09-02-2018, 09:57 PM | #220 | |
Rep 391
paniraid22.50 |
