09-06-2023, 04:30 PM | #221 |
3872
Rep 54,430
Drives: F80 M3
Add these titanium brake pad shims to your pads order to prevent conductive heat transfer to your brake fluid:
https://hpautosport.com/product/para...blue-calipers/ https://hpautosport.com/product/para...blue-calipers/ |
11-29-2023, 07:40 PM | #226 |
3872
Rep 54,430
Drives: F80 M3
Nov. 30th is the last day to get 10% off and free shipping on your Ferodo pads!
02-08-2024, 06:03 PM | #230 |
3872
Rep 54,430
Drives: F80 M3
DS1.11
The DS1.11 is one of Ferodo Racing's latest endurance race pad offerings. It has slightly less bite at high temps. vs their older DS3000, but doesn't decompose nearly as quickly under extended heavy use on the track. The DS1.11 is known for its extremely flat torque curve, which means that as temperatures go up, the response through the brake pedal remains consistent. The DS1.11 can be thrashed all day without having it burn up or fade, it's easy on discs, and doesn't have many of the judder or vibration issues that competing products have. If you want an extremely solid, all around race pad that will perform well and last a long time, the DS1.11 is the perfect choice. Fits all F2x F3x F8X F87 with 4 piston front and 2 piston rear brakes. ***Will not work on Carbon Ceramic Brakes*** |
