M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > m performance exhaust tip size (inlet)
      03-14-2018, 01:16 PM   #1
twboy1999
Drives: 1994 honda accord
Hi guys
I cannot justified the outrageous tips cost for the m performance exhaust
does anyone know the size of the exhaust that connects to the tips?
I am looking for a non oem alternatives for the m performance exhaust tips.
thanks
2019 M2 HS 10000km and counting
      03-15-2018, 07:15 AM   #2
BMWPWR18
Drives: 87' 535is, 18'M2 (sold)
Originally Posted by twboy1999 View Post
Hi guys
thanks
Here you go.
I will post updated pics with aftermarket tips once the MPE is installed.
      03-15-2018, 07:47 AM   #3
twboy1999
thank you sir
      03-15-2018, 01:40 PM   #4
McPurrs
The deuce gets loose
290
Drives: '17 M2 BSM 6MT
that inside measurement is off, by a shitload. You can see that the tool isnt being used correctly in both pics...
edit: this is the correct way to use the caliper.
And for the inside, the two tapered ends should sit all the way flat once inserted and opened. Only insert them the half inch or so of the taper.
      03-15-2018, 06:26 PM   #5
BMWPWR18
Tips fit, don't care
      01-21-2020, 12:13 PM   #6
Fedie
Fedie's Avatar
36
Drives: '18 M2
Originally Posted by BMWPWR18 View Post
Here you go.
millimetres?
M2 LCI bone stock
Recently gone, i3 on H&R Springs
Long gone, Le Mans Blue X1 xdrive35 M-Sport - Alpina TCU flash - HR springs - Catless dp - JB4 ST2 - CAI -- Alpine White 2007 335i E92 - Procede v3 Stg 2/3 custom - VRSP 3" DP - Stett charge + Forge DV - Stett CAI - CXracing IC
      01-21-2020, 12:25 PM   #7
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Originally Posted by Fedie View Post
millimetres?
Stock exhaust is 70mm inlet.
MPE exhaust is 67mm inlet.
Fedie36.00
TemjinX2520.50
