03-12-2018, 05:54 PM | #1 |
Rep 573
Issues with Direct Port Injection
Makes me want a catch can as my next mod:
03-13-2018, 02:06 PM | #3 |
Rep 6,635
03-14-2018, 12:42 PM | #4 |
Rep 221
Common myth that a catch can solves carbon build up issues.
The detergents in modern oil actually help reduce / break free carbon build up. Often the blowby is there by design to help the issue slightly - you can see this in almost all VAG engines engineering manual. |
03-14-2018, 01:14 PM | #5 | |
Rep 177
Drives: Long Beach Blue M2
If your engine is port injection as opposed to direct injection, the effect the fuel has on the valves helps reduce the buildup. I would be most interested in installing an oil catch can in my M2, but I haven't seen any easily installed solutions yet. I'm thinking of possibly buying a can from Mishimoto and installing it somehow, since it's not that expensive. |
03-14-2018, 01:34 PM | #6 | |
Rep 221
03-14-2018, 06:36 PM | #7 |
Rep 177
What are the direct factors then? Every reference I've come across seems to blame oil and direct injection remove the port injection benefit of cleaning the valves. Why do you say otherwise? Honestly curious.
03-14-2018, 08:03 PM | #8 |
Rep 573
I believe the only other paths to the intake system are through the air filter and via the EGR (exhaust gas recirculating) valve. Assuming the air filter is doing its job, the EGR in combination with blow-by could/would, I assume, cause buildup on intake valves.
03-14-2018, 09:26 PM | #9 | |
Rep 221
+ several other factors if you're interested I could explain. Catch can are great on high blow by motors as the oil vapor reduces the timing advance you can run when it enters the combustion chamber. |
03-16-2018, 09:55 PM | #10 | |
Rep 177
