03-11-2018, 09:22 PM | #1 |
Rep 4,551
Drives: 2015 328d xDrive
UCP - Ultimate Clutch Pedal
Anyone have one of these on their M2? Did it make a big difference?
Do you like it? How does it feel compared to stock? Pro's/Con's etc. |
03-11-2018, 09:50 PM | #3 |
Rep 4,551
03-12-2018, 11:00 AM | #5 |
Rep 485
Some impressions from several folks here: http://f87.bimmerpost.com/forums/sho...h+pedal&page=1
03-13-2018, 09:54 PM | #6 |
Rep 306
Drives: MY17 LBB M2
I have it. It is a worthy upgrade.
It does what it says it does: lower the clutch pedal (nothing more, nothing less). If you use/like the BMS clutchstop, this is a more complete modification (both are good, obviously the price point is a lot different). I have both. I chose the middle setting (sport), and the feel is still very much like stock. I'm curious to see what the race setting feels like, as I still would prefer to feel the clutch bite (it is still hard to feel it since the clutch is smooth; but the pedal travel is so short, its a non-issue). Because you have to get under the car to install it, it is almost a must to lift the car - and so I took it to a shop to install (I couldn't DIY it). I bought the M2 for its handles and feel and this mod does well to improve the drive experience. |
AndrewC198910931.00 |
03-13-2018, 10:10 PM | #7 |
Rep 485
I never went under the car installing mine, everything’s between the dash & floor. Still needed to do some contorting.
I tried the race setting, but the feel was weird; it was firmer, which was good, but about half way down it would just drop to the floor (which was bad). I changed to sport setting, which feels perfect. |
03-16-2018, 03:26 PM | #8 |
Rep 306
Drives: MY17 LBB M2
03-16-2018, 04:20 PM | #9 |
Rep 1,153
The UCP on the sport setting is noticeably different from stock, for me. Maybe an increase in pedal resistance of about 25-30%--enough to make it feel like you are pushing against a spring...instead of stock, which feels to me like pushing through water. Still not stiff by any means, but a change for the better.
Combine it with an SSK, and happiness is... |
AndrewC198910931.00 Spartan King79.50 |
04-06-2018, 01:53 PM | #10 | |
Rep 4,551
