03-11-2018, 08:37 AM | #1 |
Rep 4,203
MPE 3 mths and 2800mi update
To help others with questions concerning the MPE here is my update
Now after having the MPE since Dec (3 mths & 2800 mi) and doing a hard hi speed mountain road runs here are my current comments. Note: I have V2 with the exit pipe braces and slip over attaching interface. The exhaust is awesome..... the way a BMW track car should sound. Not too loud and obnoxious....just right Cost for me was reasonable since I didn't have to purchase tips. I purchased the exhaust from Sun Motorcars and had tips from previous F82 I run it in either sport with flaps open or comfort with flaps closed, why? *Cuz when you run flaps open and in comfort for some reason there is more resonating thru the car at below 3500 rpm then there is with flaps open. Why, i have no friggin idea. You would think it is the other way around. My car has the most pops/burbles in flaps open & sport, way more then in MDM & flaps open contrary what others are saying. The fit was perfect the first time, install straight forward The exhaust makes a little bit of HP proven with my dyno results 3-7hp aprox The water drain hole in the bottom leaves a black trail up the back of the polished can FYI Mine still has awful cold start vibration, but am used to it after having the F82 & MPE My bluetooth connection has been working fine so far and has not dropped. I did do the install myself so know how it was put together Feel free to ask any questions |
03-17-2018, 12:21 AM | #2 | |
Rep 88
Drives: 2018 BMW M2 | LBB | MT
horsepower_and_hounds1836.00 |
03-17-2018, 11:56 AM | #3 |
Rep 4,203
Ok so an update to my update....
So as you know I have the resonating cold start noise. I started playing around with some things to try and lesson the cold start resonation. I tried pulling the exhaust back a bit to load the rubber hangers differently and left it over night to get a true cold start. Still the same, but I moved it back too far and upon full temp and exhaust expansion it touched heat shielding. Then I tried moving it far as possible forward...still the same on full cold start. So it is not caused by design of the hanging points and as you know the exhaust also has a flex joint after the down piped so that should also help dampen any vibration. Well I remember someone commenting awhile back somewhere on here or the M4 forum about taking the tips off and trying it, I have the carbon-Ti tips. Well I took them off and it still vibrates but without the rattle resonating noise. It is a quiet vibration. So all this time with the F82 MPE and now the F87 MPE ( I have the same tips) the exhausts have always vibrated but the noise..... is being created with my M carbon titanium tips. Interesting..... I still love it |
Downunder9955.50 |
03-17-2018, 03:32 PM | #4 |
587
Rep 898
So here's your answer for the drone at 3K RPM in comfort but not sport.
In sport/sport+ modes the DME asks the EWG ( electronic wastegate ) to be closed, or at 99.99% Duty cycle until it needs to vent boost, this is for quicker spool times, vs when in comfort it's open until X amount of throttle input. When the EWG is closed it means less exhaust flow through the pipes as it's being absorbed by the turbine wheels, thus producing what we like to call BOOOOOOOOOOST. That's why it's quieter
03-18-2018, 02:14 AM | #5 |
Rep 1,017
Thanks for the updates on your MPE. I've had my M2 for just under a week and am still undecided, but starting to lean toward this exhaust again.
03-18-2018, 10:49 AM | #7 |
Rep 444
Drives: 2017 M2 6MT, 2022 X7 M50i
@m2ruder does yours feel louder after 2800 miles? I put around 4000 and it feels like it has gotten louder. Also, the dealership kinda fixed the rattle issue by pushing the exhaust in by about 3 inches. The cold rattle is now gone, with the only downside being that the exhaust tips sit about 0.5 inches behind the diffuser.
03-18-2018, 06:37 PM | #8 | |
Rep 4,203
voyagergab633.00 |
03-18-2018, 07:06 PM | #9 | |
Rep 1,083
I was curious as the tips on the driver side stick out marginally further. |
03-18-2018, 07:14 PM | #10 | |
Rep 4,203
Not if you have Ver 2 of the exhaust the attaching point on the stock pipe has a slip over joint and I tried pulling it back then pushing it forward to change the load on the hanger rubbers bit it was useless. To align your tips just slide them forward or back then re-tighten the set screw Not sure what MR_M2 is referencing in his comment whether it was the actual exhaust they slid in to the tips. If the physically pushed the exhaust forward 3in then it would be against the forward wall so it might be the tips |
voyagergab633.00 |
03-18-2018, 07:18 PM | #11 | ||
Rep 1,083
Is that joint closer to the front of the car? I recall seeing a roller type of thingy there. How do I tell if I have v2? My car was an October 2017 build and the MPE was port installed. |
03-18-2018, 07:21 PM | #12 |
Rep 4,203
Oct 2017 you should have Ver 2. There should be a bracket between the exit pipes on each side. Something that looks like a clamp that keeps then from vibrating, with a tightening screw in the middle. The slip joint is um just past the tunnel cross brace. You can see it if you look under the car...there is a clamp
03-18-2018, 07:23 PM | #13 |
Rep 1,718
Do you have an aftermarket DP? I have a Fabspeed Sportcat...and the Drone Zone (2800-3200) is horrible...in any mode to be honest but is worst when in traction mode with flaps open...which is sad since this is the combo that often has bystanders diving behind bushes, lol
03-18-2018, 07:26 PM | #15 |
Rep 4,203
Nope no DP...and as for the traction mode (MDM) it is not louder on my car. Sport is louder and has more crackles on mine with the MPE then MDM.
MDM mode might give you more on the stocker but not mine with the MPE |
03-18-2018, 07:28 PM | #16 |
Rep 4,203
voyagergab633.00 |
03-18-2018, 07:32 PM | #17 |
Rep 1,083
03-19-2018, 08:56 PM | #19 | |
Rep 1,339
I dont know if this will help much but as i installed and experienced both Fabspeed and Akra. The drone is felt less with Akra compared to Fabspeed. Not sure if that is because if 200-cell HJS in Fab compare to 300-cell HJS with Akra. I believe cell would not play any possible role making difference in drone but it does seem to be reduced noticeably. I changed them because i was looking for less emission making option but still wished to have better sound compared to the stock DP. (I have MPE as well) My wife was complaining abt the CO2 comes from the car compared to stock one although i did not feel much difference. She was concerned abt our 2 yr old daughter. I know u live close by but if u wish to see the difference we can meet up at some point. It could be just me feeling that way but u can ay least have a chance to compare urs and mine. I dont have any stage ECU or turbo tuning or intakes installed yet. Soon will be doing some mods after this year with some dinan stuff I will be away from GTA and returning around first week of April. PM me if u r interested meet and discuss. I think it would be fun |
03-19-2018, 09:03 PM | #20 |
Rep 1,718
