03-13-2018, 03:14 PM | #89 | |
Rep 209
Your build sounds awesome too!
Instagram:@skrrrt.garage
2013 C63 AMG (Sold) 2014 Nissan GTR (Sold) 2018 BMW M2 (Sold) 2005 Lotus Elise (Sold) 2015 Bmw M3 |
twin fed1175.50 |
03-14-2018, 05:13 PM | #90 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
from this thread:
http://f87.bimmerpost.com/forums/sho...5&postcount=40 |
03-15-2018, 12:05 PM | #91 | |
Rep 99
Did you have to remove the front bumper? |
03-15-2018, 12:49 PM | #93 |
Rep 4,515
You shouldn't have to if its genuine PnP as OEM FMIC comes out from underneath w/o issues so would expect upgraded FMIC to go back in the same way.
FWIW installed Wagner Comp Evo 2 FMIC on my F2x n55 as above ie not removing front bumper.
Current '22 X3M LCI.. |
03-15-2018, 01:10 PM | #94 |
Meh
926
Rep 781
also from this thread:
http://f87.bimmerpost.com/forums/sho...9&postcount=34 the video i made of an FMIC installation. no bumper removal required. |
horsepower_and_hounds1836.00 |
03-17-2018, 07:28 AM | #95 |
Rep 573
For anyone who has installed this, have you done anything to clean the intercooler out before installing it? When I took mine out of the box last night to install it this morning, I took the caps off the end tanks and saw a piece of casting so I rubbed it with my finger and it came off fairly easily. I managed to get the piece out, but it concerns me about other similar pieces. It seemed relatively large - about the size of the end of a medium ball-point pen. Not sure what that would do to the turbo cold side, past the valves, in the combustion chamber, etc...
Thanks in advance for your input! |
03-17-2018, 11:07 AM | #96 | |
Rep 573
I wonder about the strength of the plastic mounting points for the intercooler with the two relatively small OEM mounting lag screws. It looks like longer ones might be better, but it's still plastic and that intercooler is heavy! Overall, very pleased with the arrangement and install! |
03-17-2018, 11:30 AM | #98 | |
Rep 4,203
03-17-2018, 09:39 PM | #99 | |
Rep 3,539
I couldn't get my FTP charge pipes (turbo to intercooler, and intercooler to intake manifold) installed with the CSF IC. These are the only aftermarket pipes I know of for the N47/328d. The CSF outlet location is too close to my intake manifold opening for the pipe, and the intlet is at too different of an angle for the turbo to intercooler pipe. I ended up taking the CSF IC out and putting a Wagner EVO 2 competition in. In comparing the two, I noticed that the inlet/outlets on the Wagner are actually closer together than the CSF. There's a good half inch of extra room between the CSF inlet/outlets compared to the Wagner. The cores are the same width, but the CSF end takes place the inlet/outlets further apart. I was able to get my FTP turbo to intercooler and intercooler to intake manifold pipes installed with the Wagner. EDIT: After pulling my OE IC out of a box and comparing it to the CSF IC, the spacing between the CSF inlet/outlets matches that of my OE IC, so the Wagner is narrower than reference. Last edited by FaRKle!; 03-21-2018 at 12:58 PM.. |
ceedawg467.50 |
03-29-2018, 07:22 AM | #100 | |
Rep 1,348
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 03-29-2018 at 09:18 AM.. |
03-29-2018, 07:36 AM | #101 | |
Rep 1,348
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
03-29-2018, 02:02 PM | #102 |
756
Rep 504
We have another 55 intercoolers shipping out Monday from our factory and will be sent out to customers end of April once our container is unloaded. (all of these are already sold based on priority order to our dealers and distributors)
Another 100 intercoolers coming middle/end of May - about 1/2 of this shipment is to fill more backorders, and the other 1/2 is to put some into stock for new orders. - Another 100 pieces behind that for late June delivery as well. CSF will have plenty of intercoolers to keep up with the demand in the next 45-60 days. PM me with any questions. |
04-13-2018, 02:18 PM | #104 | |
Rep 203
None the less everything fitted fine, initially was looking for some kind of mounting hardware. Found some washers which did the job. |
05-01-2018, 02:21 AM | #105 |
Bright Sky
1164
Rep 922
Drives: BMW M235i (8AT)
So I just had my trusted shop install the FMIC. They had no issues installing/fitting the FMIC (ER CPs on both sides), but they did point out that the setup feels a bit less secure than it could be. They weren't overly confident if the fmic being held by two screws and washers was the beast idea. It does sit in there pretty tight and it doesn't look like it's going anywhere.
Will post a pic of the FMIC installed later Last edited by wjjkoevoets; 05-01-2018 at 06:11 AM.. |
05-01-2018, 12:23 PM | #106 | |
756
Rep 504
BIG update The intercooler is now TUV approved - looking at CARB approval next, which should be easy with the TUV approval coming before it! we have 2 intercooler containers coming this month - 1st intercooler of silver units arriving end of this week / early next week (depends on custom clearance) 2nd intercooler coming middle of May with both black / silver units Total this month will be shipping about 85 intercoolers out - another 100 intercoolers next month. Here is a cool install video from our friends at Evolve Automotive in the UK from an install last week! |
recycledAlva290.00 |
05-02-2018, 11:50 AM | #107 |
756
Rep 504
You're not able to accept private messages - so I can't respond to you - please email me info@csfrace.com
05-02-2018, 03:21 PM | #108 | |
24171
Rep 190,750
Awesome news
05-03-2018, 10:07 AM | #109 |
Bright Sky
1164
Rep 922
The intercooler seems to be doing a good job of keeping things cool (BM3 Stage 2, Oct 91 - OAT 11.5C / 52.7F):
https://datazap.me/u/wjjkoevoets/boo...-12&zoom=1-347 https://datazap.me/u/wjjkoevoets/boo...2&zoom=100-558 Mods as in signature minus pure inlet.
BMW ///M235i (EBII) - BM3 (+TCU) - Wagner DP - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
05-03-2018, 12:16 PM | #110 |
24171
Rep 190,750
CSF intercoolers black and brushed back in stock
