M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > DIY: M Performance exhaust
      12-26-2017, 07:04 AM   #1
horsepower_and_hounds
Drives: BMW
So the first "major" mod I performed on the new M2 is the M Performance exhaust. Disclaimer......no way in hell I did it in 2 hrs like the paperwork says. I now see why the port puts out so many hack jobs.....
The skid.....yes a skid arrived undamaged from Sun Motorcars. I once again must mention.......Brian is the man for BMW parts hands down. The packaged arrived to him, he opened and inspected it to verify it was un-damaged the latest revision then added additional packaging to protect it then shipped it to me. Plus the pricing is unbeatable. Above an beyond period. He never fails to give impeccable service
It took me all day in the 37 deg temps to wire & install but I am very particular about stuff like routing cables evenly, shaping of heat shielding, sealing around plugs, etc. Plus I always measure twice, cut once. I also do it on my back like a hooker...... no lift
I put the car to sleep before installing the BT module and harness so did not unplug the battery terminal. Ran everything close to what the docs said but revised it to my liking. I struggled a bit with getting the pin in the one connector under the fuse block but finally got it after taking the connector out. The other wire already came with a connector attached. Took all the shielding out to run wires behind and installed the old flap dummy plug then stowed it up behind the cover exactly as the docs tell you.
I used a pipe cutter at the dimple marked location so the cut was straight..... fuck this piping is super thick, took a bit of work. Then I hit tooled the edges so the interface was nice and smooth.
Not an easy DIY for me but I hope since I did....there will not be some of the issues others had.
I saved the tips from the old M4 and re-used these to save money so I only had to buy the exhaust.
All and all the fit is almost spot on, might have to tinker with it slightly but really no complaints. I will update the post after i drive it and take a couple of daylight pics.....I have my break in service today
Appreciate 22
Alby_416114.50
Dirtboy197.00
emdeuce196.50
S1monQc223.50
HODLM363.50
bollinm25.00
Wilsm2187.50
qnet681.50
Poochie9104.50
gily88.50
963mw331.00
r121444.00
cncmastr1590.00
      12-26-2017, 11:37 AM   #2
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
Love it when people do DIY themselves. I hardly see this on BMW's forums. Good job!
2011 BMW M3 Sedan Alpine White
Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD**
      12-26-2017, 11:51 AM   #3
seetohey
Drives: 2018 M2 LBB, 6MT. Future: CTR
2018 BMW M2  [0.00]
Nice job on the DIY! Looks great
gsrbri559.50
      12-26-2017, 12:08 PM   #4
msingh637
Drives: 2019 JCW / 2018 M3
Great Job
      12-26-2017, 12:17 PM   #5
MR_M2
Drives: 2017 M2 6MT, 2022 X7 M50i
BMW M2  [0.00]
BMW X7 M50i  [0.00]
Very nice job! I would recommend turning off the ASD. Open valves + fake cabin noise was a bit too much for me.
Also, the side by side picture of OEM with MPE shows the latter is pretty much a straight pipe setup from BMW
S1monQc223.50
      12-26-2017, 01:00 PM   #6
Drives: BMW
Thanks everybody and yes ASD is off I found it worse on the F87 then I did on the F82
      12-30-2017, 08:04 AM   #7
beppeM3+123d
beppeM3+123d's Avatar
205
Drives: bmw m3 dct + 123d e81
Thank you for the post, can someone check if is possible to install with performance exhaust the Normal stainless steel tips. I personally think is crazy spend 800 euro for titanium or 1300/1400 for carbon...
      12-30-2017, 09:58 AM   #8
importriders
If you mean the stock tips I think they are a different diameter, so no. There are a few aftermarket tips that will fit the MPE that are much cheaper. See sponsor classified section.
      12-30-2017, 11:52 AM   #9
Bt12
Drives: 2018 X5,2018 m2, 2018 x1
Great job man!!! Did u do the Downpipe while u were under the car?
      12-30-2017, 04:43 PM   #10
Drives: BMW
No DP at this early stage, only 1300 mi and that would be an instant warranty flag
      12-30-2017, 05:45 PM   #11
NO_USER_
Drives: .
Good job man nice DIY! Not sure if you had jackstands on the front, but you shouldn’t rely on floor jacks to hold the car up (should only be used to raise the car). Stay safe! I have the same ///M flag on my garage wall too
      12-30-2017, 10:59 PM   #12
Rock Sweden
Rock Sweden's Avatar
Drives: 2016 M2
“... on my back like a hooker.” my wife can definitely relate.
      12-31-2017, 12:23 PM   #13
bravosvo
Drives: 2018 M2 6MT
Agreed. Good work dude!
      12-31-2017, 02:21 PM   #14
Drives: BMW
Yes not the safest way but best thing in place of a lift...... I don't like siting the alum suspension components on jack stands. I did the whole M4 this way..... I take it carefully and check the jacks often.....
      01-01-2018, 11:10 PM   #15
impulsiv
Cool. Will also be installing my MPE tomorrow
      01-02-2018, 01:36 AM   #16
ried
ried's Avatar
Drives: F31, F80
Excellent work!
      01-02-2018, 12:03 PM   #17
geogerf
geogerf's Avatar
116
Drives: MY17 LBB M2
2017 BMW M2  [0.00]
Nice garage!
      01-02-2018, 04:13 PM   #18
Drives: BMW
Thanks guys! This exhaust rocks and the BT communication has been consistent so far, has stayed open as far as i can tell. There is highway drone when flaps are open (i have asd off) but I don't really care. I have noticed the M2 transmits more exhaust vibration thru the chassis than the M4 did.... much more with the MPE but it has bark
      01-02-2018, 10:50 PM   #19
impulsiv
Did the install today. Where did you stuff the dummy connector? Any picture? The instruction I have are in german and there is no picture about that. (got a used exhaust + new hardware/remote kit)
      01-03-2018, 02:59 AM   #20
beppeM3+123d
205
Guys can someone explain why the ask to cut the exhaust to install mpe when seems made like this the oem?
      01-03-2018, 03:39 AM   #21
Drives: BMW
there is a whole dummy plug/routing doc:
https://bmweba.com/eba-01-29-2-412-923/
As for cutting, who knows why they design it that way. Maybe for ease & speed of install at the port? Who knows.......
      01-03-2018, 01:33 PM   #22
18EM2
Public Last Class
18EM2's Avatar
Drives: 2018 M2 DCT LBB
2018 BMW M2  [0.00]
Looks great. How much do you charge
