11-21-2017, 05:44 PM | #1 |
Rep 259
6MT Launch Control
Any tunes currently offer a 6MT Launch control feature? Example- set certain rpm limit/ antilag?
2013 MW E92 M3
2018 MG F87 M2 (Sold) 2016 YMB F80 M3 (Sold) Follow me on Instagram- @dtmpower98 |
11-24-2017, 01:07 PM | #2 |
Chuggin' Along
333
Rep 588
11-27-2017, 01:09 AM | #3 |
587
Rep 898
Eventually we値l probably get a 2step to build boost off launch. I知 sure once most of the mapping is ironed out we値l eventually get custom logic on the DME with BM3 like the N54 did after a little bit
11-27-2017, 03:29 PM | #4 |
Rep 549
Drives: The Bus
Left foot & right foot + a little talent.
11-29-2017, 01:11 PM | #5 | |
Chuggin' Along
333
Rep 588
If you install an 82mm turbo, then you might need 2step. |
11-30-2017, 10:22 PM | #6 |
Rep 5,369
Weird that the M2 doesn't have the same launch control feature as the M235. With the M235, you select Sport+ and at a stop, floor it, and the revs hang around 3500rpms. Admittedly it's not very effective for maximum acceleration. I'm far better with modulating the throttle myself.
12-05-2017, 10:40 AM | #7 | |
Chuggin' Along
333
Rep 588
12-14-2017, 08:07 PM | #9 |
Chuggin' Along
333
Rep 588
Really? That's so weird man. I never heard of a manual transmission BMW that had a rev limited launch control like you explained.
Maybe the M2 does the same thing. I've never even thought to try it. |
01-19-2018, 01:10 PM | #12 |
Rep 105
It will definitely happen when they map it out properly, just like flat foot shifting, cold start delete, and all the other goodies that are generally available in the tuning market. This is pretty standard stuff.
Also, its more than just beneficial for the massive turbos, it also just flat out results in better times. When all you have to do is floor it and release the clutch at the right time, it removes the extra movement to push the gas pedal. I know, it seems insignificant, but launch control and flat foot shifting is hands down faster for the vast majority of drivers that aren't launching their car every weekend at the strip to maintain muscle memory. |
cookiesowns587.00 |
