10-11-2017, 01:02 PM | #1 |
Rep 450
Traction Mode problems
I've had my LCI for about 3 weeks. The traction (MDM) mode is fantastic for the burbles and pops. I've noticed intermittently that after pushing the button there is no change in the exhaust character and it seems to stay in comfort mode. At first it happened once every few days but today I had to turn traction on and off 4-5 times to get it to make sexy sounds. The traction light comes on and idrive shows the change but no exhaust change. Anyone else run into this problem?
I've also noticed a lag in the 1500-2000 RPM range in traction mode where the engine seems to hesitate before picking up again. Not like turbo lag but like its cutting ignition or something. Not sure if this is related. No CEL or anything else. |
10-11-2017, 01:13 PM | #2 |
Rep 3,949
Traction mode puts the throttle in comfort. If you have a manual you will notice it more. You may also be feeling the traction control since it is still aggressive even in MDM mode.
10-11-2017, 01:15 PM | #3 | |
Rep 450
With the lag, its under light acceleration, <50% throttle application, so I don't think its wheelspin or TC kicking in. |
Maximoosh49.50 |
10-11-2017, 03:45 PM | #4 |
Rep 3,949
Mine does not do it all the time either. It's dependent on rpm and how quick you let off. Mine (17) has more exhaust noise in sport plus than just in MDM mode.
10-11-2017, 07:09 PM | #5 |
Rep 116
Firstly..
When you put it in MDM. It'll only make burbles and pops once the car is warmed up.. So if you put it in MDM on the cold start, it'll take a couple minutes of driving for the ECU to to make these over runs and burbles because one of the preliminary requirements is that the engine is warm enough (hits a specific temp.) All BMW are programmed to not burble over 5,000 RPM. Secondly, if you run it in MDM. Your throttle response is actually equivalent to sport.. Its more responsive than comfort but less than sports + Thirdly, the stock valve are pretty crap, all the exhaust sound the same pretty much. However, on sports+ I believe that over a specific RPM (I think 3,500) it is louder than comfort. But all else remains the same except comfort doesn't allow for engine braking. Hope this clears up your questions! |
10-11-2017, 07:47 PM | #6 | |
Rep 450
10-12-2017, 01:17 AM | #7 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
Is this actually verified truth? Comfort does something non-standard to prevent lift-throttle engine braking? (What does it do, open the intake valves a bit to prevent building vacuum?)
10-12-2017, 01:47 AM | #8 | |
Rep 116
So for example, on a standard manual, it'll wait till the engine speed is equivalent enough for you to downshift and instantly let out the clutch (aka to the point you shouldn't have been in that gear). Something similar to this. ECU Programmed. |
10-12-2017, 02:24 AM | #9 | |
I INDIC8
612
Rep 1,286
So if I'm cruising in 4th doing ~40mph, and I push the clutch and shift to 2nd, while the car is in Comfort... are you saying it does not rev up the throttle? If I then release the clutch, it somehow "holds" that clutch release until the revs have dropped on their own?
10-12-2017, 05:40 AM | #10 |
Rep 844
According to the technical chart, throttle response in MDM is in COMFORT and it does feel like it from personal experience.
4
10-12-2017, 02:39 PM | #11 |
Rep 6,635
AndrewC198910931.00 |
10-17-2017, 01:52 AM | #12 |
587
Rep 898
If the EGT is too high the car won’t burble. And it doesn’t always burble. My car burbles in MDM and I mean quite violently just roughly 1-2 minutes off cold start.
Sometimes if you put it directly into MDM on over run from comfort it’ll take another throttle application to get it to burble. Normal behavior. You can’t expect a DME to change it’s fueling map half way through... that would be interesting coding challenge. As for rev matching in comfort or MDM the rev match is much more tame so you have two options. Be slower on shift / timing of clutch engagement or blip the throttle yourself in addition or just go in sport or sport+. I usually drive in MDM and I still rev match myself when I need to. As for engine braking on comfort or sport. It’s definetly not as aggressive as in sport + but this is mainly for economy. Yes there’s still engine braking as in you’ll be slowing down. But even then all BmWs now don’t have 100% engine braking due to turbo setup as well as ECU tuning |
10-22-2017, 12:37 AM | #13 | |
I INDIC8
612
Rep 1,286
I did note that at very low revs (uner 2000 down to 1k) the braking effect does seem to be somewhat reduced, I haven't played enough to figure out if this changes between Sport and Comfort though.
10-22-2017, 06:54 PM | #14 | ||
Rep 4,551
Drives: 2015 328d xDrive
Yes it does...it's just delayed. Next time you downshift in comfort just wait a second before you drop the clutch and it will rev match. It's much slower than sport/sport + but it will do it. Last edited by AndrewC1989; 10-23-2017 at 04:47 PM.. |
NYC Bimmer259.50 |
01-12-2018, 03:57 PM | #16 | |
Rep 254
Turn it on by quick pressing the traction off button near your gear lever/shift knob. A long push of the button turns off all the nannies, "DSC Off" mode. Pops and burbles not as loud as traction mode. |
01-13-2018, 05:31 PM | #17 |
Rep 4,203
I bought the MPE and it cracks n pops alllllllll the time.
I am not sure when the stock flap even closed on my car. I think it was defective to tell you the truth. But a non issue now |
01-18-2018, 10:32 PM | #18 |
Rep 6
