01-26-2018, 07:04 PM | #89 |
Rep 6,635
01-27-2018, 09:31 AM | #91 |
Rep 69
I have 100% coded and think the dazzling/wash out effect is minimal. I'm fine with 100%. If I were going to do it again maybe I'd go 75%. But I don't care enough to change it unless I decide to change a bunch of codes in another session. Even then, I don't think I'll change mine
01-30-2018, 11:42 PM | #92 | |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
It requires the adaptive headlights, so if you have a 2018 and don't have the hex halos, it won't work for you. It makes the lights aim downward and to the side when you are driving at lower speeds. Should be 100% safe to other drivers though. You do NOT want to try to do NGHB (no-glare high beams) with NAR-spec lights, because that can glare oncoming traffic (specific feature in the headlights is missing from US/Canada lights that the rest-of-world lights have).
02-01-2018, 04:52 PM | #93 | |
Rep 960
02-02-2018, 04:39 PM | #94 |
Rep 1,925
Great thread. Coded off ASD last night.
Question: I saw a YT video to put the phone in airplane mode and leave the car running to prevent any interruption. Is that necessary?
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS |
02-02-2018, 06:10 PM | #95 |
Rep 4,203
02-05-2018, 05:39 PM | #97 |
Old Guy
25
Rep 89
Drives: 2018 M2 LCI, 2019 X3
? Any Help
02-05-2018, 08:09 PM | #98 | |
Rep 752
I guess just be cautious on the amount of times you code the FEM. I've been going back and forth with rev match on and off LOL....so I may need to choose one and forget about it. |
bollinm25.00 |
03-05-2018, 09:23 AM | #99 | |
Rep 630
Drives: 2021 G80 M3
Was actually quite fascinating to see the diagnostic equipment they use to determine module faults and how one failing can affect the others. For example, we saw how a short in the stability control module can make your wipers freak out (E90) |
rowzy14.00 |
03-05-2018, 09:24 AM | #100 |
Rep 630
Drives: 2021 G80 M3
And on that note, grabbed the latest E-SYS and files to code my 2018 last night:
Close windows and sunroof from keyfob Fold mirrors on lock Unlock door on engine onff Disable window roll-up door interrupt Enable brake-force flashing when driving 10+mph Illuminate exterior door handles in reverse DISABLE STUPID ACTIVE SOUND (no more drone in Sport+) Disable legal disclaimer on iDrive and backup camera (one less chime in the mornings) Re-code 5AP Variable Light Distribution Re-code 8S4 Anti-dazzle |
HandmadeShifts146.50 |
03-05-2018, 12:43 PM | #101 | |
Rep 136
Instagram: @handmadeshifts
03-05-2018, 08:39 PM | #102 | |
Rep 752
03-06-2018, 12:57 AM | #103 |
587
Rep 898
The FEM crash from what I've seen is recoverable with ESYS. That said, coding doesn't manipulate flash counters, most ECU/DME modules have a flash counter limit, that if not bypassed, once you hit the limit you won't be able to flash that module again.
Code away guys! I like the bimmercode for quick coding, but coding/flashing anything without a battery that is at least 80% topped off, or using a power supply is risky. Improper coding could temp brick your module, and without full PSDZ in ESYS you won't be able to recover.
03-22-2018, 10:54 PM | #105 |
Rep 650
Track codes
I coded out the TPMS so I can easily swap wheels/ tires for track days without going into reset/limp mode. Also changed to the Euro M mode to allow the car to be driven more aggressively when not in DSC off mode.
05-11-2018, 04:31 AM | #106 |
Rep 39
Just ordered my cable and got the Win7 VM up and running. Using this
https://www.bmwesys.com/guides/Begin...e%20Coding.pdf Seems my car was coded before I owned it, previous owner was BMW UK employee, i-drive disclaimer already off and digital mph already done. My first attempt will be folding mirrors on lock/unlock |
06-25-2021, 02:51 AM | #107 |
Rep 2
