08-17-2023, 11:13 AM | #69 |
Rep 589
08-17-2023, 11:38 AM | #70 |
Rep 3,703
It definitely maximizes all available space with not much room for variances. We mounted the e39 aux pump down that way, so had to change a cpl things for the oil line to connect spot on, but it’s on the car.
Corner balance, alignment, and track brake switch tomorrow, so hopefully set up for the track next week. Still have to open that day up for fun in my biz calendar. |
08-17-2023, 03:11 PM | #71 | |
Rep 427
Drives: F87 M2 DCT, F15 X5
ZM22827.50 |
09-19-2023, 05:23 PM | #73 | |
Rep 3,703
10-28-2023, 08:05 PM | #76 |
Rep 4,183
You need to use a M235i v Brace or cut yours and that would require the bumper to be removed I believe. Otherwise pug and play like anything else.
10-29-2023, 09:17 AM | #77 | |
Rep 589
front section thickness: 54mm front section height: 235mm rear lower section thickness: 198mm rear lower section height: 140mm width: 490mm (I measured the portion that air can travel through - not including the end tanks) I have photos if you want to check my math. Fin Density Comparison: MAD HD: 11/inch (estimated from photo) CSF: 13/inch VRSF (HD pack): 19/inch (per their post here) Last edited by M2guru; 10-29-2023 at 09:52 AM.. |
10-30-2023, 09:12 AM | #79 | |
Rep 4,183
Mods: Yes.
10-30-2023, 12:38 PM | #80 |
Rep 587
10-30-2023, 01:09 PM | #81 |
Rep 4,183
Technically speaking, the M2's brace has additional mounting to the chassis and is triangulated, meaning it should be stronger. I'm not an engineer, but this is what I've read up on chassis stiffing.
Also, chassis stiffening will not make you faster, or handle better objectively (Again, from my own research) but it can help with feedback and suspension geometry. The braces are as pictured below. M2 PN 51648054327 (#20) M235I PN 51647245789 (#4) You can see the ER intercooler comes with it's own brace as a replacement: https://f87.bimmerpost.com/forums/sh....php?t=1828191
Mods: Yes.
