Classifieds Section > Sponsors Classifieds > SPL TITANIUM Rear Toe Links BMW F8X M2 M3 M4 + Eccentric Lockout
      02-24-2023, 04:28 PM   #133
HP Autosport
Drives: F80 M3
bump
      03-14-2023, 08:13 PM   #134
HP Autosport
Drives: F80 M3
bump
      03-29-2023, 08:44 PM   #135
HP Autosport
Drives: F80 M3
bump
      04-13-2023, 11:20 AM   #136
HP Autosport
Drives: F80 M3
bump
      05-04-2023, 04:30 PM   #137
HP Autosport
Drives: F80 M3
SPL Titanium Series Adjustable Rear Toe Links BMW F8X M3 M4 with Eccentric Lockout Kit
SPL rear toe arms increase stability and response by eliminating bushing deflection while providing an increased range of rear toe adjustment, necessary for lowered cars or for performance alignments. Even small changes to ride height and camber will effect toe settings and the wide range of adjustment allows you to maximize grip on a track car and extend tire life on a street car. The factory rear toe arms utilize an eccentric bolt and washer for adjustment and lack the precision that SPL Parts rear toe links plus eccentric lockout washers offer. Our eccentric lockout washers ensure that your alignment will never slip like the factory eccentrics are known for under extreme loads. Black anodized and gundrilled 2024 Aluminum main links along with our 360 degree rotating clamp design allow for quick and precise adjustment.
Gundrilled 2024 Aluminum Links to reduce unsprung weight
6061 Aluminum Clamps and Heim Joint Spacers
Titanium Socket Head Cap Screws
Rotating clamp design allows for easy access to lock down your alignment settings
Low friction 3 piece Teflon lined FK Heim joints/rod ends made in Connecticut
6061 Aluminum Eccentric Lockout Washers
Grade 10.9 Hex Cap Bolts with Lock Nuts
Sold as a pair.
Made in the USA.
Applications:
2014+ F80 M3
2014+ F82 and F83 M4
2016+ F87 M2
      06-08-2023, 04:01 PM   #138
HP Autosport
Drives: F80 M3
bump
      10-20-2023, 07:24 PM   #139
HP Autosport
Drives: F80 M3
bump
      11-16-2023, 03:49 PM   #140
HP Autosport
Drives: F80 M3
bump
      11-30-2023, 11:05 AM   #141
HP Autosport
Drives: F80 M3
bump
      12-18-2023, 02:12 PM   #142
HP Autosport
Drives: F80 M3
bump
      01-06-2024, 01:41 PM   #143
HP Autosport
Drives: F80 M3
bump
      02-06-2024, 05:15 PM   #144
HP Autosport
Drives: F80 M3
Sold as a pair.
Made in the USA.
Applications:
2014+ F80 M3
2016+ F87 M2
      02-19-2024, 12:03 AM   #145
HP Autosport
Drives: F80 M3
bump
      03-13-2024, 12:12 PM   #146
HP Autosport
Drives: F80 M3
bump
      04-19-2024, 02:56 PM   #147
HP Autosport
Drives: F80 M3
bump
