03-05-2021, 11:29 AM | #155 |
Remove Before Flight
6869
Rep 1,615
I just got off the phone with a very nice Michelin rep and she confirmed that the MP4S in 285/30/19 will be released on 1 Apr 2020 with purchase availability around the last week of April/first week of May.
That might be a good choice and keep the front/rear stagger proportions similar to stock? Now, I've got to redo all of my tire research to decide on a 285 or 295 rear! R. |
03-05-2021, 07:09 PM | #156 | |
Rep 44
03-07-2021, 07:29 AM | #157 |
Rep 1,126
I just picked up a slightly used set of 275/295 Titan Ts-5 wheels and tires. I have stock suspension (thanks to Ohio roads), so I'll post some pics when I get them mounted.
05-20-2021, 05:10 AM | #158 |
Rep 1,074
Anyone know if running 255/35/19 front and 285/35/19 would be an issue. wanna go +1 front and +2 rear in sizes as i wanna keep the front still light and nimble. Will this adversly affect the cars handling not going to 265 fronts?
Instagram: M2_Medusa
05-20-2021, 07:34 AM | #159 | |
6638
Rep 4,145
Drives: '18 M2 6MT
The significantly wider tire in the rear will increase sideways grip, which will in turn induce more understeer for sure, but if you're not tracking the car you may not notice at all. I'd look very closely at the specs of the particular tire as well, as your rear tire will be much taller than your front tire (1.7" if you're using PS4S). That's going to increase your rake, which is only .5" from the factory. Also, the tire weight in the rear will be significantly more than the front (+7 lbs for the PS4S). And remember, depending on the tire you choose, and how the tires relate to each other, the issues can be exacerbated. Case in point. The 255/35 PS4S that a lot of guys buy is only .1 wider TW than the standard 245/35 PSS. But the 275/35 rear they pair with it is .4 wider, so they're actually adding more rear sideways grip than they think they are. This will be different for every tire and in every size, so as I said, look closely at it. |
06-08-2021, 10:50 PM | #160 | |
Rep 1
I dont understand when you say the rear is .4 wider, please can you explain, in both cases the width of the tire is increased by 10 Mill, or 1 cm, 245 to 255, and 265 to 275. That's 4 % larger F and R, the same, assuming PS4S everywhere. correct? |
06-09-2021, 06:22 AM | #161 | ||
6638
Rep 4,145
Drives: '18 M2 6MT
07-22-2021, 03:10 PM | #162 |
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
182
Rep 302
Great thread!
Looking for help ordering track day tires. Just picked up Titan TS-5 19x9.5 +27 and 19x10.5 +44 Will be lowered .5" front and .75" rear on Dinan HAS. Looking to fit 265/30/19 and 295/30/19. What options are out there? I don't see many track tires in those sizes...or is there a more common size? |
07-22-2021, 03:13 PM | #163 | |
182
Rep 302
at 9.8" vs 9.6" I would go with a 295/30 to get some "meat" out back with 11" TW. Bonus: Rake only increases by .2"... |
07-22-2021, 06:50 PM | #164 | |
6869
Rep 1,615
I went with a 255/35/19 & 275/35/19 combination instead. Somewhat of a compromise, but I felt that was the best for my situation, driving style and where I live.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
n8dgr84182.00 |
07-22-2021, 07:31 PM | #165 | |
Rep 1,759
n8dgr84182.00 |
09-07-2022, 03:39 PM | #166 |
Rep 1,358
I was looking for this thread, I want to mount 275 on the front axle and I was wondering if they don't rub, from what I see I can mount them without any problem on 9.5 rims.
09-07-2022, 07:50 PM | #167 |
Rep 1,368
09-08-2022, 12:12 AM | #168 |
Rep 1,358
09-08-2022, 06:26 AM | #169 |
Rep 3,354
265/35-19 up front? The diameter becomes the issue with those up front as I think many have tried them and found that to be the case. The 275/30-19 has a good bit smaller diameter but a greater section width, so rubbing comparisons between the two sizes up front might likely show up in different areas.
Current Stable:
09-08-2022, 08:02 AM | #170 | |
Rep 1,358
09-23-2022, 05:55 PM | #171 |
Rep 354
09-24-2022, 11:50 AM | #172 | |
Rep 1,358
Now 275/30, lowered around 28mm, don't rub: Wheels specs 19x9.5 et22 no spacers. Last edited by Track/S; 09-24-2022 at 02:32 PM.. |
05-06-2024, 09:09 AM | #175 |
Rep 1,426
old thread i know...but hoping someone can chime in and help. Im no expert like many of you and am quite honestly overwhelmed with wheel/tire choices.
Looking for some assistance with tires. Ive been runnning stock sizes and stock wheels since i bought the car. 2017 M2 lowered on Eibach. No camber plates. Just purchased Apex VS5-RS 19 x 9.5 +22 and 19 x 10.5 +45 Existing stock tires wont cut it with the crazy stretch. I like a much squarer look. I dont track. But drive spritely. I was thinking max 295/30 in rear and 275/30 in front. Semi confident with rears but thinking 275 may be too aggressive in front with my drop. I already get rare rub (on big dips) with my fronts, using 12mm spacers. Would appreciate any help...ive read through all these pages and my eyes are watering lol..TIA |
Yesterday, 09:18 AM | #176 | |
Rep 203
Apex fitment guide says that they recommend at least -2 degrees of camber up front: https://apexwheels.com/fitment-guide...-fitment-guide My friend was able to run 275/30/19s Falken RT660s on 19x9.5 +28 with HR springs, Bilstein B6 struts and OEM camber correction hubs that gave him -2 degrees of camber. Street tires such as Michelin PS4s will give more room than the RT660s which will decrease chances of rubbing. |
Dabozo627.50 |
