M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Active Sound Design (ASD) topics
      10-24-2016, 08:40 AM   #111
Pieman
Originally Posted by jimmy9980 View Post
I don't know if anyone has posted already but ASD can be turned off via coding too. Which is Free!
But coding leaves the ASD control box in the audio path so can still impact the sound quality, the loopback cable bypasses it completely.
      10-26-2016, 02:27 AM   #112
J.M
J.M's Avatar
Netherlands
264
Drives: '17 M2 DCT BSM
2017 BMW M2  [0.00]
I did it and noticed no difference in the sound system, which admittedly I do not use a lot. Still, check it out for yourself (I will be making a better video soon) but the ASD seems to be turned off almost entirely.
youtu.be/OubmtmwUsx8?t=106
PS: Sorry for reposting the video, I will make a better one as soon as I do the 2000kms service and can actually push the car.
      11-01-2016, 09:52 PM   #113
toastie
toastie's Avatar
Drives: e39 M5
When ordering the bypass harness, which audio system is for the 2017 model, model 676 or 674?
      11-03-2016, 04:42 PM   #114
sth519
sth519's Avatar
119
Drives: M135i → M2 → i4
676 = HiFi sound system
674 = Harman Kardon sound system ("Top HiFi")
      11-03-2016, 10:02 PM   #115
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2020 BMW X4M CS  [0.00]
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
Originally Posted by J.M View Post
I didn't try it before, you may be right.
It does 100%
And OP...I coded DVD in Motion...no speed limit..
Whoever coded it maybe made a mistake bc you do code @ what speed its disabled...Unless they locked that .dzt, i dunno...Let your coder know, or if you coded it, remember u have to activated step 1...step 2 determine what speed its diactivated and choose a high number where youll never go.
lmk findings.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3
J.M263.50
      11-03-2016, 10:23 PM   #116
jtfields
Drives: M2, X2 M35i, X6,328i,230i
"Start/stop memory" means that the start&stop state (on/off) remains the same when you turn your car off and then start it again.
I still don't know what this means.
Also, why does everyone code the door handle lights to come on in reverse?
      11-04-2016, 01:43 AM   #117
Joaozao
Joaozao's Avatar
189
Drives: 2017 M2
To see the curb while parallel parking in poorly lit areas
      11-04-2016, 04:26 AM   #118
J.M
J.M's Avatar
Netherlands
264
2017 BMW M2  [0.00]
Can't explain it any better than that... sorry but I think you are not trying hard enough because everyone else seems to get it.
As said "To see the curb while parallel parking in poorly lit areas" and also so that the car becomes more visible in parking lot manoeuvres.
Check out my M2 YouTube channel: The HyperCar Collective
      11-04-2016, 04:28 AM   #119
J.M
J.M's Avatar
Netherlands
264
2017 BMW M2  [0.00]
Originally Posted by DKM3Power View Post
It does 100%
lmk findings.
We did try it but entering the deactivation speed had very random behaviours. Seemed like BMW made it on purpose not to allow it. Mine is a August build MY2017. Yours? Might be different versions of something...
      11-04-2016, 07:48 AM   #120
hshot_rooke
123
Drives: 2017 BMW M2
Are you asking what Start/Stop is? Hopefully I'm not butchering this explanation, someone feel free to correct me:
Start/Stop seems to now be on most modern day vehicles. I believe car manufacturers are using it as a means to save fuel.
Have you noticed cars that have stopped at a light/stop sign that it sounds like it turns over again and the ignition fires up like as if they had just started the car? That's start/stop. Basically turns the engine off when you're idling at a light/stop sign. Then it will restart the engine when you give it some gas.
You can turn this off in the car so it doesn't do that, but the next time you drive your car, you have to turn it off again every time.
Basically the coding tells the car to remember your last setting for it ON or OFF.
      11-04-2016, 08:06 AM   #121
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
This doesn't apply to North American cars, let me explain. Above the ignition button there is another smaller button to turn off the automatic engine deactivation (a.k.a. the start-stop) that turns off the engine when idling at say a stop sign or red light.
For US/Canada cars, once you press that button, the car remembers your setting and it will remain that way until you change it again - i.e. once it's off, it stays off until you press it again. This has something to do with NHTSA requirements for start-stop systems.
In most other international markets, once you press that button, the car will remember it for that one time, and will reset once you turn off the car. When you turn the car back on, you have to press it again. For 99% of M2 buyers, this is a huge PITA, as I presume most of us aren't using the feature.
So that is why most people code it, but we in NA don't have to worry about it.
      11-04-2016, 08:09 AM   #122
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
In the US the setting sticks. In other markets you have to reselect the on every start.
      11-04-2016, 08:31 AM   #123
J.M
J.M's Avatar
Netherlands
264
2017 BMW M2  [0.00]
Originally Posted by omasou View Post
I don't hear a difference. Maybe in person it's noticeable?
Quite noticeable in person. I'll try to shoot a video with better sound.
      11-04-2016, 10:13 AM   #124
jtfields
I am familiar with it. Both my 328i and M2 already remember the last setting so I was assuming he was referring to something else. Maybe only the US cars remember by default?
2017 M2 (LBB 6MT Exec Pkg MPE) My Way Too Wordy TL;DR M2 Timeline
      11-04-2016, 10:16 AM   #125
J.M
J.M's Avatar
Netherlands
264
2017 BMW M2  [0.00]
Maybe it only the US cars remember by default?
Could be, yes. Emissions regulations in the EU are the devil.
      11-04-2016, 10:17 AM   #126
jtfields
Okay, that makes sense. Never thought of that.
      11-04-2016, 10:23 AM   #127
jtfields
Thanks, I should have read your post before I replied to the last one. I'm thinking of getting my car coded so I'm interested in these threads to see what my options are and what other people are doing. I know there's a very lengthy thread with spreadsheets and all that I need to dive into at some point. Until I started reading these forums, I didn't know coding was a thing. Now I'm thinking of getting all three of my Bimmers coded if only just to get rid of the nagging iDrive warning confirmation screen on start.
Anyway, sorry to hijack the thread. I realize it is supposed to be about ASD.
      11-04-2016, 10:25 AM   #128
Joaozao
Joaozao's Avatar
189
Drives: 2017 M2
I had it coded but didn't think about that until I saw your post hahaha.
      11-04-2016, 10:27 AM   #129
J.M
J.M's Avatar
Netherlands
264
2017 BMW M2  [0.00]
Offtopic: You're called Joćo?
      11-04-2016, 11:54 AM   #130
gmzanatta
gmzanatta's Avatar
1823
Offtopic: You're called Joćo?Joaozao
Saw that too, was wondering if it's a fellow Brazilian transposed up north.
ry_h0.00
      11-04-2016, 12:33 PM   #131
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
My ASD was only noticable when installed a 2400w 12" Sub lol...Jesus christ
      11-04-2016, 05:09 PM   #132
Joaozao
Joaozao's Avatar
189
Drives: 2017 M2
Yes but I'm Portuguese
