01-07-2024, 07:15 PM | #133 | |
Rep 249
Car is running strong with 530-540whp, peak 23-24psi, but it's having misfire CEL near Redline, above 6.3k rpms. My tuner checked everything and all parameters in logs are looking perfect. plenty more of hpfp angle, the B58 coil system is running strong and the turbo is healthy with 85%-90% wastegate duty cycle. He played with rail pressure/injector advanced SOI table and gained me a bit more RPMs but we all agree that it's not healthy to overwork stock injectors. They are rated 2900psi and just can't flow enough in the short injection window at high rpm causing misfire code and getting diagnosed to the ignition system often. I found your build journal very helpful mentioning the injector limit for DI only with Emix cuz most of the data out there are running PI or meth. Upgrading M5 EU5 soon as the tuner suggested. I'm going to see how N55+ turbo can do next. Cheers |
-Eidos493.50 |
01-07-2024, 08:00 PM | #134 | |
Rep 871
Drives: OG M2
01-07-2024, 08:58 PM | #136 |
Rep 871
Drives: OG M2
Damn actually? I'm currently installing a PS2 but might switch to N55+ if I can't live with the lag on it lol
01-07-2024, 09:13 PM | #137 | |
Rep 249
https://www.bootmod3.net/log?id=6590...18c420ef7e253b https://www.bootmod3.net/log?id=651b...729bf4e4bd14a5 this is stock turbo multimap, same fuel. If WOT started around 2-2.5k, probably 700rpm to hit the target boost, from 3k usually 500rpm. If you see the engine rpm, It always has slippering during boost. If tyres are not warm enough or road condition is not good enough, the car would slip until 6k. Last edited by ericlr1225; 01-07-2024 at 09:21 PM.. |
01-07-2024, 09:31 PM | #138 | |
Rep 871
Drives: OG M2
01-07-2024, 09:35 PM | #139 | |
Rep 249
This is how it looks by turning it up a bit. I think eventually my tune will end up like this, boost ramping up after 4k and all the way up to 7k. Keeping boost within 24-25psi range and wastegate at 90%. I dunno what PS2 can do but it's not bad for a $1100 turbo. |
01-08-2024, 12:23 PM | #140 | |
@lbb_kev
494
Rep 515
Please update us with a dyno graph once you sort out the fueling bottlenecks
ericlr1225136.50 |
01-08-2024, 04:03 PM | #141 | |
Rep 871
Drives: OG M2
01-17-2024, 07:31 PM | #143 |
Rep 249
Revision #17 for Flexfuel map, E52 in tank, 13.5degree timing at 6500rpm, DS2, stock LPFP, EU5, CTS intake, etc.
01-19-2024, 09:13 AM | #144 |
Rep 315
01-19-2024, 12:49 PM | #145 |
Rep 249
Nope, it's gone when EU5s in. Tested with the same map on the same day. Me and the tuner were sure it was the EU6 injectors limit causing it.
Posted the reason #133. Our single HPFP can't push injectors as hard as S55 dual HPFP but you still can raise the pressure to compensate for the flow. Plus you need to adjust injection advance timing to open the injection window as much as you can. It's a tricky job. If it's not done correctly, exhaust could shoot much fuel from the exhaust directly and lost power. I told my tuner I don't wanna mess with those parameters and try to stick with OEM settings. You can turn on "HPFP angle final(KW)" in your log. 105 is the maximum effort of Dorch stage 2. Mine only hits 86ish maximum running E50. Plenty of room for the pump. It will help you know your HPFP limit and diagnosing things Last edited by ericlr1225; 01-19-2024 at 01:01 PM.. |
01-19-2024, 05:55 PM | #146 | |
Rep 315
interesting, your tuner used to tune my car. Couldn’t figure the misfire/hesitation at 6500 for the longest. Switched to full dorche setup. liftkit, injectors etc….Glad the solution was found |
ericlr1225136.50 |
01-19-2024, 07:25 PM | #147 |
Rep 249
Yeah, the first thing is to make sure plugs/coils are new and setup correctly. I have B58 coils and DS2 already, tried stock gap and 0.024'' as he suggested, and Misfires above 6.3-6.5k still. Then playing around with injection SOI, and raised up hpfp pressure from 2900 to 3300psi, it got better but still randomly happened at the very top or 4th gear very top.(I like to pull until 7.1k. Damn OCD. LOL) Everything else looked perfect. Then he said there was no need to gap down more. Method of exclusion. Also, I did some research on the S55 forum and @Eidos's post confirmed it, those guys pushed the s55 injector by 3600-3900psi on the E85 tune. That's why S55 injectors failed so often, it's way over operation pressure. Bosch engineer also confirmed with Kratos turbo that the s55 injectors failure has nothing to do with E85, just simply mechanic failure. Double confirmed with David Shoup. Now everything is good. BTW, during the whole process, I refused to change anything else except the fueling/Injection table and When EU5s were in, we reset the fueling/injection table back to the original to minimize variances. Same timing/boost/Emix during the whole process.
VGSON220.50 |
01-19-2024, 07:44 PM | #148 |
Rep 315
first thing i did was b58 conversation and f8s plugs trying to fix it. then came the liftkit, injectors, & lpfp..Now running straight pump ethanol and looking forward to 25+psi
ericlr1225136.50 |
01-19-2024, 08:01 PM | #149 |
Rep 249
Yeah, I hate to change things randomly. Shooting darts in the dark. Misfire happened when boost was turned above 23-24psi with my small turbo. Below that, free revving all day. Since you’re pure750 and DI only setup, you need all those anyway. Not bad. 😄
VGSON220.50 |
01-20-2024, 05:05 AM | #150 |
Rep 585
I appreciate your discussion on the forum here - you guys have helpful experiences to share!
Are you guys experiencing any clutch slippage yet? Wondering the stock clutch will take. When I get the car hot on the road course, I experienced some slipping upon acceleration with Stage 2 on stock turbo non-ethanol. Some extra heat is being generated by my imperfect heal-toe shifting, so I have that working against me. Thanks! |
01-20-2024, 06:10 PM | #152 | |
Rep 249
