BMW M2 Forum > BMW M2 Discussions > How accurate are the values in ODB Fusion logs?
      01-23-2024, 02:23 PM   #1
2018Aloy
Drives: 2018 M2 sapphire black
2018 BMW M2  [8.08]
Hi, I'm new here. Sometimes I log the "spirited" drives, and I see values in ODB Fusion that are higher than expected. My local tuner states that those values are not accurately calculated, but I'm under impression that ODB Fusion simply logs ECU data, doesn't "interpret". Any clarity would be appreciated!
example: my 2018 M2 Stage 1 shows peak values of 461.9 HP/ 375 lbs of torque @ 6478 rpm in fourth gear. seems a bit over the top for a Stage 1 tune, Wagner EVO2 FMIC, CTS intake.
      01-27-2024, 02:44 PM   #2
jefe2000
jefe2000's Avatar
Drives: 2018 M2 6MT
2018 BMW M2  [10.00]
IIRC, the stock tune has a time-limited overboost up to 369 lb-ft of torque. I’m not sure how the stock tune compares to Stage 1 tunes.
      01-28-2024, 01:18 PM   #3
2018Aloy
2018 BMW M2  [8.08]
I didn't log the car when it was stock, so perhaps it should've been a place to start. Currently I see the max values of torque logged at 412 lbs. (The log provided is Stage 1, Sports +) thanks for your reply
