BMW M2 Forum > BMW M2 Discussions > how good are these motors? how many miles can they go without rebuild?
      01-12-2024, 07:29 AM   #1
Topcarbon
Drives: 2022 m4
I am considering a 2018 M2.
There are some mild modifications like downpipes and cold air intake. No tunes or crazy Frankenstein build.
It has a considerable amount of miles(70,000).
Anything to look for or be concerned about?
thanks in advance for your responses
      01-12-2024, 07:38 AM   #2
Topcarbon
Drives: 2022 m4
I know I will need to marry this car for life and go into the purchase as if the money is a sunk cost
opinions welcome
      01-12-2024, 07:48 AM   #3
Topcarbon
Drives: 2022 m4
and remus exhaust
      01-12-2024, 09:08 AM   #4
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
It's not the mileage that would concern me, as the N55 will last 200K without issue if you keep up on the maintenance.
The thing that would concern me is all the mods. Hope he has all the stock parts...
omasou2088.00
      01-12-2024, 09:30 AM   #5
Topcarbon
Drives: 2022 m4
So even mild mods like downpipes and exhaust are a no no
      01-12-2024, 09:35 AM   #6
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Down pipe and exhaust should have zero effect on the life of the engine.
Appreciate 4
chris7197334.00
///MPhatic13862.50
Topcarbon1307.00
      01-12-2024, 11:13 AM   #7
David1
David1's Avatar
Drives: 09 E92 09 X5
The only real engine problems across the entire BMW engine family is rod bearings. The standard N55 motors are eating them up but no reports of this with the N55 in the M2.
Topcarbon1307.00
      01-12-2024, 11:44 AM   #8
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Most every M2 owned by an enthusiast will have either a catted or catless downpipe, and these pose no danger to the engine. An exhaust is stupid expensive for the M2, especially something like Remus, and causes no harm either. My comments were just about how much stuff has been changed on the car.
DanG10660.50
Topcarbon1307.00
      01-12-2024, 03:55 PM   #9
TheHaze
Drives: '18 M2
The N55 engine has been around for a long time and seems to be reasonably reliable, as long as you're keeping up with all maintenance items and watching out for fluid leaks (OFHG, oil pan, etc.). Do you have any info on the car's service history?
A modified car wouldn't necessarily scare me away, but it would be nice to have a comprehensive list of what all has been done to it. The Remus is a big plus in my eyes as I think it's a fantastic sounding exhaust. I've had their system on my car for years and it never gets old to me.
Topcarbon1307.00
      01-12-2024, 04:54 PM   #10
Topcarbon
Drives: 2022 m4
thank you for all the responses
serviced annually at the dealership, and oil changed every 7000 km.
what about clutch fluid, and tranny fluid?
this has a dual clutch, no? don't those last forever?
      01-12-2024, 06:35 PM   #11
F87source
F87source's Avatar
Drives: Bmw M2
flush clutch fluid with the brake fluid - because they share the same master cylinder. This is for the manual only.
Transmission fluid should be done probably every 4 years 50k km at most. With the DCT it is alot more complex, you have to flush the fluid, change 2 filters, the jet pump and the sump (if you keep the plastic one, unless you're able to buy a seal elsewhere - i think there were resellers online).
DCT's do not last forever, eventually those clutch packs will wear out and that's going to be insanely expensive unfortunately.
Topcarbon1307.00
      01-14-2024, 10:48 AM   #12
dtmurf
dtmurf's Avatar
482
1996 BMW 318is  [4.75]
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
I would not be overly concerned with the mods but I'd really want to know if it had any track time.
70K isn't excessive, that's about 12k a year, if it was a daily however, if it was tracked, what percentage of the 70K is track mileage as that's where the engine will have been worked the hardest so tracked once or twice, no big deal, tracked ever other weekend...nope!
'17 M2 DCT Long Beach Blue
      01-14-2024, 11:08 AM   #13
Topcarbon
Drives: 2022 m4
The miles reported from the seller are
Mostly highway miles. No track usage
      01-14-2024, 10:44 PM   #14
Brokenbones
Drives: M2c and S2000
As for buying a track car, you’re really buying the owner. Did they keep up with maintenance, was the car properly warmed up and cooled? Running a car hard isn’t necessarily bad, as long as it was tucked away nicely afterwards. I’d almost be more wary of super low mileage cars, not the m2 age but more in the 10+ year old range… what kind of dried out rubber ticking time bombs are there waiting for me?
      01-15-2024, 01:18 AM   #15
bmwstephen
Drives: 95' M3, 17' M2
Steve Dinan has always said that M engines throughout his experience is 125k miles, it is ready for a rebuild as piston skirts, seals, and bearings are typically worn down by from spec. So if you are dealing with increasing oil consumption and lower compression, its one of those components warned down (if not all). It is the "M" tax for having more exotic metallurgy for low friction, revy motors.
Having said that, the last time I checked with him at Carbahn, the two motors he touts as being the most "reliable" M built engines that would go beyond 250k on stock power without having to open it up, are a) the US version's e36 s50/s52 and b) f87 n55 because they have more traditional components iron cylinder walls, cast pistons, and skirts which significantly better wear and thermal cycles; therefore extending life.
      01-15-2024, 04:43 AM   #16
Topcarbon
Drives: 2022 m4
the owner of the car is also the owner of a modification business. he uses this car as a show car. most miles are highway miles.
the upkeep and maintenance is regular and frequent.
      01-15-2024, 10:24 AM   #17
///MPhatic
The Seeker
///MPhatic's Avatar
13863
I don't buy that. Honda has no problem building an engine that's just as powerful and technological as BMW, they're just consistently more reliable. I think this 100% comes down to tolerance. The Japanese companies are known for sacrificing ultimate power for reliability through tolerance, and BMW just won't do it. To them, the engine, like the first owner, is a transient thing. BMW's general philosophy is one of impermanence.
      01-15-2024, 10:41 AM   #18
bmwstephen
Well thats the thing. The s50/s52 and f87 n55 does have higher tolerance.
I have an e36 m3 approaching 140k still on original bearings, headgasket, doesn’t burn oil, and compression within spec because they use less exotic components and conservative power levels.
My previous s65 was already burning a quart of oil when daily driving under 60k miles because of lower tolerance (obviously with the more exotic materials) and high strung. Sold it before needing a rod bearing job.
The f87 n55 is the opposite and is built better and in some respects more so than the s55. It can probably take on another 100hp/ft tq but you sacrifice reliability and decrease tolerance. Only thing is the heat soak that was subsequently solved in the s55 cooling system.
      01-15-2024, 02:42 PM   #19
chris719
Drives: '08 M Roadster
Nope.
