BMW M2 Forum > BMW M2 Discussions > cheap winter wheels solution
      12-03-2023, 04:36 PM   #1
chatcher
Drives: C6 ZR1 and E92
Wondering if anyone has some options for affordable oem wheels I can swap on my M2 for winter storage. I would like to put the summer tires inside for the winter and would prefer a beater set i can leave the car sit on and be mobile enough to drive a mile or two if ness rather than putting up on jackstands for the season. Thanks in advance for any help.
      12-03-2023, 06:56 PM   #2
chatcher
Here is a set of wheels I am considering any thoughts?
https://www.facebook.com/marketplace...66445564166465
      12-07-2023, 08:34 AM   #3
wjones14
wjones14's Avatar
659
Drives: 2021 M2C
Personally, I would just overinflate the summer tires, park it, and forget it. Why would you need to drive a mile or two, assuming you have another vehicle for the winter? I inflated the tires to 40 lbs. in my M235i when I used to store it and didn't touch it until spring. Unless you're going to take it out for a drive long enough to heat the oil up to temp (20 minutes), it's best to not even start it.
As far as those wheels, if the mismatched rim doesn't bother you, they look okay if your plan is to occasionally drive the car.
You should be able to find other deals in the M2/M3/M4 forums. I found a 641M winter tire/wheel package from an M3 owner for $1300. The wheels were the same 19x8.5 and 19x9 sizes made for the M2 winter package, but the M3 package came with 255/35-19 tires instead of the 235 tires in the M2 package. I'm on my 3rd winter with them and no rubbing issues.
Vehicles: 2021 Alpine White M2C 6MT; 2011 Kawasaki Z1000 (1/4 mile 10.3 seconds @ 129 mph - stock)
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT
      12-07-2023, 08:38 AM   #4
wjones14
wjones14's Avatar
659
Drives: 2021 M2C
641M pic
      12-18-2023, 08:15 PM   #5
chatcher
It's not about driving it. Its more about getting the summer tires into heated storage while the car is stored in freezing temps I have seen a few sets similar to yours but I was hoping to find something on the cheap because i just need it to sit on them. But it appears as though most won't clear the brakes I'm most likely hoping to find a set of oem M2 wheels with crap tires. I have zero interest in driving it in the winter.
      12-18-2023, 11:21 PM   #6
dtmurf
dtmurf's Avatar
482
1996 BMW 318is  [4.75]
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
For a little more money, you could pick up a Quick Jack! You could lift the car on the quick jack and remove the wheels for heated storage (I'd put a jack stand on each side of the the quick jack for additional security that the hydraulics don't leak down). Without wheels, the car will be secure as it can be moved or driven away and you'll have a quick jack for doing maintenance in the summer time!
'17 M2 DCT Long Beach Blue
      12-19-2023, 05:43 PM   #7
chatcher
This is probably not a bad idea for most in my situation however my needs are a little different than just storage per say. I hate to let on to how much of a first world problem this is and it will probably come off as some sort of internet flex but I have a two post and a four post already a quick jack is just not needed. My problem is car placement. Right now the M2 is where I'd like another car to be sitting and then I can move another car where that one is now. In order to do that I would like to have the summer tires remain in the warmer garage where the car currently is. with a cheap set of disposable-ish wheels I could move the M2 to my other garage which isn't heated and it would be a tight squeeze once in place to get it up on jack stands or even switcth the wheels in place which is why I'd like to be able to drive it a bit with the junk wheels on it.
dtmurf481.50
      12-19-2023, 08:59 PM   #8
philth
philth's Avatar
199
Drives: F87 N55
Just find a used set off a 2/3/4 series on facebook marketplace or where-ever local to you.
If you don’t care about looks and won’t be driving it anywhere, just look for a used/take-off set.
‘BMW Rims’ into the search and away you go. Just make sure they’ll clear the calipers.
      12-21-2023, 11:47 PM   #9
dtmurf
dtmurf's Avatar
482
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
This is probably not a bad idea for most in my situation however my needs are a little different than just storage per say. I hate to let on to how much of a first world problem this is and it will probably come off as some sort of internet flex but I have a two post and a four post already a quick jack is just not needed. My problem is car placement. Right now the M2 is where I'd like another car to be sitting and then I can move another car where that one is now. In order to do that I would like to have the summer tires remain in the warmer garage where the car currently is. with a cheap set of disposable-ish wheels I could move the M2 to my other garage which isn't heated and it would be a tight squeeze once in place to get it up on jack stands or even switch the wheels in place which is why I'd like to be able to drive it a bit with the junk wheels on it.
Nothing wrong with having first world problems!
      01-14-2024, 12:29 PM   #10
chatcher
641M pic
I ended up finding a used set of these local!!
philth198.50
      01-14-2024, 01:16 PM   #11
mtoosexy
mtoosexy's Avatar
730
Drives: It like I stole It.
Need first world problem advice!
I currently have a 3.5 (fairly deep) garage, wife and kids have 1/2, my cars and yard equipment have the other 1/2.
Should I build a detached garage or purchase 2 lifts? The lifts would be cheaper, but man would it be nice to have my OWN 2 car garage that could be locked and not have a zero-turn mower or kids sledding toys in the same space.
P car or AND M2>
      01-14-2024, 09:48 PM   #12
chatcher
If you can swing it more garage is always better IMHO
Here's a pic of the little one I put in my back yard
mtoosexy730.00
mssVT98141.50
