10-06-2016, 08:41 PM | #155 |
1991
Rep 6,916
M Performance Alcantara/Carbon Fiber Interior - 5 pieces - installed
Well not exactly just 2 pieces out of the 5. I'm not all that much a fan of our "dry/matte" carbon fiber interior trim, I knew that BMW made some the Alcantara Carbon Fiber Interior Kit. So I pulled the trigger picked up the 5 piece set for the two pieces. The two pieces that I needed Take a look Before Trim above the glove box Open the glove box door and pull the trim off - use a pry tool if necessary. Removed After Before Driver's side dash vent very easy to install about a 5 minute install just a quick pull pull the ac vent out from the bottom pop it out and replace it with the new piece (sorry no photo) |
10-12-2016, 09:26 PM | #156 |
1991
Rep 6,916
more interior trim pieces -
installing the IND F87 M2 Alcantara Custom Stitched Armrest stock and Ind's side by side close up install pop the vent out with a pry tool, then disconnect the vent control and 12v. vent and trim piece removed push these pins out installed interior shot |
BAN_M2C4178.00 |
10-13-2016, 07:31 PM | #158 | |
Rep 362
10-14-2016, 07:02 AM | #159 |
1991
Rep 6,916
10-14-2016, 10:44 AM | #160 |
Rep 362
10-14-2016, 01:13 PM | #161 |
Rep 905
Nice job Phil!
10-31-2016, 09:25 PM | #165 |
Rep 214
Hmmmm when do you expect to have the Akra delivered and installed by? I need to come stop by anyways and check the shop out my buddy Aiman from Park Ave told me about you. I picked up my M2 LBB DCT Exec from Paul miller my good friend is a SA there and he also recommended to check your place out cause I'm 15k miles in and need a nice cleaning lol.
I also definitely want to hear the Akra in real life and check out the other mods you've done. Much better seeing them in person to help make my decision easier between MPE, Akra, and Meisterschaft. All the other stuff I'll probably just get from M Performance like steering wheel and all the cosmetic stuff. Hope I can stop by soon I may shoot you a PM. I'm located 10 min from the Garden state plaza. Thanks Phil! Also......unbelievable work you've done to this beauty. Can't wait to see what else you do man. Great job 👊🙌 |
10-31-2016, 09:50 PM | #166 | |
1991
Rep 6,916
11-09-2016, 07:35 PM | #167 |
1991
Rep 6,916
Got some pics from the unwrapping of the Akrapovic
A quick description from the Akra site. Made from ultra-lightweight high-grade titanium, which will lower the overall weight of the car and improve handling. This perfectly finished ECE-approved system has been tuned to get the most from the TwinPower Turbo six-cylinder engine of the M2 and is designed to deliver more power all the way across the rev range. This new system features two separate tubes from the downpipe to the muffler – unlike the car’s original single-tube configuration. It is perfectly routed and shaped to provide optimum gas flow from the M2’s stunning engine and deliver a noticeable performance increase. The sound has also been enhanced by Akrapovič’s engineers; the unique external sound is higher in pitch, giving a true racing feel in the upper rpm range. The Evolution Line is perfect for everyday use, with low-rpm driving smooth and refined, but still showing the true potential of the system – and, when higher revs are hit and the valves are permanently open, the sound has an addictive racing tone. A simple plug-and-play system offers a superb addition to improve the performance of the BMW M2. Carbon-fibre tailpipes give an added look to the rear of the M2, to display its sporting potential. Performance can be further increased with the addition of the optional downpipes, which can be purchased with or without cats. To set off the system to its visual best, optional parts are also available. --------------- I'm already excited with Akra with such extreme attention to detail in just the packaging alone. Quality! |
BAN_M2C4178.00 |
11-09-2016, 08:32 PM | #168 |
Resident Engineer
135
Rep 748
Get that beast on!
(Thanks again for the Rupes )
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD 2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air European Delivery Journal & F8X Door Rattle Fix Machine Shop Directory - www.mfgcenter.com |
11-10-2016, 06:11 AM | #170 |
Rep 214
Damnnnn that akra got me jelly now. Holy shit you are Not kidding about the attention to details man. That's absolutely beautiful. Congrats can't wait to see it on. I just can't get myself to spend that kind of money on just that one piece alone. Although it does seem like it's worth it if you have the liquidity which god bless you do. Congrats man!!!!
11-10-2016, 07:45 AM | #172 |
1991
Rep 6,916
Up next the Eventuri Intake Installation
Pick one up at IND - the team is amazing! Eventuri Intake for the BMW M2 |
11-10-2016, 02:56 PM | #173 |
1991
Rep 6,916
Here is pic heavy install of the Eventuri Carbon Fiber Intake for the F87 M2.
Picked this up from the team at IND. Popped the hood only to find it a bit dusty and full of leaves so I decided to clean up the motor first. Products used to do the engine clean up Kranzle 1122TST Cold Water Pressure Washer Kwazar Venus Pro Super Foamer Wheel Woolies 20 inch Black Boar's Hair Brush Adam's Polishes All Purpose Cleaner Sonax Plastic Care - Exterior and interior dressing Metro Air Force Blaster 8 hp Hit the motor up with some Adam's All Purpose Cleaner Agitate the dust and grime All clear to rinse it down A quick blow dry while the motor was running will ensure good drying times Used the Sonax Plastic Care to dress up the engine bay Nice and clean and ready for my next step. Unpacking the Eventuri Carbon Fiber Air Intake. Great packing to ensure nothing is broken in transit Lots of stuffing and everything was organized well - packing slip. Opened it up and it was Christmas! Who doesn't love carbon fiber! Detailed photos of the parts Of course being a bit OCD I went ahead and polished it out and coated it with Nanolex SI3D HD Rupes Ibrid Short Neck Adam’s Paint Finishing Polish Nanolex EX Nanolex SI3D HD - Pro Use Only Uber All Purpose Microfiber Towels Now to the good stuff Actual instructions for this install are here - Eventuri Carbon Fiber Intake Installation for the BMW M2 I bought mine at IND - Click here to purchase the Eventuri Carbon Fiber Intake for the BMW M2 Last edited by Detailers Domain; 11-10-2016 at 03:47 PM.. |
4
11-10-2016, 05:37 PM | #175 |
Rep 154
Intake looks beautiful. Have you thought about adding the M3/4 Cf strut brace?
http://www.babybmw.net/forum/viewtop...710096a1ec1bf5 |
11-10-2016, 09:36 PM | #176 | |
1991
Rep 6,916
Joaozao188.50 |
Tags |
bbs fir, bmw m2, detailersdomain, nanolex, xpel |
