03-07-2022, 01:49 PM | #331 |
Rep 203
I am running a Hotchkis FSB set at 2nd to softest. Ladders and slaloms are a staples here in the PNW due to the venue sizes (mostly old, narrow airfields). The FSB helps keep the rear in check during hard transitions which is good. The trade off though is the understeer in the two turnarounds/ sweepers we have in every event. I'm still on stock suspension so I'm exploring rear shocks to help solve for the understeer.
03-08-2022, 10:28 AM | #332 | |
Rep 74
I took out a bunch of rear toe just before nats to try and get the rear involved but the car was not predictable and had a lot less traction (from 0.19deg to 1/16" total, annoying conversion) I bumped it up to 0.17degrees total car toe for the GA tour this week. Hope it's better now or I'll still be slow |
AlpinewhiteM2C126.50 |
03-27-2022, 09:53 AM | #335 |
Rep 203
I have experience between a 265/35/19 Bridgestone RE71 vs 275/30/19 RT660s in the front. The 275 RT660s felt better as far as turn in crispness and front end grip. If I had to choose between 265/35 vs 275/30 (same manufacturer), I'd opt for the 275/30. The very competitive drivers in my region runs the 275/30 fronts which is pretty compelling anecdotal data.
03-27-2022, 12:02 PM | #336 | |
Rep 3,361
Current Stable:
03-27-2022, 01:40 PM | #337 |
Rep 178
Camber hubs, lots of pushing and pulling when installing shocks to focus on front camber and I was able to achieve 2.0 drivers side, 2.1 passenger side with me in the car. Problem we ran into is with the passenger rear. Anything over 1.8 camber would not allow enough toe adjustment to toe that side in. Drivers rear did not exhibit this behavior. Anyone run into this before?
03-28-2022, 08:28 AM | #339 |
Rep 178
Last year I ran 275/30 F with both 275/35 and 275/30 rears. The car was hateful and did not want to put power down. Based on my experience, the 660s are not really a good tire. Yes the 275/30 works well for the front, untill it heat cycles out, however it is simply not enough tire for the rear of a m2c. I would go with the larger 305 if the 660 is your choice. Lastly, good luck in damp/wet conditions are the tires are just about useless then lol.
CSBM52756.00 AlpinewhiteM2C126.50 |
03-28-2022, 09:55 AM | #340 |
Rep 3,361
Kind of sounds like A052s in 255/35-19 and 275/35-19 might be a better option than the RT660s? (i.e. M2C so forced to use 19")
Current Stable:
03-28-2022, 10:28 AM | #341 | |
Rep 32
03-28-2022, 10:31 AM | #343 |
Rep 178
What is really strange is that this is only on the passenger side rear, the driver's rear doesn't appear to have this issue and at -1.9 camber we could get almost .5 toe in just on that side, where as -1.8 on the passenger side would only result in .06 toe in maxed out (which is what I run per side)
03-28-2022, 10:33 AM | #344 |
Rep 3,361
Tires? I don't see the 295/35-18 for RT660 nor a 275/30-19 for the A052.
Current Stable:
03-28-2022, 10:38 AM | #346 |
Rep 3,361
Ah, wow, cool. Looking forward to how that works out!
Current Stable:
04-01-2022, 05:10 AM | #347 |
Rep 685
I would stay away from running two separate compounds F/R. You want stability under load to maximize mid corner speed, which this setup will not yield.
04-02-2022, 10:36 AM | #348 | |
Rep 203
04-02-2022, 10:40 AM | #349 |
Rep 203
I'm liking this set up quite a bit after a few test and tunes and initial SCCA events. The RT660s will just not fire up when the temps are low (mid 40s to low 50s) we are experiencing wheather wise in the PNW. The A052s starts to work well after first run. Only negative is the accelerated tire wear in the fronts compared to 660s.
CSBM52756.00 |
04-02-2022, 05:33 PM | #350 |
Rep 178
Looks pretty stable to me lol. Stock front bar, heavy slalom transition based course. Car is ON THE MONEY....and it was complete dog shit last year.
04-05-2022, 09:34 AM | #351 | |
Rep 74
04-05-2022, 10:05 AM | #352 |
Rep 178
