12-06-2020, 05:20 PM | #1 |
Rep 35
M2 OEM + PE Hybrid Exhaust
Here's my idea to modify the OEM M2 Exhaust to M2 MPE. The goal is to keep the exhaust nice and quiet but also have the ability to loud. The yellow circles are the OEM exhaust valve.
M2 Hybrid exhaust, HOW IT WORKS?: when it's in comfort/eco modem, the valves remained closed, exhaust soundwaves and gases go through the muffler. When it's switched to Sport / Sport+ mode, the valves open up, exhaust soundwaves and gases go through the muffler and outer tips, a straight piped design just like the MPE. Do you think this is a good design to accomplish the goal that's mentioned above? Are the valves located at the right location (Closer to the Y pipe? Closer to the tips?) THE LAST GRAPH IS A M2 OEM MUFFLER THAT'S BEEN MODIFIED WITH TWO EXTRA PIPES AND A VALVE Last edited by joshua12334; 12-06-2020 at 07:12 PM.. |
12-06-2020, 05:48 PM | #2 |
Rep 570
There's a number of issues with this solution. Unless you have the MPE already, it's a huge waste of money.
Even if you do have the MPE, the routing of the hybrid doesn't make much sense. 1. The valves should be much closer to the split to prevent pressurizing the closed branches and causing back pressure with the valves closed. Second, you can't just plumb a line into a random spot on the muffler. the current entrances are on the sides, you might get really unfavorable effect by welding a pipe into a different spot. |
AndrewC198910931.00 NYC Bimmer259.50 |
12-06-2020, 06:12 PM | #3 |
Rep 4,551
Drives: 2015 328d xDrive
This seems like a pretty complicated way of achieving that. Why make a custom exhaust when there are already so many good established options on the market that are designed the exact same way? If price is an issue just go to the classifieds section or ebay and buy one second-hand. Or if that's too expensive buy a used sport cat and a valve controller. Way less work and really not that expensive all things considered.
NYC Bimmer259.50 |
12-06-2020, 06:18 PM | #4 | |
Rep 35
There isnt any new pipe getting installed on the muffler. That's the OEM pie going into the muffler on the OEM Muffler. Two new pipe goes to the outer tips. Just like the MPE |
12-06-2020, 06:21 PM | #5 | |
Rep 35
12-06-2020, 06:44 PM | #6 |
Rep 570
Sell the MPE (if you already have it, or just don't buy it) and you will be able to build custom exhaust that does what you want for a fraction of the cost.
If you actually want to do this here is my suggestion (I have designed and run multiple fully custom exhausts built with off the shelf parts, and designed them for friends): Go for 3.5 in piping back from the stock down pipe. Run an 18inch 3.5 in and out cherry bomb glasspack in the center of the car. These are straight through "mufflers" that really are fantastic resonators. Split your 3.5 in piping at a Y just behind the rear axle. Both exits to the Y should also be 3.5 in pipes. On one end of the Y, put your stock exhaust valve. That should run directly to dual tips at the rear left of the bumper. The other end of the Y should run to a Magnaflow 5"x8" 3.5 inlet straight through muffler (or OEM muffler if you want it quieter, but this is a bad idea because you would have to reroute the exit and ruin the flow) that ends at dual tips to the rear right. That will cost you about $500 bucks to build, $750 max. You'll end up with exactly what you want. |
12-06-2020, 06:46 PM | #7 |
Rep 570
Ah, you didn't label that as the OEM muffler on the pic. You're going to spend about $2000 bucks too much with this design.
12-06-2020, 06:48 PM | #8 | |
Rep 4,551
Super quiet with valves shut in comfort and loud as all hell when they're open in sport+. $4000 for everything brand new. I'm sure you could get it all used for ~$2000. |
NYC Bimmer259.50 |
12-07-2020, 03:11 AM | #9 | ||
Rep 425
I find the N55 MPE in comfort with ASD delete with valves closed is quieter than stock in comfort - but there is obviously 3k rpm drone with the MPE. |
DroneandDone94.00 |
