12-06-2020, 11:29 AM | #1 |
Rep 72
Stage 2 N55
Hey everyone, I plan on going stage 2 on my N55 (93 octane only) and plan on using Bootmod3 , if you have other suggestions please let me know!! Anyways I was going to run
BMS intake VRSF downpipe and fmic and chargepipe Not sure which spark plugs to run? Is there anything else I should have? Diverter valve? Turbo inlet? new to bmw tuning so sorry if these are noob questions , thanks for your time ! |
12-06-2020, 11:32 AM | #2 |
6637
Rep 4,145
Drives: '18 M2 6MT
Stage 2 only requires an upgraded IC, but the charge pipe is smart, as is the DP.
The only thing I'd say is to definitely check your logs after doing the 93 tune, as some guys have reported not quite getting 93 at the pump, and some timing being pulled. I'm a set-it and forget-it type of guy, so I'll be doing the upgrades, but flash the 91 tune for safety reasons. |
12-06-2020, 11:34 AM | #3 | |
Rep 72
12-06-2020, 11:36 AM | #4 |
6637
Rep 4,145
Drives: '18 M2 6MT
Yeah, that's exactly right.
Most guys will just check their logs. I can't be bothered. Another few hp isn't going to make or break me. I'd rather have the extra security. At some point I'll get a custom tune just for the sake of having it. |
12-07-2020, 08:12 PM | #5 | |
Rep 1,644
12-07-2020, 09:26 PM | #6 | |
6637
Rep 4,145
Drives: '18 M2 6MT
But in any case, the OP is running a VRSF DP. |
12-08-2020, 06:19 AM | #7 | |
Rep 1,644
AmuroRay2282.50 |
12-08-2020, 08:09 AM | #9 | |
Rep 1,899
anything from 300CPI and below are considered high flow downpipes for the N55. |
12-08-2020, 08:42 AM | #10 | |
24198
Rep 190,807
use the 1 step colder NGK
12-08-2020, 10:43 AM | #11 | |
6637
Rep 4,145
Drives: '18 M2 6MT
Which is every aftermarket DP available for the N55. So they're basically saying anything other than the stock DP. Got it. |
Poochie9104.50 |
12-08-2020, 02:43 PM | #12 | |
Rep 1,644
For the downpipe, no one is going to be selling an aftermarket one that, at minimum, doesn't have a hi flow cat. That would be pointless and if you did buy one you got scammed. |
AmuroRay2282.50 |
12-10-2020, 01:42 AM | #13 |
Rep 201
What Mike said. Turbo inlet and diverter valve help. The stock diverter valve has been known to leak some boost so upgrading that will help mitigate some of those issues. The turbo inlet pipe upgrade is similar to the charge pipe upgrade, it can crack, and the fitting to the turbo can get loose.
12-14-2020, 07:39 AM | #14 | |
Rep 449
VisualEcho6636.50 |
12-14-2020, 06:15 PM | #15 | |
6637
Rep 4,145
Drives: '18 M2 6MT
Hold on there partner. Intercoolers and catalytic converters aren't nearly the same thing. You're applying the idea of one part to a completely different part. Beyond that, most everyone knows the stock intercooler leaves much to be desired. It's not a must-have for a stock car, but it's definitely a good thing to have. It's really the weak link, which is why it's required for Stage 2. Last edited by VisualEcho; 12-15-2020 at 03:40 PM.. |
12-15-2020, 02:48 AM | #16 | |
Rep 4,516
I upgraded turbo inlet pipe to remove the restriction due to the oem inlet ID where it mates to the turbo is smaller than the port to the std turbo comp wheel. Better flow at inlet means faster spool and turbo's wastegate duty cycle is less for same/similar levels of boost. BP
Current '22 X3M LCI.. |
