M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Measurements of full stock OG M2 exhaust system
      11-16-2020, 08:21 PM   #1
BMWF87Melb
Drives: VW Golf
Hi all,
Would someone have the length measurements of the stock og M2 exhaust system?
I've yet to remove mine from my car - but I'm looking at transport options to get my stock system from the workshop back home.
I've done a guesstimate that the exhaust length is around 3.3 meters from lining up a tape measure from outside of the car, but it's really a guess as I'm not sure where the exhaust would be cut as I'm getting an MPE installed.
Would be great if someone had these dimensions handy to share! If anyone has the weight as well, that would be handy too. Thanks!
      11-16-2020, 08:43 PM   #2
Matt Devo
Recovering RS4 owner
Drives: 2017 M2
2017 BMW M2  [0.00]
~130" / 330 cm
not sure you'd need to cut anything to install a MPE exhaust, it replaces the entire length
      11-16-2020, 08:52 PM   #3
BMWF87Melb
Drives: VW Golf
Originally Posted by Matt Devo View Post
~130" / 330 cm
Cools thanks - much appreciated.
Looks like my rough estimate was a spot on
Happen to know the weight of the stock system?
      11-16-2020, 10:50 PM   #4
Mosely
Mosely's Avatar
594
Drives: '18 M2 | '20 X5 | '07 E92
~130" / 330 cm
MPE requires you cut the stock exhaust just in front of the resonator. Then you use a slip joint to connect MPE to the cut pipe. It's a bitch to do. Took me an hour with a brand new pipe cutter. There is a dimple where you're supposed to cut.
OP if you need the cut measurement I can get it for you tomorrow
IG Photo Gallery:
instagram.com/dr_m2sko/
      11-16-2020, 11:15 PM   #5
BMWF87Melb
Drives: VW Golf
~130" / 330 cm
Thanks - the cut exhaust measurement would be much appreciated to assist with my transport.
