11-18-2017, 12:47 PM | #1 |
Rep 32
Time for some upgrades
Hi all,
Owner of an M2 MG with some performance goodies for 2 months. Car is used as daily driving for short distance. I am thinking to take some mods to personalise the car although is already unique with the M Performance exhaust, carbon fiber diffuser, M Performance winglets, full suntek PPF, M Performance lines etc. As the car is under BMW warranty I would like to take mods that it can be reversed in case an issue happens. I am thinking as first mod to upgrade the wheels either with FF04 in 20" in Eureka or Sarsparilla. I have some concerns about the wheel color due to M Performance lines. Any advice is more than welcome. I plan to keep my OEM wheels to use for track days as an M2 is useless only for daily driving car. As a second mod I am thinking for the Jabspeed catted DP in order to use with M Performance exhaust and a free flow air filter in OEM air box. As the car is under warranty I do not plan to perform ECU upgrade. Finally I consider to lower the car with springs only but I have serious concerns as it is used as DD. Any advice or recommendations is more than welcome. Cheers, Nick. |
11-18-2017, 01:22 PM | #2 |
Rep 3,402
All of your mods will be warranty friendly except the downpipe, if your going to pass on an ECU tune I would also forgo the downpipe because your not going to get much of anything out of it except the risk of dealing with a potential warranty issue. There are a few guys here who have had problems triggered by DPs and had to scramble as a result. On lowering the car, I would think long and hard on that one and if you can see if you can get a ride in a car lowered by springs alone. I currently hit my curb going into my driveway if I come in at the wrong angle at a stock height so that and ride quality would be my concerns.
Let us know what you decide to do and best of luck |
11-18-2017, 02:03 PM | #3 |
Rep 105
Hey Nick!
Seems we think pretty much the same things when it comes to modding the M2! Wheels: I bought HRE FF15 in 20” for my MG M2 in IPA and love them. I posted pictures of them in the wheels and tires section in the HRE thread on this Forum. As you asked about the stripes and your colour choices... Well I think Sarsaparilla and Eureka both would not correspond very well with M colours i’m afraid. Maybe you buy the colour of your choice and decide afterwards if it is time to get rid of the stripes... I also thought about lowering the car with either the m performance coilovers or the KW thread springs. I asked people about the springs and they told me they switched to the whole coilovers because of the poor ride quality. Others however seem to be fine with them. I forgot the idea because I have 20” wheels and with 20@ and these springs i am almost sure the ride quality will be significant lower than now and i don’t want the car’s original ride quality to be lost. Coilovers I dropped because of the fact that I am one of the few who thinks that the car needs only a few mm dropping. I am however totally fine if it stays on this height. Also I discovered it can be a technical problem if you get the m performance coilovers and lower the car only about 5-10mm because then some parts would not be covered from the dust saving part of the damper, i don’t know how to explain it in English sorry. I have the m performance exhaust and have already bought the Akrapovic 300cell DP and will install it in Spring. I heard a car with that combination and must say that it sounds awesome how it cracks and pops! In fact sounds so addictive that i will be fine if it damages the Turbo over time but I don’t think that it will happen. What else could go wrong? Edit: where do you live? Last edited by Egress; 11-18-2017 at 02:08 PM.. |
11-18-2017, 02:37 PM | #4 | |
Rep 329
bobert858.50 |
11-18-2017, 04:33 PM | #5 |
Rep 32
Hello,
Thank you for the feedback so far. I did not know that a catted DP can cause problems that can void BMW warranty. Which are actually these problems? If there is any link I would appreciate to share with me in order to understand. The M Performance color lines is quite difficult to be removed as the car is fully wrapped with Suntek PPF. In order to remove the lines I have to seriously adapt PPF which means extra cost. Last but not least I believe an M2 driving only 15 Kms per day is not used at all for what it deserves. Before the M2 I was owner of a BMW 430I M Performance and I have to say that M2 is awesome car. I believe cars like M series should spend some time monthly on truck otherwise someone can purchase a normal sports daily car. I realise that tunning in M cars is a big challenge as there is highly possibility the result to be worst than OEM. |
11-18-2017, 05:27 PM | #6 |
Rep 229
11-18-2017, 06:43 PM | #7 |
Rep 4,203
A DP is a flag for a dealer to look further. Most that run a DP will run other mods. Just say'n. Not sure a warranty can be voided due to a DP but may trigger them to look around. Even if you brought it in for just a oil change and they do a std scope as they always do and you have a dash light or error code they will see it.
If you run a piggy back like a JB4 and you post high boost or mix fuel and register high fuel trims and have a mechanical issue the warranty will be void cuz they ill see it in the DME data. Remember you can get flagged all day long but you have to have a major problem for them to go to BMWNA with your DME data other than that you should be fine....... But if you play...be prepared tp pay |
11-18-2017, 09:16 PM | #8 | |
Rep 329
I really have no intention of tracking the car on a regular basis, as I don't see this as necessary justification for owning one. To me the M2 qualifies as a normal sports daily car. YMMV |
