11-09-2017, 09:49 PM | #1 |
Rep 2,577
At this point there has been no confirmation yet of the possibility of LCI instrument cluster swap for Pre LCIs.
But I noticed this: our Pre LCI instrument cluster looks much better (at least to me) when turning into red & white two tone. Below are the comparison pictures two tone vs. full red. The pictures don't do it justice IMO. Any way possible thru coding we can replace full-red with two-tone when in dark?
Lemania 2320
11-09-2017, 11:42 PM | #3 |
Rep 2,577
I'm not 100% sure but it seems to show when ambient lighting isn't too strong (which turn it off completely) and isn't too dark (which turns on full red) either.
Lemania 2320
11-10-2017, 06:57 AM | #5 |
Rep 2,577
Forgive me I am a car noob... what is " lights on at dusk but the headlight beams are off". Picture, picture..please thanks
Lemania 2320
11-10-2017, 07:01 AM | #6 | |
Rep 2,948
1) When it's dusk but still light enough out, they turn on but aren't projecting a long beam (first setting on the headlight switch, two small headlight symbols) 2) When it gets dark enough they turn on fully and start projecting the low beam (second setting on headlight switch, one large headlight symbol with beam pointing down) If you're sitting in your car, go through the setting in the headlight selector switch and you'll see as they change. |
11-10-2017, 11:45 AM | #7 | |
Rep 2,577
Yeah, now I get you, you were explaining when it shows what. But i was trying to find a way of completely replacing full red with red/white
Lemania 2320
11-10-2017, 11:59 AM | #8 | ||
Rep 2,948
11-12-2017, 10:07 AM | #9 |
Rep 134
Drives: BMW M2 Coupé (BSM)
funny... at launch everyone was raging about that white needle on an M car vs all red on the sister M3/4 :P
11-12-2017, 10:45 AM | #10 |
Dinosaur supervisor
3027
Rep 4,214
No confirmation?
There are a lot of swaps made already. Works just fine. |
AndrewC198910903.50 |
11-12-2017, 11:48 PM | #11 |
Rep 1,466
One thing that I don't think anyone has commented on yet, is that the LCI cluster looks a bit silly in direct sunlight. It's now autumn, and low direct sun is common here in California at this time of year.
The LCI cluster is a well lit traditional cluster behind a tinted front panel, which sort of looks like it's floating out of nothing normally. In direct sunlight however, you can see through the tinted cover, and see the needles and the shadows created by the fake shaping of the front cover etc. Doesn't look that good at all to me; the pre-LCI probably looks a lot better in this situation.
2018 ///M2 LCI, LBB, 6MT...
geogerf115.50 |
11-15-2017, 08:02 PM | #12 |
Rep 2,577
Needle doesn't have to be white
Lemania 2320
11-15-2017, 08:06 PM | #13 | |
Rep 2,577
Though I think I pre LCI two tone cluster would be best if it's possible thru coding.
Lemania 2320
11-16-2017, 11:43 AM | #14 |
Rep 1,027
SeanWRT
You can actually solder white smd's on the speedo anywhere you want (speedo, rpm, fuel) There's a few DIY's for the old 1 series that showed this Also found a guy in the UK that did these conversions and had some pictures posted up It doesn't sound really hard tbh but have never soldered so idk |
11-16-2017, 07:58 PM | #15 | |
Rep 2,577
Coding or LCI swap would be preferred options so far, though that leave it as is isn't unacceptable either.
Lemania 2320
11-17-2017, 12:42 AM | #16 | |
Dinosaur supervisor
3027
Rep 4,214
They post a new one every week. |
