BMW M2 Forum > BMW M2 Discussions > Drove in ICE storm
      01-11-2017, 03:11 PM   #1
Aronis
Aronis's Avatar
2272
Drives: 2018 M5
Drove in ICE storm
We had a bit of an icy day yesterday. When I left work to head home I found that we had been having icy rain all afternoon and the ground was coated in Ice. The roads (secondaries) were fairly icy.
1. My Car was encased in ICE. - my frameless front doors opened without a problem.
2. The roads were coated in ICE. - my M2 had no problem handling the icy roads due to snow tires.
3. If i deliberately tried to get the tires to spin, the tires did so but the car stayed straight and I had no problems getting home up our very icy hill (about 2.5 miles of driving up hill (about 1200 feet of elevation)).
So, frameless windows, not a problem. Winter driving, not a problem.
Get over it......drive.
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
Appreciate 8
      01-11-2017, 03:18 PM   #2
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
I'm glad you survived the ICE.
      01-11-2017, 03:18 PM   #3
cbpdpm
Drives: 2022 M4 Comp Xdrive Conv
Same for me this AM in PA with dedicated Scottzero snow tires.
      01-11-2017, 04:00 PM   #4
QM
Drives: 2020 M2CS 6MT
Same here with Michelin Xice3. The M2 is very competent in snow and ice with the winter tires.
      01-11-2017, 04:43 PM   #5
Bluedoor
Bluedoor's Avatar
63
Drives: 2017 M2
Beauty of a balanced car is that it is built to be balanced always. Congrats!!
      01-11-2017, 05:24 PM   #6
mike@x-ph.com
mike@x-ph.com's Avatar
+1
https://x-ph.com/sale/
Phone number 702-494-9435
      01-11-2017, 05:55 PM   #7
atxsk8r
atxsk8r's Avatar
Drives: 2020M2C
Good to hear you made it home safe in the ice.
When i left work yesterday, i had to drive home in the 70s and sunny weather, it was a rough one
Appreciate 5
6734202180.50
F87LUV3689.00
DCM278.00
Aronis2271.50
      01-11-2017, 06:17 PM   #8
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
Yes! Don't fear winter, your car will be just fine
(Taken after 25cm (10") of snow came down while at work)
Appreciate 6
6734202180.50
Robin_NL8717.00
kvndvs59.00
      01-11-2017, 06:19 PM   #9
6734202
Drives: MG 6MT
Woah. Even my Jeep was a little sketch in 8-10" of snow. That's crazy, especially with how little ground clearance the M2 has!
      01-11-2017, 08:51 PM   #10
F87LUV
F87LUV's Avatar
Drives: '16 M2, '23 GT4
2023 Porsche GT4  [5.00]
2016 BMW M2  [8.66]
I have 19" blizzaks and my car was all over the road with barely any acceleration. Forget the 300 feet downhill- it was sliding with almost zero throttle. I had them on my z4 and 350z and it was never as sketchy as these. I'm going to sell the winter setup and go with something entirely different next winter. This was through fresh snow and ice later on.
IG: Trackinheels
      01-11-2017, 11:27 PM   #11
BMWSRT
Drives: BMW X5
Looks like less than five inches....snow is below splitter, ground clearance is 4.8 inches on M2.
      01-12-2017, 12:19 AM   #12
ried
ried's Avatar
Drives: F31, F80
Damn, that's a lot of ICE.
      01-12-2017, 12:22 AM   #13
Gatte
Gatte's Avatar
1193
Drives: anything with 4 wheels.
Just do this. You'll be golden.
      01-12-2017, 12:44 AM   #14
highspeed
Drives: E91 335xi, M2 (ordered)
We should bridge a gap in the aftermarket with that
      01-12-2017, 06:00 AM   #15
Bluedoor
Bluedoor's Avatar
63
Drives: 2017 M2
Problem is most //M winter sets are based around performance snow tires. I found as soon as I focused on true snow and ice tire with a smaller rim that I got very good results. Nokian Hakkapeliitta R2 snows which are amazing. (Hardest names to remember). Definitely softer ride and taller sidewalls are spongy but in New York roads are filled with gravel and sand as often as snow and ice...the is no performance driving until Spring. Also, I enjoy the sharp distinction of my summer tires when Spring comes. Nokian isn't sold through TireRack which is unfortunate because I'm a huge supporter of them.
      01-12-2017, 06:14 AM   #16
gmzanatta
gmzanatta's Avatar
1823
Have you ever heard of a plow?
No car or truck can get through 10" of snow comfortably, so the roads get plowed 2 or 3 times during the day.
F87LUV3689.00
SoCalRob281.00
      01-12-2017, 07:56 AM   #17
F87LUV
F87LUV's Avatar
2016 BMW M2  [8.66]
I thought I was doing the same by getting blizzaks over the alpins. I'll definitely drop down to 18" and reconsider the tires going on it next winter.
IG: Trackinheels
Robin_NL8717.00
      01-12-2017, 08:22 AM   #18
gmzanatta
gmzanatta's Avatar
1823
I'm running the 18" Alpins and so far they have been great. Kinda meh on fluffy loose snow, but great on everything else - in particular, I was impressed with the performance on ice, way above my expectations.
      01-12-2017, 08:27 AM   #19
LinkF1
Drives: 16' MG F87 M2
Which Blizzaks did you go with?
There is a significant difference in deep snow and ice traction between the LM-32 and the WS-80.
      01-12-2017, 08:52 AM   #20
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
I really recommend Michelin Pilot Alpins 640M square 235 18
or 235 18front and 255/35 18 at the back. Supersporty and grippy/traction for a wintertyre(even on dry/wet roads)
If I had to drive with them 24/7/365 I would do that, they are SO good!
@gmzanatta has the same setup on the pic above.
Cheers
Robin
F87LUV3689.00
      01-12-2017, 10:22 AM   #21
IS+1
Drives: 2017 M2 (AW 6MT)
What brand and size(s) of snow tire are you running?
      01-12-2017, 10:41 AM   #22
allthatisntnow
allthatisntnow's Avatar
377
Drives: BMW M2C, 991 C2
Its refreshing to have an M2 thread about the ice on the hood instead of the ICE under it.
