01-11-2021, 08:31 AM | #1 |
Rep 4,381
How Red Bull screwed Albon?
Its interesting to compare the maximum speeds at each track for the 2020 season for Albon and Verstappen.
The number of times that Verstappen had a higher maximum speed than Albon was 1 single race and that was a gap of 0.1 kph. In every other race Albon had the higher maximum speed, as much as 29 kph. No wonder then that Albon struggled all year with a much lower downforce setting than that given to Verstappen? |
01-11-2021, 08:46 AM | #2 |
Rep 3,004
Great thread Senor!
Why, it just must be a coincidence that ALB's racer was significantly faster (terminal velocity) than VER....I jest, of course. One could state that the RBR "braintrust" simply set up both racers with different strategies to "cover all bases" in their team management to hopefully achieve optimum race results. One could state ALB's racer was hobbled by design (aero setup) to prevent a better outcome against his teammate.... Ensuring VER always had the better setup that achieved better results. Your acute observation(s) will be telling when you post the terminal velocity trap speeds of PER and VER.
Racerbruce
01-11-2021, 10:19 AM | #3 |
Rep 2,665
Your theory is RB purposely handicapped Alban? For what purpose? He scored less than half the points and came in 7th compared to 3rd, not even close.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
M5Rick60093.00 ///M Power-Belgium63392.50 |
01-11-2021, 10:39 AM | #5 |
General
60093
Rep 19,569
David701567.00 ///M Power-Belgium63392.50 |
01-11-2021, 10:41 AM | #6 | |
Rep 4,381
Assuming that Verstappen is given the optimum set up in terms of downforce vrs top speed for any given track and the optimum pit stop strategy in terms of tyre type and number of stops....then why give a (what is by definition a sub optimum) different strategy to your second driver...especially when a lower downforce set up must surely make the car harder to drive? By comparison the Mercedes drivers had a smaller delta in top speeds and almost always the same tyres and pit stop strategy. Also interesting is that Verstappen and Hamiltons maximum trap speeds were much closer but with Verstappens max speeds being higher 2/3 of the time. |
racerbruce3853.50 |
01-11-2021, 10:47 AM | #7 | |
Rep 2,665
If Verstappen had the fastest trap speed you would have said he had the better setup or engine settings and this was the cause of Albon doing poorly?
01-11-2021, 11:52 AM | #8 | |
Rep 4,381
Why give your second driver a significantly different (harder to drive) set up and tyre/pit stop strategy at every race (bar 1 or 2)? |
01-11-2021, 12:26 PM | #9 |
Rep 1,823
From a vehicle dynamics point of view, lower down force = less darag on the car. Less drag = greater acceleration at same engine power. Greater acceleration = greater top speed by the end of the straight. So not surprising.
Corner speed, and exit speed will be slower with lower downforce though.
2017 BMW M2 German Spec
MKSixer34184.50 |
01-11-2021, 05:57 PM | #10 |
Rep 2,099
I think Albon is more about "hopes up and dashed quickly" sorta like Gasly. Perform or go back down. Red Bull is known for their brutal truth in success desires. They saw an option and they went for it. Not sure I see the different setups as an intentional block.
I think the good thing you see about them is those two were still kept within the relative stable and were found roles. |
01-11-2021, 07:44 PM | #11 |
34185
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
If your objective is to use one driver as test bed for the other, it's perfectly logical. And, of course, that's never happened in F1. Nope. Not at all.
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
racerbruce3853.50 SenorFunkyPants2510.50 |
01-12-2021, 07:30 AM | #12 |
Rep 2,665
For all we know they tried both setups with Alban and the one he ended up with gave him the best lap time. We have no idea if his laptime would have been better with more downforce. Just speculation.
01-12-2021, 01:56 PM | #13 | |
Rep 910
Every good conspiracy theory has to have a few supporting facts, I struggle to see a single one in the theory that Red Bull deliberately screwed Albon, because no-one would buy the line that RBRH did it unintentionally and through incompetence. Every driver will have slightly different set-up preferences to their team mate, some minor and some major, downforce is just one of them. Last edited by MJE60; 01-12-2021 at 03:15 PM.. |
David701567.00 |
01-12-2021, 02:10 PM | #14 | |
Rep 4,381
Why not simply give him the same set up as Verstappen as it was already proving pretty successful. But no they gave him an already pointy car (that was not to his taste) and made it even harder for him to drive by considerably reducing its downforce. Not for a couple of races to see it was to his taste but for pretty much every race in the season. Surely they could have tried him out with Verstappens set up for a few races..rather than watch him under perform race after race after race. |
MKSixer34184.50 |
01-12-2021, 02:27 PM | #15 | |
34185
Rep 11,637
fiveohwblow3633.00 |
01-12-2021, 02:39 PM | #16 | ||
Rep 2,665
MJE60678.00 |
01-12-2021, 02:43 PM | #17 |
Rep 2,665
Every driver wants to beat their teammate, they are the one that is most closely matched in equipment and the best way to judge a driver on his ability.
01-12-2021, 03:00 PM | #18 | |
Rep 910
01-12-2021, 03:09 PM | #19 |
Rep 910
Absolutely correct and this, no doubt, is what put incredible pressure on both Alex and Pierre. Both drivers have talent but being a team mate to either Max or Lewis takes a certain mental stamina. I cannot wait to see the dynamics with Sergio Perez.
01-12-2021, 03:10 PM | #20 | |
General
63393
Rep 24,680
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
01-12-2021, 03:16 PM | #21 | |
Rep 2,099
BTW, found it interesting to see more of the drama of past years in the Netflix show. Cant wait to see the behind-the-press action for this past year. That said, I usually watch replays in spare time, so maybe I missed the drama live :P |
01-12-2021, 03:17 PM | #22 | |
General
60093
Rep 19,569
MJE60678.00 ///M Power-Belgium63392.50 |
