M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2 dyno'd with Dinan Sport tuner
      03-06-2017, 11:13 AM   #67
Fabspeed Motorsport
Fabspeed Motorsport's Avatar
Drives: BMW M235i
Originally Posted by Mbavar2 View Post
Thanks! I've been reading some have been doing the manual M2 in 5th gear as well. Do you know what the gear ratios are? Wonder which one is closest to 1:1
Thanks!
Off the top of my head, I do not know what the ratios are. My technicians have found the closest to 1:1 to be in 4th gear though.
      03-06-2017, 12:36 PM   #68
NOLAGUY
Drives: LBB M2
5th gear in auto or manual is 1:1 for the M2
FSociety3812.50
      03-06-2017, 02:05 PM   #69
TheKosherStogie
TheKosherStogie's Avatar
Drives: 08 M3 DCT AW/Red
http://rennlist.com/forums/991-gt3-g...-on-m2-11.html
I'm confused. Isn't this saying the opposite.
"Had an M2 stop by the other day for the addition of our Sport Cat Downpipe and to try out the Dinan Piggyback Tuner. We did numerous dyno runs and overlayed stock, stock exhaust with Dinan Tuner, Sport Cat Downpipe, and the Sport Cat Downpipe with the Dinan Tuner. The Dinan Tuner made some nice torque improvements, but would be begin to break up over 6k after a few pulls, deeming it unreliable in our opinion. The Dinan tuner was taken back off and he left with our Sport Cat Downpipe happy as can be. In the client's words below...
"We did about a thousand dyno runs today at Fabspeed. Here are the results: (GRAPHS TO FOLLOW)
stock: 325/366 (a low reading but their M4 put down 410whp which is 10-20 lower than others on that forum board)
with Sport tuner: 333/396
sport cat DP only: 339/388
sport cat DP and tuner: 338/426
The DP is awesome! It creates amazing low/midrange punch. In addition, my entire exhaust setup is louder throughout the RPM range. I recommend it to anyone. I'm looking forward to a proper DINANtronics piggyback to raise the boost and other parameters."
      03-06-2017, 02:27 PM   #70
PrematureApex
Drives: N55 X1, N54 135, s54 m3
I mean, that's showing that the sport tuner (and other piggies generally), are just fine at boost power in the midrange (hence the mid range torque increases). They don't gain much up top, where perhaps the factory timing parameters need to be better optimized to make the most from the limited turbo headroom.
So while the sport tuner may not be gaining you peak power, you're clearly still gaining power in the mid range...
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
FSociety3812.50
      03-06-2017, 03:57 PM   #71
auf Deutsch
auf Deutsch's Avatar
2017 BMW M2  [0.00]
That was me...problem was I disconnected the tuner, did a stock dyno run....reconnected it without driving any miles for the ECU to adapt and right back onto the dyno...it fizzled out at around 6k. I'm quite certain the sport cat DP and Dinan tuner combo would be really strong.
retired: 2014 435xi|MPPK|335 bhp|3/5 stars
      03-06-2017, 05:54 PM   #72
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
You can install IC and stage 4 box and set it to stage one via APP when waiting for bigger turbo.
That's what Dinan suggested me to do a few weeks back.
Lemania 2320
      03-06-2017, 06:19 PM   #73
kiysersosae
kiysersosae's Avatar
436
Drives: 1M, M2CS, M3CS
I reckon your bhp figures would be better if you had an updated ic for the dyno. The reason your making great torque and not hp Is timing retard due to heat soak, I'm sure of it. On the open road u bet it feels great!?
      03-07-2017, 05:19 AM   #74
RPM2-85
Drives: 2017 M2 AW
I now have a Wagner evo 1 comp on my car. Throttle response better and pulls smoother to redline. I never ever feel the ect is cutting timing but the things buttery to the end. Took a few hundred miles to adapt as it did for the cat and the sport tuner.
      03-07-2017, 06:32 AM   #75
auf Deutsch
2017 BMW M2  [0.00]
IC, box, and turbo are all arriving together. It's been a long 6 weeks thus far.
      03-07-2017, 08:13 AM   #76
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
What gear should the 6 speed manual be in during a dyno run?
6spd cars usually are dyno'd in 4th gear but every car is different. I know we dyno the M2 in 4th gear.
If the car isn't in a 1:1 gear ratio. Does it invalidate the dyno run data we have to date?
      03-07-2017, 02:46 PM   #77
Fabspeed Motorsport
Drives: BMW M235i
Finally!
When you get all that installed, you definitely need to bring the car by again!
      03-07-2017, 03:02 PM   #78
auf Deutsch
2017 BMW M2  [0.00]
Finally!
Absolutely. Already did the baseline grunt work (339/388). I see no reason why 400 WHP can't be reached, let alone 450 TQ.
      03-07-2017, 03:31 PM   #79
Fabspeed Motorsport
Drives: BMW M235i
I can definitely agree with that!
      03-08-2017, 12:54 AM   #80
kiysersosae
436
Doing a 4th gear pull will make the dyno show less power if it's not 1:1
omasou2089.00
      03-08-2017, 06:45 AM   #81
auf Deutsch
2017 BMW M2  [0.00]
My dyno run was in 4th gear. Everywhere I read, 5th is 1:1.....
Fabspeed Motorsport we should try 5th gear next time.
No Boost4027.00
      03-08-2017, 08:59 AM   #82
Fabspeed Motorsport
Drives: BMW M235i
I am going to check with my technicians to see what their thoughts on. We can absolutely still do a couple pulls in 5th for you and compare the results!
      03-14-2017, 06:52 PM   #83
arwin
Drives: 2017 AW M2
I'm really confused.
If the Dinan Sport Tuner is giving these numbers for $300:
stock: 333.4 WHP @ 6388
356.2 WTQ @ 2769
Dinan tuner: 362.0 WHP @ 6369
407.4 WTQ @ 2844
Then why would anyone want to spend all the money to go to the Dinan Stage 4 for 18 more WHP? (See here: http://f87.bimmerpost.com/forums/sho...&postcount=226)
Seems like the best bang for the buck mod would be to do the Dinan Sport Tuner + FabSpeed Sport Cat DP to get similar HP.
Am I missing something?
      03-15-2017, 11:12 AM   #84
Fabspeed Motorsport
Drives: BMW M235i
I am not a Dinan expert but the Sport Tuner is a plug in and go system. There are a couple different maps to choose from and that is it. Other, more expensive tuning devices may allow for custom tuning to expand the parameters of the car. Other devices offer things such as lap timers, boost gauges etc.
      03-15-2017, 12:56 PM   #85
auf Deutsch
2017 BMW M2  [0.00]
One thing I've learned these past couple of months it that all dynos are absolutely useless with one exception....they provide a reliable delta when performing mods on your vehicle but, you must use the same dyno preferably in the same atmospheric conditions.
I had a stock baseline run of 333 whp and 362 whp with the Dinan sport tuner on a DYNAPACK back in January. This type of dyno runs higher. Case in point, I had a stock baseline run of 325 on Fabspeed's Dynojet and 339 with the sport downpipe....We ran the sport tuner but the results are garbage because we didn't give the ECU time to adapt prior to strapping it down. Given the 29 whp gained on the DYNAPACK, we can "possibly assume" that with the sport DP and Dinan tuner would yield a total of 368 whp. But this is all speculation given the two different dyno machines.
The boys on the M235i boards are consistently running ~400 whp with Dinan stage 4 with no other mods on a Dynojet. This is a good jumping off point of what to expect with our M2 given same N55. Add in the sport DP and a max whp number COULD be around 415.
This is really some complicated shit we're dealing with here. Whenever Dinan ships my turbo (it's been almost 7 weeks since order was placed), and I get it installed along with the stage 4 box and intercooler, I'm heading back to Fabspeed in the hopes to gain at least 60 WHP (400 total with DP). It's a nice psychologically satisfying number. But in reality, I need to FEEL a substantial power gain, numbers aside. this setup ain't cheap.
In summary, pay no attention to people's dyno graphs unless they provide a completely stock baseline run in conjunction with their stage 4 tune, or any other tune for that matter.
Appreciate 4
No Boost4027.00
SeanWRT3179.00
ried791.50
      03-15-2017, 01:19 PM   #86
Fabspeed Motorsport
Drives: BMW M235i
I had a stock baseline run of 333 whp and 362 whp with the Dinan sport tuner on a DYNAPACK back in January. This type of dyno runs higher. Case in point, I had a stock baseline run of 325 on Fabspeed's Dynojet and 339 with the sport downpipe....We ran the sport tuner but the results are garbage because we didn't give the ECU time to adapt prior to strapping it down. Given the 29 whp gained on the DYNAPACK, we can "possibly assume" that with the sport DP and Dinan tuner would yield a total of 368 whp. But this is all speculation.
In summary, pay no attention to people's dyno graphs unless they provide a completely stock baseline run in conjunction with their stage 4 tune.
Very well said! And I look forward to strapping the M2 back down with the Stage 4 ready to go!
      03-15-2017, 01:36 PM   #87
auf Deutsch
2017 BMW M2  [0.00]
And bring your driving shoes. You should get a feel for it in comparison to your highly modded M235i.
      03-15-2017, 01:39 PM   #88
Fabspeed Motorsport
Drives: BMW M235i
Oh I'm ready for it!
