10-19-2016, 07:11 AM | #23 | |
BMW Newb
582
Rep 903
Dabozo ...can you comment? |
10-19-2016, 09:00 PM | #26 |
Rep 1,514
10-24-2016, 09:46 PM | #30 |
Rep 229
Yeah I looked at the photos of the car I sat in and can't see them anymore. I just distinctly remember see M1 and M2 with little circles on them somewhere in the interior. I sat in 2 m2s and a m235i. Can't imagine it was in the m235i.
09-20-2017, 08:20 AM | #31 |
Rep 11
Drives: 2017 M2 (LBB)
My2017 M2 has blanks, however I purchased a set of M4 switches with the M1 & M2 buttons but alas no operation. I haven't fiddled with any coding yet.
09-20-2017, 03:36 PM | #32 |
Rep 479
I don't expect it will do anything...but I wonder if you could set them to exhaust modes (like the Macht Schnell and AWRON exhaust functions)
08-20-2018, 09:08 PM | #35 | ||||
Rep 5
08-20-2018, 09:51 PM | #36 |
Rep 289
As I recall the m240i has those buttons, but not the M2.
///M2 - 2018 LBB DCT
03-29-2020, 04:04 PM | #39 |
Rep 147
Hi guys,
sorry to revive an old thread, but at least the coronavirus is good for one thing - giving me time to fiddle with my car. I've made some progress on this idea. I've disassembled the steering wheel to see how the controls work. The blank buttons have a working circuit underneath them, which is good, the bad news is that there are two LED's missing, which means you'd have to find the correct LED's and solder them on, or the buttons wouldn't light up at night. A minor issue, but still. The left button cluster (where the blanks are) has analog pins that go to the right cluster, where there is presumably a LIN slave that then sends a digital signal through the steering wheel clock spring, at which point it is useless to us. To get working buttons, you need to intercept the analog signal before it gets to the LIN node in the steering wheel. I've been able to find the correct pins for both blank buttons, one is pin 1 and 6, the other pin 3,4 (see attachment). Now it's a matter splicing the 4 wires and finding a way to route them through the steering wheel separately. I don't think there is a way to route the wires other than going through the clock spring (that's the thing that allows you to turn the wheel without severing the wires). There are two connectors on the steering wheel that go through the spring. One is for the LIN stuff and has one empty pin on it and the other is for the airbag, which has 4 empty pins. If you have a heated steering wheel/or lane assist, you have an additional connector AFAIK. I don't so I don't know if there are any empty pins there... I've seen people retrofit a heated steering wheel and wire it through the empty pins on the airbag connector instead of buying a new clock spring. You could do the same thing here, and it would be just 2 buttons instead of a heating element, but I'm still a bit unsure about doing that, since I don't want an airbag exploding in my face Another option would be to buy a new clock spring which has the additional connector for the heated steering wheel function and you could use that, but I'm guessing that would be pricey. Anyway this is doable and I just need the right pins to fit the connectors and I'll be all set. I will be using the buttons to control my P3 gauge, but they could be used for anything What do you guys think? |
4
03-30-2020, 02:53 PM | #40 |
Rep 759
Looking forward to seeing where this goes!
'17 M2 DCT Long Beach Blue
04-01-2020, 04:06 PM | #41 | |
Rep 660
One thing that comes to mind is the disassembling the bluetooth controller for MPE or the "garage opener" for the VSC-1 (https://x-ph.com/cg-precision-vsc-1-...nd-controller/). That way you would not have to run any wires through the clock spring. The only question is whether or not there is enough clearance in that area for the electronics + batteries. May be possible to just run the wires out and tape/glue the electronics/batteries to the backside or underside of the wheel. |
05-12-2020, 04:13 PM | #42 | |
Rep 147
I will post an update when I get all the parts and get around to doing it |
05-12-2020, 06:16 PM | #43 |
Rep 159
"To get working buttons, you need to intercept the analog signal before it gets to the LIN node in the steering wheel."
"Working" in this context means "used for things other than the M1/M2 functionality", yes? Sounds like if someone wanted to map M1 to sport and M2 to sport+ or whatever, the steps are "buy and install the buttons" followed by "enable the buttons via FDL coding in E-sys"? EDIT: Spent a half hour screwing around in E-Sys. Looks like FEM_BODY > 3140 PfLinSteeringWheel > LIN_VARIANTE_MFL > "DCC_Sports" should be set to "DCC_M_Drive" (or "SLD_DCC_M_Drive"). Would someone with an M2C and/or an M3/4 with the buttons installed mind taking a look at this setting and letting us know what it is? As for the LEDs, if you post a picture of the existing circuit board I can probably get a part number. I assume they're just orange surface mount LEDs in 0402, 0603, or 0805 size, plus a resistor of some value in the same size. Since the other buttons are backlit, the parts should already be there. EDIT 2: Some folks on the German 1 series forum have been asking the same questions we are (https://www.1erforum.de/threads/mult...-m140i.260091/). They seem to be discussing it fairly actively and Google Translate in Chrome seems to do a decent enough job of getting the message across. Last edited by asciimike; 05-12-2020 at 07:55 PM.. |
