09-19-2021, 08:46 AM | #1 |
Rep 11
4 x 255/35/19 on stock rims?
Hi folks,
Wondering if I could safely run 255s all the way round to be able to move tires front to back (by remounting) to extend their life on the track. So basically square tires, staggered rims. I think 255s are within the range of both 9 and 10 inch widths... should I be concerned about the slight stretch on the rears? Might be slightly squishier on turn-in? Planning to run my PSS 245 and 265 with my 437Ms on the street (they wouldn't last a day at the track) and getting a second set of 437Ms with 4x 255 R-compound tires for the track as I like the look and durability of the forged OEM wheels. Hoping to keep everything (except pads) stock otherwise. I had a set of staggered contis that saw 12000km of sporty street and 6hrs of track. The inside of the rears wore first and the outside of the fronts wore first... hence my thinking... Thoughts? |
09-21-2021, 05:00 PM | #3 |
Rep 11
Very true, I had also been thinking that.
Then I saw a set of 437Ms take offs for $1700 CAD and the wondering began... It puts me $400-500 ahead and with lighter wheels (even the 18" EC7s are heavier) that are forged and that could be resold for not much less down the road. If I was going to track more than 6-8hrs a year (2hrs each time ), then I start into coilovers, camber plates and some aero dodads as well, but I'd say I'm 3 years away from going there. Hence the finest-cheapest approach to my set up. I love the power and refinement of the M2, but I may go back to the simplicity of an FRS/BRZ/GT86 for a dedicated track car in the future... And so concludes my life story. So you don't see any issues otherwise? My tire and wheel guy doesn't think it'll be an issue, but it may not be worth the hassle of mounting and dismounting the tires... |
09-21-2021, 07:18 PM | #4 | |
/M Enthusiast
1605
Rep 1,619
If you want to swap front to rear on a square set you want 4x rear rims, then run spacers to get the correct front offset.
BMW 437’s won’t allow that. Quote:
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
09-21-2021, 10:34 PM | #5 | |
Rep 7,337
The front and rear offsets are functionally identical on the OEM wheels. 9" ET 29 and 10" ET 40 works out the same in terms of poke. https://www.willtheyfit.com/index.ph...=10&offset2=40 |
09-22-2021, 02:40 PM | #6 |
Rep 11
I like it. Plus a 19x9 et 29 with a 255 would be a great spare to have in the trunk.
I think I'll buy the set and the tires, then see if someone has a pair of fronts they are selling and sell the rears or something like that. I suspect that I'll be good even if I give up an inch of rim at the rear. The limiting factor is front left at my local track, then front right, then the rears. Maybe it'll even undo some of the initial push with my stock set up on several exits... |
09-22-2021, 02:55 PM | #7 |
Rep 11
Not sure if the 19x10" ET 40 rims can fit in the front without spacers (to clear the suspension) and camber plates to avoid rubbing the fenders. Has anyone tried?
Car History: '71 VW Westfalia, '72 BMW 2002, '78 Fiat X/19, '82 VW Westfalia Diesel, '84 VW Jetta, '88 BMW 528e, '95 VW Passat GLX, '06 VW Jetta Wagon TDI, '10 VW Golf Wagon TDI, '13 Jeep Wrangler Sport, '14 Scion FRS, '14 VW Golf Wagon TDI, '17 Audi A3 E-tron, '17 BMW M2, '18 VW Golf R, '18 Smart fortwo Electric.
09-22-2021, 05:02 PM | #8 |
/M Enthusiast
1605
Rep 1,619
I cut a groove on one of my front struts from a front tire that was mounted on a rear rim by accident at the tire shop. I just looked at the tire size when putting the wheel on the car.
It made one hell of a noise, so I didn't go far.
100110121.50 |
09-22-2021, 06:12 PM | #9 | |
Rep 11
I feel lucky to know a very meticulous tire/wheel/detail guy. I trust him completely; one of the very few! He's also crazy fast in his FRS at the track (2:17 at Calabogie)...
Suds1604.50 |
09-23-2021, 09:22 AM | #10 | |
6643
Rep 4,145
Drives: '18 M2 6MT
https://www.tirerack.com/tires/tires...omCompare1=yes |
100110121.50 |
