02-10-2017, 11:39 AM | #23 | |
I used to be conceited, now I'm perfect.
570
Rep 1,826
Drives: 2018 M3 CS
2018 M3 CS - Alpine White l l
"I used to be conceited. Now I'm perfect" |
02-18-2017, 05:48 PM | #26 | ||
Rep 1,418
I got around it by using longer bolts and a a coupler acting as a very thick washer. I adhered a foam strip to the back of the plate because it does bounce around a bit...I don't know how thrilled I am with that but it wasn't expensive so no biggy if I go another route. Last edited by Dabozo; 02-18-2017 at 06:10 PM.. |
tutankhamon163.50 |
02-21-2017, 09:41 AM | #28 |
Rep 181
02-21-2017, 11:03 AM | #29 |
Rep 1,418
i just used a regular bolt and nut with a large washer in behind the grill but i was not able to fully tighten it...hard to hold nut in place while tightening...
i will probably have to go back and re-fasten it with proper fasteners...like this: |
02-21-2017, 11:04 AM | #30 | |
Rep 1,418
im in the west end btw...west mississauga. Guess you are thinking about an M2? |
02-21-2017, 12:50 PM | #32 | |
Rep 743
02-21-2017, 12:52 PM | #33 |
Rep 743
The way the front bumper is shaped I think the centre mounted plate in the pre-drilled slots actually looks best. i learned that after receiving my us mill works tow hook plate and looking at another tow hook mount on the lot. then looked back at the centre mount and it was an easy decision based on the way the M2 looks. I sent the usmillworks plate back.
I also got a Winnipeg jets plate so that definitely helped as the blue in the plate complements the BMW blue. Having our standard green white and yellow prairie plate would have looked awful. |
02-21-2017, 01:44 PM | #35 |
Rep 181
02-21-2017, 06:43 PM | #36 | ||
Rep 1,418
Think they are 220 euro shipped approximately. |
02-22-2017, 07:58 AM | #37 | |
Rep 2,948
02-22-2017, 09:58 AM | #38 | |
Rep 1,418
https://autoid.uk.com/products/perfo...nt=27061943303 |
02-22-2017, 11:05 AM | #39 | |
Rep 2,948
Ugh, I gotta make a decision before modding season begins in May. |
02-24-2017, 09:49 AM | #42 |
Rep 181
02-26-2017, 08:11 PM | #43 |
Rep 6,634
Did you pull the bumper off so you could fasten it or did you just attempt to hold it through the grill with your fingers..?
02-27-2017, 09:47 AM | #44 |
Rep 181
^You should be able to do it without having to pull the bumper off.
In other news, very happy with the clear bra install and the tint. They did a great job! Highly recommend Pureauto to anyone needing work done in the GTA. I was concerned that 30% may be too dark for my liking, however it seems to have come out just fine. Springs and spacers are on the way! Might be done everything before the break-in service at this point lol |
Dabozo624.50 |
