01-04-2024, 02:52 PM | #1 |
Rep 287
So I’m currently on the BM3 multimap stage2+ OTS tune, with about e30.
It seems whenever I go WOT, high rpm range, the car stutters or misfires. No codes at all. Just feels as if the car is breaking up or choking rapidly. I took a log of it but let off as soon as I felt the stutters. Can anyone who’s more knowledagble with reading logs, take a look and see if there’s anything that can lead to why the cars doing this? It was running perfectly fine for about a week or two when I first installed the flex fuel kit but now it’s back to doing it. Fresh plugs (0.030) and PR coils. https://bootmod3.net/log?id=65970e30f9a8ea58b1642010 |
01-04-2024, 06:26 PM | #3 |
Rep 287
01-05-2024, 12:07 PM | #6 |
Rep 287
I’m thinking plugs as well. Do y’all have a recommended gap I should go down to? I had 0.028 before these new plugs, but car still did same behavior on stage 2+ OTS map. I read somewhere 0.030 was the stock gap so I gapped wider on the fresh plugs.
MAP was replaced for a 3.5 BAR before getting the flexfuel kit, and injectors were replaced with EU6’s not too long ago. Hoping it’s just plug gap! |
01-11-2024, 11:40 AM | #7 |
Rep 261
At what RPM does it do it?
Does it constantly at the same RPM?
Speedtech top mount G35|Motive| Reflex plus | Wagner EVO 3 | BMP manifold | Dorch Stage 2 HPFP | PI | Precision Racework stage 4V2 LPFP | BendCalibration Flex Fuel Kit |turner catch can| HRE 20” \Apex 18” wheels| ECUTEK tuned by bendCalibration|ohlins suspension
IG Modded_M2 |
01-12-2024, 01:43 AM | #8 |
Rep 287
01-12-2024, 01:59 AM | #9 |
Rep 261
I had the exact same issue with stage 2+, it was my HPFP, but I had stock HPFP.
Does it do it with stage 2 not 2+. What is your Emix ? (E30?)
IG Modded_M2 |
01-12-2024, 02:03 AM | #10 |
Rep 87
01-12-2024, 09:43 AM | #11 |
Rep 261
I’m just sharing with him My issue was fuel related, so it can atleast gives him an idea what it could be.
IG Modded_M2 |
01-12-2024, 10:07 AM | #12 |
Rep 287
[QUOTE="Mr_M//;30806658"]I had the exact same issue with stage 2+, it was my HPFP, but I had stock HPFP.
Does it do it with stage 2 not 2+. What is your Emix ? (E30?) Stage 2, no issues. Stage 2+ & MM Stage 2+, I get the stutter/misfire feeling issue. According to the FlexFuel sensor, I’m at about e25 currently! |
01-12-2024, 10:27 AM | #13 | |
Rep 261
[QUOTE=Jayrhee7;30807444]
Did you run the car with stage2+ or MM stage 2+ without issue before the flex fuel sensor? Or did you do everything at the same time?
IG Modded_M2 |
01-12-2024, 10:38 AM | #14 | |
Rep 249
Second, your hpfp holds up fine Third, your injectors are new(hardest to diagnose) Last, according to what you said, it's boost related. Just gap down |
01-12-2024, 10:42 AM | #15 |
Rep 287
First time I ran stage 2+ 93oct OTS map, I didn’t have FlexFuel or ran any E. I still had the same symptoms on that map, but when I installed the FlexFuel and added E, I still had symptoms on the MM Stage 2+ map.
01-12-2024, 10:43 AM | #16 |
Rep 287
Oh, I did not know it needed e40+! Will add some more after I gap down and see how things run 👍🏼
ericlr1225136.50 |
01-12-2024, 10:49 AM | #17 | |
Rep 261
Maybe try selecting a different one.
IG Modded_M2 |
01-12-2024, 02:12 PM | #18 |
Rep 287
01-12-2024, 05:24 PM | #19 | |
@lbb_kev
494
Rep 515
01-12-2024, 05:49 PM | #20 | |
Rep 287
I have a set of OEM coils as well. When the Bosch plugs arrive, should I give 0.025 gap a try? |
01-13-2024, 12:48 AM | #21 | |
Rep 249
Get them to 0.022-0.023 first then do some log/pulls. If it fix your issue, you can gap up later. If the issue still remain, there is no point to gap down more under 0.022''. At least you know it's something else. Last edited by ericlr1225; 01-13-2024 at 12:54 AM.. |
01-15-2024, 11:33 AM | #22 |
Rep 261
I would check the injectors and work that was done after they got replaced.
But hopefully you don’t need to do that after gaping the plugs or changing the coils. Good luck
IG Modded_M2 |
Jayrhee744.00 |
