04-05-2024, 01:35 PM | #23 |
your average JAMF
3179
Rep 4,107
Well folks, I've been down this road, lots of good info above.
My stock brakes were acting like the rotors were warped early on and at 8k miles, dealer did a "goodwill replacement" of the front pads & rotors. Problem solved. For 4k miles anyways, the same amount of time it took to crop up with the original parts in place. So I started researching and came to the same conclusion as above - it's not warped rotors, it's deposits on the rotors from the shitty stock Brembo brake pads. So at the recommendation of many, I went with the Carbotech 1521's at about 14k miles. I'm now at 32k miles. MUCH MUCH prefer these pads for my use which is 100% street. Pedal feel is miles better, much more linear, about 90% of brake dust now gone and wheels stay clean forever. My indy mechanic was supposed to do a light turn on the rotors to get the deposits off but didn't - and I still had some of that shimmy feel for quite a while, but now 18k miles later, it's all but gone. Here's a good article about brake rotors, warping & deposits.. posted here by someone a few years ago. Everyone with 2NH brakes should read this.... https://alconkits.com/blogs/news/the...d-brake-rotors
'21 M2 Comp
'19 Golf R |
///MPhatic14091.50 chris7197368.00 |
04-05-2024, 02:28 PM | #24 | |
The Seeker
14092
Rep 3,379
That's a good article, but he skips over the fact that not all pads need to be bedded-in. In fact, the more ceramic the pad material, the less it needs bed-in, and if you do bed them in you'll glaze them and the rotor terribly. He also doesn't mention the fact that with some pads, like those that come fitted to the M2, parts of the pad material are harder than the rotor, so over 30% of what you're seeing as brake pad dust is actually rotor. Couple that with the fact that BMW only gives 1.6mm of wear and you've got yourself a cash cow for those that don't know better. |
04-09-2024, 06:00 AM | #25 |
Boost All the Things
122
Rep 96
Ordered the 1521s based on this thread, mainly because the dusting makes me half insane. My car is a toy for me, and I basically only drive it on nice days, so having the car turn black from the brakes, and especially trying to maintain the wheels, makes me a bit nutty.
'21 M2C, HS, MT, EP - AA EL + Axle Back, FMHE, "Enabled"
Past - '09 335i Sport, '11 M3 ZCP Sedan, '11 550i M-Sport Also - '94 F-150 Lightning (mild, mid-mount turbo), '95 F-150 Lightning (big motor, big turbo), '15 Chevy SS Sedan (supercharged) |
captain slowly721.50 |
04-09-2024, 05:01 PM | #26 | |
Rep 74
FMOS Racing121.50 |
