06-23-2019, 12:24 PM | #89 | ||
21736
Rep 8,700
It's to aggressive for sure, and will easily destroy the rear tires in short order.
06-23-2019, 03:43 PM | #91 | |
847
Rep 1,962
The former are are embittered and sarcastic. The latter are smug arseholes. While I am an M2 LCI owner, you would be a prime example of the latter... Last edited by M Fifty; 06-23-2019 at 04:27 PM.. Reason: Clarity |
kfscoll208.50 nothingman522.00 |
06-23-2019, 04:28 PM | #92 | |
Rep 6,978
Drives: 2018 M2 AW DCT
I still have a iPhone 7. |
06-23-2019, 06:53 PM | #94 |
Rep 1,122
06-23-2019, 07:42 PM | #95 |
Rep 7,340
I've driven both now, but with a significant gap in time between them. Engine definitely more powerful in the mid-range and higher on M2C. The seating position is just as bad (high) on both. Rumors that the M seats had you sitting lower were false I believe. The brakes on the M2C are a bit overboosted and very touchy. Replacing the pads with something that has less initial bite would probably take care of it. Steering feel did seem better but I didn't drive them on the same roads so it's hard to make that comparison.
06-24-2019, 05:09 AM | #96 | |
Rep 3,361
My E90 M3 is a slicktop, so lots of extra headroom, but even in that car with the seat adjusted all the way down, I have about 2 finger widths of room or less. The M2C slicktop with the new design seat adjusted all the way down yields more than twice that amount of room as the M3. I feel like the M2C seat sits very low in the car in fact. One of the reasons I love the new (well M4) seats. As soon as I get in the M3, I lament the nice low seating available in the M2C.
Current Stable:
06-24-2019, 07:12 AM | #97 |
Όλα ρόδες
760
Rep 561
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
I guess it all depends on how you define high seating. The M2 does have more headroom than other BMWs that's why you get better clearance with the helmet on, it's a tall car.
But relative to other BMWs, (e46 and e86, in my case) and relative to the dashboard/center console, one does feel more "on" than "inside". Personally, it doesn't bother me. Nice article you wrote in the Roundel! |
CSBM52756.00 M3 Adjuster7909.00 |
06-24-2019, 09:58 AM | #99 | |
S0THPAW
8783
Rep 7,852
Cheers Robin |
06-25-2019, 02:10 AM | #100 | |
Rep 7,340
06-25-2019, 03:23 AM | #101 | |
Rep 1,018
As much as I've studied and researched the M2 over the past few years, I remember seeing that description a lot. I enjoy reading you guys discussions, and have no particular interest or care in this debate, other than what I mentioned, just pointing this out. |
06-25-2019, 03:41 AM | #102 | |
Rep 7,340
qnet684.50 |
06-25-2019, 04:14 AM | #103 | |
Rep 1,018
I've since learned how to modulate the throttle and control it a little better, but it still more fun to just shift in manual mode on the streets. |
///M TOWN21736.00 |
06-25-2019, 10:49 AM | #104 | |
Rep 35
I did not really notice that much difference in the initial turn in between OG M2 and M2C. M2C maybe a bit stiffer due to the M4 carbon strut brace, but the dampers and springs are the same OG M2 to M2C, despite what BMW said about revised suspension. There are a couple of joints which were changed to rose joints and that is it. I also find this a bit odd as the S55 is heavier and I would have expected the front suspension at least to have been re calibrated for this and changed. I think it comes down to the fact that BMW had to put the S55 in to keep the M2 going as the N55 was being killed off due to the emissions changes. They maybe did not want to spend the money tuning, testing and redoing all the spring and damper rates as the M2C will not be in production that long anyway. This is a compromise for the M2C though as the suspension was developed, tested and tuned for the OG M2 and the N55. In terms of the M2C drivelogic with the button to change the shift aggressiveness, I find this to be completely pointless. In the OG M2 BMW dealer technician technical documentation they explained how the drivelogic had been programmed to automatically select the shift ferocity based on driving parameters, which makes sense and it works really well for me. If I drive it hard, it shifts harder and faster, when I am pootling about, it shifts slower and calmer. It immediately adapts to how the car is being driven and changes the shift ferocity as appropriate. In my opinion having a button which I would need to mess around with and change when putting my foot down or going slowly, is a step backwards, not forwards. But I guess it gives another button and some LED lights for people to get excited about and discuss in the pub. Last edited by 620turbo; 06-25-2019 at 11:06 AM.. |
F87EVO4059.50 |
06-25-2019, 11:08 AM | #105 |
Rep 3,844
The iDrive behavior sounds like every automatic transmission I've driven. They all hold gears longer when accelerating faster. As far as the button, it's like a sport mode button which is in about half of the cars on the road. There is nothing unique in the setup.
06-25-2019, 11:15 AM | #106 | |
Rep 35
The drivelogic system on the OG M2 automatically computes and adjusts the change ferocity, which the M2C M3 and M4 have the button behind the gear selector with the LED lights for. |
06-25-2019, 11:22 AM | #107 | ||
Rep 6,638
If you are in comfort mode and drive hard the shifts are still lazy, slow, and smooth. It may hold gears longer based on throttle and but that's not all there is to it. When you press the drive logic button to get it to 2 or 3 or in the OG m2 put it in sport or sport+ you'll notice the shifts happening much faster and much harder. I always know if I'm accidently in the wrong drive logic mode as soon as I shift. |
06-25-2019, 12:00 PM | #108 | |
Rep 35
From the F87 M2 technical training manual: "In all three modes, the shift points and shift dynamics, among other things, are influenced by the accelerator pedal position" |
06-25-2019, 12:02 PM | #109 |
Rep 3,844
ok, yes I meant to say drive logic, I guess that wasn't obvious?
06-25-2019, 12:11 PM | #110 | |
Rep 1,122
Yeah the N55 was def on its last legs due to emissions but it didn't have much left let alone for a competition model. I too owned the OG M2 swapped turbos and all I can still state with ease the M2C is a better car in every aspect well aside from exhaust note lol. As for suspension the parts are different but how much that's how to debate still. On the DCT front I have no clue as I never would buy an M car in automatic. Manual transmission is a must for me as these cars are intended to be driven that way |
