M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Will a 18x8 ET 20 square setup fit?
      05-12-2017, 01:39 PM   #1
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
I have a leftover set of winter wheels/tires from my 1M which I'm guessing won't clear the brakes? Can anyone confirm?
      05-17-2017, 11:59 AM   #2
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Keith@tirerack.com or anyone?
      05-21-2017, 12:32 AM   #3
aarodynamics
Drives: 17 M2/08 M3/15 Golf R/20 GT4
I just tried a set of 18x9.5 et22 from my E92 and it didn't seem like it will work from looking at it. I might try a bunch more negative camber though.
      05-21-2017, 01:18 AM   #4
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Might fit depending on wheel design. Some 18" clear the brakes, some don't. It is the design of the inner barrel and spokes that matter.
Your wheel is 17 mm more aggressive than the OP question, so not really relevant.
      05-21-2017, 06:31 AM   #5
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
It's the Sport Edition A7's.
https://www.tirerack.com/wheels/Whee...Silver+Painted
      06-06-2017, 08:37 PM   #6
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Handy calculator here (http://www.rimsntires.com/specspro.jsp) to show fender clearance and strut clearance comparisons between two wheels. Very common for people to overlook the width of the tire when comparing two setups.
You can see here that the 18x9.5 ET22 comparison referenced above will stick out 2mm less than the 18x8 ET20 at the tire which is where you are most likely to get rubbing.
TunedM2C828.50
      06-08-2017, 07:41 AM   #7
Rudy@tirerack
Drives: rudy@tirerack.com
I just noticed this post, sorry for the delay.
The 18x8 ET20 Sport Edition A7 will not clear the top of the caliper. This wheel will rub on the M2 brake caliper.
      06-08-2017, 10:33 AM   #8
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Ok thanks.
