05-03-2017, 09:09 PM | #1 |
Rep 463
M4 tires on M2?
Hello all,
My apologies if this has been covered, Searches yielded very little. I want to know if stock suspension/stock wheeled(no spacers) M2 will rub when running the larger 255/35/19 and 275/35/19 tires that come on the M3/4. Thank you in advance. Best, Nate |
05-03-2017, 09:21 PM | #2 |
Rep 2,560
Drives: Rapidly from A to B
They will fit with no rub or other issues.
M2OG400.00 |
06-01-2017, 09:34 AM | #4 |
Rep 4
will that size fit a m235i?
we just got a 14 m235i and there is a set on craigs off a m4 for sale and was wondering the same thing? thank you |
06-01-2017, 10:21 AM | #5 |
Rep 281
06-01-2017, 10:57 AM | #6 |
Rep 149
Does anyone have pictures of this setup on stock suspension / wheels? Has anyone run the larger M4 sized tires on the track without rubbing? I'm thinking this will be my next tire size if there is no rubbing on the track. Thanks.
06-01-2017, 12:24 PM | #7 |
Rep 379
You should be fine with about any 265/35 - 285/35 sized tires on OEM wheels and stock suspension. Keep in mind not all tires are exactly the same width, etc.
See this post... http://f87.bimmerpost.com/forums/sho....php?t=1296871 I also talked to someone who had 295/30s on the rear, stock suspension.
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 |
06-15-2017, 06:37 PM | #12 |
Rep 463
Hey everyone, just want to throw this update out there. Yesterday I swapped the stock tires for Pilot Sport 4s in the M3/4 stock sizes. Much to my surprise I got some rubbing in the rear when cornering under load. Going to get the car on the alignment rack tomorrow...
EDIT: I failed to realize the tires were overinflated by 3-4psi. I dropped the pressure back to 35 and so far so good. Still going to get the car on the rack tomorrow. Last edited by M2OG; 06-15-2017 at 07:36 PM.. |
06-16-2017, 10:39 AM | #13 | |
Rep 236
Drives: 2017 M2 6MT
06-16-2017, 12:41 PM | #14 | |
Rep 379
06-16-2017, 05:40 PM | #16 | |
Rep 15
(you can hear the rubbing at 0:55 and 1:10) |
M2OG400.00 |
06-17-2017, 01:17 AM | #17 |
Rep 7,294
A lot of the tires in that "extreme performance" category seem to run wide like the Dunlop Star Specs, Yokohama AD08R, Bridgestone RE71-R, etc. You can always see that the OEM stretched look is gone if you mount the equivalent tire size on the stock wheels.
