M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Michelin PSS Star vs no star
      03-24-2017, 07:20 AM   #1
spiderman1982
Drives: BMW M550x Drive
What is the difference between a Michelin PSS non-star and a Michelin PSS star? Is the rubber compound different or is it just the tread width that is different? I can't believe that a Michelin made for a Porsche is less sticky or more sticky than one made for a BMW. The tire made of the Porsche, same size of course, is wider than the one made for the BMW.
Mr 294.00
AndrewC198910931.00
      03-24-2017, 01:58 PM   #2
stripecheck
stripecheck's Avatar
2017 BMW M2  [0.00]
Long winded but kind of explains....
Lots of manufacturers have their own special hallmark they put on the tires they assist in development. Bentley has a "B". Porsche has N0. Ferraris put a K or something like that on theirs. Bimmers get a star. Are they really any different? Maybe, maybe not but as long as the size is the right size they ought to work.
      03-24-2017, 11:44 PM   #3
chris719
Drives: '08 M Roadster
Truth is, no one outside of BMW knows. Most of the time it doesn't appear that BMW makes big changes. However, if you look at the Corvette version of the PSS, I think they might be a more aggressive tire. They have a lot of reports of cracking in low temps which I haven't seen with the normal or BMW PSS.
      05-04-2017, 04:04 PM   #4
maddoc
Drives: E36-E82-F87-7P
I'm reviving this, because I'm hoping someone has a better answer. Because I'm a little dumfounded right now.
Long story short, I had to replace my right rear tire after only 800 miles. Went to the dealership to have them replace the tire and assumed that the tire would be a PSS with a BMW Star on it. Long story short, It's not. In fact it has "MO" on it, which I found out is Mercedes. I've been doing a bit of research in Michelin's site and it appears the BMW Star version weighs in at 26.2lbs vs the Mercedes one weighing in at 24.8. To me that tells me there's something in the BMW PSS that's different.
Initally I wasn't going to fret over it much, but I'm going to have to say otherwise. It's basically like running a different tire on the wheel.
Take a look at the table: http://www.michelinman.com/US/en/tir...tail-sku-table
      05-05-2017, 06:15 AM   #5
swagon
swagon's Avatar
Drives: F80 6MT
Tread design (e.g. wider water channels), tread & section width, compound, weight, etc. might all be different. It's not like it's just a marketing gimmick, at least for those high-performance models.
I'm just surprised a BMW dealership has not installed a BMW-approved tire.
      05-05-2017, 10:43 AM   #6
maddoc
You and I both. I specifically went to BMW because they said they had it in stock and so I would receive an OEM tire for the car and specifically asked the Parts department if it was the OEM tire for the M2. I got unamaous "yes's" the whole way around. I could have just ordered the tire from TireRack and had the correct tire mounted on the car by now.
I'm in the midst of having the discussion with the dealership. Yesterday I had the run around that "its the same tire, the tire with the part number we use, its the tire we get from the distributor, etc. etc."
Well, you're distributor is messing up.
      05-05-2017, 12:05 PM   #7
swagon
swagon's Avatar
Drives: F80 6MT
I would like to see the difference between MO1 and *. Someone over at F80Post has posted photos of the two tires together, but they were different sizes.
Another confirmation that dealers are just clueless.
