M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Wheel offsets
      03-15-2017, 05:48 AM   #1
Smiley1175
Smiley1175's Avatar
281
Wheel offsets
Hi Guys,
Would anyone be able to let me know if the following would fit on our M2's?
9x19 ET 15 Front
10.5x19 ET25 Rear
From what I can tell, they'd be almost like stock with 15mm spacers.
Anyone know if they'll fit with stock suspension?
Cheers
      03-15-2017, 06:53 AM   #2
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
They won't be anywhere near inside the fenders but might not rub depending on tires.
      03-29-2017, 10:26 PM   #3
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
What about 18x10 +25 offset square.
Seems like the front should have no problem but afraid the rear might be too low of an offset.
      03-30-2017, 12:09 AM   #4
nacaruh
FOUO
nacaruh's Avatar
Drives: E82
I think stock offsets are ET29 for front, and ET40 for the rear.
(Someone correct me if I'm wrong).
I have a set of ET22 wheels for my 1M, and I am 99% sure that it'll stick out on the rear
      04-13-2017, 10:16 AM   #5
maddoc
Drives: E36-E82-F87-7P
I was just looking into this...
OEM wheel specs are as follows:
19x9 +29 F
19x10 +40 R
I'd like to know the range of offsets we could put on the M2 so I can know what wheels to hunt for
Thus far I've seen:
BBS FI-Rs
Front: 19x9.5 ET22
Rear: 19x10.5 ET35
Volk TE37s
Front: 19x9.5 ET18
Rear: 19x10.5 ET22
*Super aggressive
Signature Wheels suggests - Link
Front: 19x9.5 ET30
Rear: 19x10.5 ET40
      04-13-2017, 11:09 AM   #6
Ex-MINI
BMW Newb
Ex-MINI's Avatar
582
Drives: 2016 LBB M2 DCT
Front: 19x9.5 ET30
Rear: 19x10.5 ET40
I've got those wheels coming in mid May....I'll let you know then
Seagull288.50
      04-13-2017, 12:35 PM   #7
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
If the car is lowered I would go a bit more aggressive to be flush, especially at the front.
      04-13-2017, 12:37 PM   #8
Ex-MINI
BMW Newb
Ex-MINI's Avatar
582
Right now its stock, and still debating whether to lower or not. Probably going to keep it at stock height for now, and re-evaluate later.
      04-13-2017, 12:45 PM   #9
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
OK, on stock height I personally wouldn't go more aggressive than the stock setup as it is flush enough for my taste. But I know a lot of people prefer the slight poke.
Ex-MINI582.00
      04-13-2017, 10:55 PM   #10
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
What tires are you going to be throwing on this setup?
Current
AW BMW M2
Past
VO BMW 1M
      04-14-2017, 08:47 AM   #11
Ex-MINI
BMW Newb
Ex-MINI's Avatar
582
Haven't decided yet, but either a set of oem F80 Pilot Super Sport take offs, or gong with a bit wider set of RE71r....
      04-25-2017, 02:03 PM   #12
maddoc
I feel like we should update the thread title to "M2 Wheel Offsets", sticky this and have people show what wheels and offsets they've been able to accomplish.
      11-12-2018, 05:04 AM   #13
Ryantopham
Drives: Bmw f87 m2
Could any of you guys tell me if these wheels would fit?
Front – 20×9 ET20
Rear – 20×10.5 ET25
      11-12-2018, 12:22 PM   #14
mr_lab_rat
mr_lab_rat's Avatar
564
Drives: 2017 M2, 2018 X1
Front – 20×9 ET20
Rear – 20×10.5 ET25
The fronts yes, the rears are too aggressive. The equivalent to the front would have to be 20x10.5 ET37 or 20x10 ET31.
They could still fit if you stretch the tires, add camber, the usual tricks.
      01-21-2019, 08:08 PM   #15
mcjoe691
mcjoe691's Avatar
Drives: 2015 M3
Need some help i have Vossen 20 inch wheels for my f80 m3 Front 20x9.5 et+21 and rear 20x11 et+34 will these fit M2 COMP looking to buy M2C ....want to see what i can use from my F80 and sell the rest... thanks so much .
Build by (PSI) 2019 M2C , BC suspension , BC wheels , DP , Vorsteiner trunk lip , Diffuser , Side Skirts , IND reflector kit , Rw carbón hood , DME Tuned !
E90 M3 Supercharged
      03-10-2019, 08:38 PM   #16
m7ich7ael7
Drives: M3
M2c - Wheel Offset - will these fit?
Looking to get in on an M2 and I have the following wheels from my M3. Wonder if they will fit...
Will 19 x 9.5 et +32 and 19 x 11 er +25 fit on and M2c?
      03-11-2019, 10:57 PM   #17
m7ich7ael7
Drives: M3
Anyone?
      03-12-2019, 12:22 AM   #18
pointy
pointy's Avatar
29
Drives: M2 Competition
I'm no expert but I would say that it would be a squeeze, if not rub. And it would largely depend on what size tyres you plan to fit on as well.
Try using this basic calculator to get an idea.
https://www.willtheyfit.com
As an example, plug in the M2C rear stock rim size:
19x10 +40 with 265/35/19
Then put in your new wheels and tyres:
19x11 +25
Let's assume a new tyre size of 285/35/19
The calculator then states it would poke out 27.7mm at the rears.
From what I've read, people are successful using 10mm spacers at the rear on stock rims without scrubbing.. so 27.7mm seems like it would push it.
      03-12-2019, 12:45 PM   #19
Raptor911
Drives: 2018 AW M2
You will need spacers in the front but rears will hit the outside fenders
      03-17-2019, 11:23 AM   #20
gnx
Όλα ρόδες
gnx's Avatar
760
Drives: BMW
You guys should try this too. Super detailed.
https://www.rimsntires.com/specspro.jsp
      03-17-2019, 01:45 PM   #21
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Originally Posted by Smiley1175 View Post
Hi Guys,
9x19 ET 15 Front
10.5x19 ET25 Rear
Cheers
Your math is backwards. Lower positive offset puts the wheel further out. Adding spacers gives you less positive offset.
Adding 15mm spacers to +19 offset nets you +4 offset. Given that stock is +29, theyre going to stick out 25mm (basically an inch) more than stock.
Motorcity BMWCCA Member
Instagram | YouTube
      04-01-2019, 03:10 AM   #22
R-power
R-power's Avatar
Italy
Drives: M3e46cs
dears,
thx for this topic
firstly i ask u this:
M2 oem 19" are
F: et29
R: et40
but they are et+29 or et-29 ???. this is my first question
i think et+29 but this is very crucial to understand "rooms" in the car.
Then second question is:
i have found titan 7 ts5 for my M2
they are 18" 9,5j et22 for square setup with 255 semislick tires for trackday and i am not sure if they can work in my M2 my16 or i will have issues
Some of you may help me?
thx a lot
