07-06-2018, 09:23 PM | #23 | |
Rep 60
I saw your discussion on 295/30 rear on stock wheel, if we go 255/35 front, how will the electronics on the car be affected? |
Al1969533.50 |
07-06-2018, 10:26 PM | #25 |
Rep 3,699
The electronics should be ok. Mostly what the car is looking for is a larger diameter and sidewall height in the rear. Otherwise, the car will think the rear is slipping relative to the front and will engage traction control.
Al1969533.50 |
07-09-2018, 08:51 AM | #26 |
Rep 60
07-09-2018, 10:34 AM | #27 |
Rep 3,699
Following up on this, I wasn't sure which tire sizes exactly you were comparing. If it's 295/30/19 & 255/35/19, I wouldn't recommend it. The 295/30 has a shorter overall diameter and sidewall height compared to the 255/35.
It's the actual measurements that matter, vs the series, but if you put a 30 series on the rear you're essentially forced to put a 30 on the front within the size ranges that fit on the M2. I've run 245/35 & 265/35 and 265/35 & 285/35 on the OE wheels, and 265/30 & 295/30 on a track wheelset. Personally, I'm trying to decide 255/35 & 285 or 295/35, or 265/30 & 295/30 for my next set of 4S's on the OE wheels. Comfort, wet track grip, and then dry street grip are the order of my priorities, so leaning towards the 35's. |
07-10-2018, 06:52 AM | #28 |
Rep 489
Was talking to some M2 folks during last M Fest in France, larger front tires could become a bigger problem of little stones hits damaging the paint on rear sides, despite the (too) small protection, one of them had a LBB driving intensively in mountains, his side was full of minu white spots ... so he made some front protection, i think its wise to stay with 245 in front
07-11-2018, 08:11 AM | #29 | |
Rep 60
Al1969533.50 |
07-13-2018, 07:37 PM | #30 |
Rep 312
I was told by a Michelin rep at a recent M track day that star spec 4S are coming soon. He said the compound and/or tread pattern will be more specifically tuned for the M2 on those as they are developed specifically with the OEMs. FWIW.
Al1969533.50 |
07-18-2018, 04:03 PM | #31 |
Rep 460
Drives: BMW 330i G20
I have like double wear left on the fronts and soon need to change the rears.. I feel it's a waste to change the fronts at the same time..
Is it "OK" to have stock tires on fronts and PS4s on the rear? Only street and spirited overtakes on my part.. |
///M2-PILOT311.00 |
08-01-2018, 10:45 AM | #32 |
Rep 2,577
The RE71R on the back was almost worn out after 12000KM including 3 HPDEs. Hankook RS4 was on my top list, but I was so mad I didn't order earlier and now that it's sold out and will not be available any time soon.
I don't really want to use AD08R (poor man's RS4, IMO) and see it lasting forever on my car. So I settled for Cup2, should be doing great in Summer. Here in Shanghai, summer is 90~100F most of the time with high humidity. Installed Cup2 on the back today. Did a few LC@2500rpm, and got mostly 4.1~4.3s in 0-100kph, or 3.9~4.1s in 0-60mph, meaning grip is there. Now that I don't struggle getting them up to temperature, so far so good.
Lemania 2320
Al1969533.50 |
08-03-2018, 01:01 PM | #33 | |
Rep 468
08-03-2018, 01:10 PM | #34 | |
Rep 3,699
Plus, being in CO, you’ll be able to drive a cpl more months in the year with the 4S. The 71R is sketchy below 45F on the street, which you’ll definitely see in spring/fall mountain runs. Put the 71Rs on a dedicated wheelset and run them at the track and in the middle of summer (when it’s not raining...). |
dcmac443.50 |
08-04-2018, 10:46 AM | #35 | |
Rep 60
Summer is hot enough for the Cup2, and so far used over 3,000km, the wet performance is not that bad. Enjoy. |
08-07-2018, 07:33 PM | #36 |
Rep 387
What about nitto nt555? Any feedback, I had the toyo r888r 285/35/19 and kept stock fronts
Fee like toyos after 4000 miles don’t grip anymore Torn between a tire Was thinking Michelin’s Help |
07-06-2023, 06:15 PM | #38 |
Rep 1
