M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > California Duster
      10-13-2017, 07:29 PM   #1
scadagawd
scadagawd's Avatar
47
Drives: BMW M2 2018
California Duster
Anyone here have experience with using this? My colleague at work says he uses it all the time in between washes. Does it scratch the car? Any thoughts on this?
BMW M2 2018 LBB
BMW X1 2016 PSM
Audi S4 2014 SMG
      10-13-2017, 09:56 PM   #2
Orange fever
Orange fever's Avatar
Thailand
2351
I will never use that... And yes it will scratch your car
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged ///
F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87)
      10-13-2017, 09:58 PM   #3
scadagawd
scadagawd's Avatar
47
Drives: BMW M2 2018
Guess I should hold off on getting one then ?
BMW M2 2018 LBB
BMW X1 2016 PSM
Audi S4 2014 SMG
      10-14-2017, 02:28 AM   #4
greasypeanut
Drives: F87
why not take a look at his car while on a break
      10-14-2017, 03:19 AM   #5
ORIGIN M.
3161
Drives: ///M
If you just use it lightly on a clean but dusty car it works good.
Shaking it every few swipes, and do not apply much pressure.
I follow up w/ Mist & Wipe once I have remove the surface dust.
      10-14-2017, 10:49 AM   #6
Spa2k
Drives: '13 JCW
I've never had a genuine California Car Duster (there are lots of copycats) scratch the paint, but I only have used one on a slightly dusty car that was in the garage. I would never use one on a car that has just been driven.
A better choice for removing dust is a quick wipe down with detailing spray and and a high-quality microfiber cloth. Surface lubrication is your friend when wiping any painted surface.
OTOH, I use a mini California Car Duster all the time to dust the dash, door panels and other interior hard surfaces and have never had any issues or damage. However, I would not use the Duster on the plastic gauges or any piano black surfaces. In those places, a wet (water, but not dripping) microfiber towel followed by a gentle wipe with a dry one works best.
      10-27-2017, 12:05 PM   #7
bobsor
I've used mine for several years on multiple cars including my M2 without a scratch. I suspect that if it's been dropped on a dirty surface and used without shaking it adequately it could pick up contaminants that could scratch, but when used as recommended it's an awesome product. I see them in use often at car show and concours events on exotic cars.
      10-30-2017, 12:25 PM   #8
scadagawd
scadagawd's Avatar
47
Drives: BMW M2 2018
Interesting. Have you tried using it on the dried out rain spots?
BMW M2 2018 LBB
BMW X1 2016 PSM
Audi S4 2014 SMG
      10-30-2017, 01:29 PM   #9
Spa2k
Drives: '13 JCW
If you rub hard enough with a California Duster to remove rain spots, which usually contain contaminants (or mix with the ones on your car), you'll damage the paint. Use a detailing spray (or water spot remover if they're on glass) and a microfiber cloth to remove them.
      10-30-2017, 01:58 PM   #10
tutankhamon
164
Drives: 2017 LBB BMW M2
I use a california duster (an actual one) on my car all the time. No scratches whatsoever. I don't push hard, i just use it to get the dust off. If there are rain spots, then the car is getting washed, not dusted lol
      10-30-2017, 02:03 PM   #11
geogerf
geogerf's Avatar
116
Drives: MY17 LBB M2
2017 BMW M2  [0.00]
how do you guys clean the duster?
      10-31-2017, 11:41 AM   #12
David1
David1's Avatar
Drives: 09 E92 09 X5
You don't. I have a duster that is 20 years old with a wood handle that still does a good job. I just use that one for the lower portions of the car. Newer dusters that are broken in do the rest.
geogerf115.50
      11-04-2017, 01:27 PM   #13
lax01
Drives: 2017 M2
Using a California Duster to remove water spots? UM WHAT
It removes dust...light to no pressure. Won't scratch the car if you use as designed
ORIGIN M.3160.50
      11-04-2017, 01:58 PM   #14
SheWentToJared
SheWentToJared's Avatar
16
Drives: 2015 M3
just drive the car with dust on it if you don't have time for a proper two bucket wash. we spent way too much for this metal bruh
ORIGIN M.3160.50
      11-04-2017, 02:15 PM   #15
ORIGIN M.
3161
Drives: ///M
The original is entrenched with carnauba wax, that is why is easier on the paint than a dry mop quasi knock-off, and you use it correctly, and I assume on only a lightly dusty car.
      11-07-2017, 08:12 AM   #16
DETRoadster
Space Force - 4 Star General
DETRoadster's Avatar
11463
Drives: M2 MG 6MT / Moto Guzzi V7
I have used one for years without a problem but I follow a couple basic "rules."
1) As others have said, go light. Lay it down on the car, then raise the entire duster up about an inch so you are supporting all the weight of it and only allowing the fibers to drape down and contact the paint as you dust.
2) My rule for when to use it and when not to is this: First you start with a freshly washed and detailed car. Go drive and enjoy it. If you have not encountered any rain or moisture (like dew from parking outside overnight) then it's fine to use the duster to wipe off any dust. If you HAVE encountered any rain or moisture since your last wash, then DONT use the duster. It's time for a fresh wash.
      11-07-2017, 03:29 PM   #17
scadagawd
scadagawd's Avatar
47
Drives: BMW M2 2018
BMW M2 2018 LBB
BMW X1 2016 PSM
Audi S4 2014 SMG
