M2 Technical Topics > Track / Autocross / Dragstrip > 93/e30 Pump fuel
      09-20-2017, 07:00 PM   #1
DelGriffith
DelGriffith's Avatar
Drives: 2019 SO M2C
93/e30 Pump fuel
93 octane fuel is difficult to come by here in Kansas. I discovered this today at a station across town. I'm aware that this is lower octane gas mixed with E85 to bump the octane, but is it safe for our cars? I don't run a tune, and have a track day coming up soon. Searches seem to indicate that my injectors won't keep up without a tune or LPFP. Would really appreciate some input on the safety, and potential benefit of trying this really cheap "93 octane" gas. I'm expecting some solid reasons why I should steer clear....
'02 E39 M5-Gone
'07 E60 M5-Gone
'07 E64 M6 Cab-Gone
'17 F87 MG M2-Gone
'19 F87 SO M2C
      09-26-2017, 11:26 AM   #2
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Should be ok if you mix in 1-3 gallons, did that quite a bit in an E92 335 and F8x M3. Not sure if I'd do it without a tune though.
      07-10-2020, 02:35 AM   #3
whitesharkM2
M2 LCI WHITE
whitesharkM2's Avatar
Thailand
34
Drives: BMW M2 LCI 2018 AT
Ethanol 20% Can use with our car?
      07-10-2020, 09:05 AM   #4
Bee Pee
Bee Pee's Avatar
1777
Drives: AW M2 DCT
OP,
IIRC std tune/hardware should cope with ~ e20 content w/o issue.
From you photo, my read is that yr local pump gas goes from 87/e10 thru to 93/e30, such that gas is a low octane base product blended with added ethanol to bump up the octane. The higher the eXX blend, the higher the octane.
I'd run the 91/e20 initially as I think you might struggle with an e30 blend....
Here in the UK, we have SVP fuel [99RON (AKI 95.5-96.5) with e5]. I've add ethanol 1.5-2 imp gallons to a full tank to get a ~e20 blend to boost octane and the car works really well on BM3 OTS racegas & e30 tune as SVP (base product) here has higher octane and less ethanol content as the starting point.
HTH, BP
Current '22 X3M LCI..
      07-10-2020, 12:53 PM   #5
Insane_Dawe
Drives: 18 White ZCP M3
Anyone do this for track days? Add 1-2 gal of E85 to their tank for "safety"
      07-10-2020, 05:11 PM   #6
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
I will be running a 30+% mix of E85 and Pump 93 on my Stg3 BM3 M2C.
I Also have 1 step colder plugs..
Your engine will run a little cooler and of course its great insurance against the engine pulling timing, boost...
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
