08-07-2017, 07:47 AM | #1 |
Rep 3,681
Track rotors (OEM size)
Hey guys.
I'm thinking about grabbing a set of rotors just for the track. OEM size until I splurge for a BBK. Do you guys know what options are out there, and if they're worth it over buying an OEM set from Turner? Thanks. |
08-07-2017, 12:55 PM | #2 |
Rep 796
Check out the IND post. They have OEM sizing 2 piece rotors that will out perform the stock setup. As do other companies
08-07-2017, 01:39 PM | #3 |
Rep 3,681
08-07-2017, 01:40 PM | #4 |
Rep 162
Not trying to troll or anything, but what about the rotors available at IND make them "out perform" the stock rotors? I assume you're referring to the $4,100 Alcon kit.
Chris H. - In the sunny PNW!
My handy Speed-in-Gears calculator |
08-07-2017, 05:12 PM | #5 | |
Rep 796
No worries! I would say any rotor that fits in the stock caliper has room for improvement. It's not about the diameter so some manufactures will notch up their thickness a few Mm while utilizing better cooling fins. So overall I'd say the main advantages are 1: there's weight to be saved within the center aluminum floating section that accounts for a lot of performance 2: better cooling due to rotor thickness and airflow and lastly would be longevity and rotor face designs. Drilled rotors don't take as much abuse as slotted and don't last as long, drilled rotors no longer hold a cooling advantage. I'm not saying that the IND posted rotor does all of these things, but a stock diameter replacement can improve performance. |
08-08-2017, 04:57 PM | #6 |
Rep 295
My thoughts exactly. That's like $3k over OEM replacements. For maybe marginally better cooling and lower weight?
08-08-2017, 05:32 PM | #7 | |
Rep 3,681
I was mostly looking for the best way to not have to drive on the street with rotors beginning to howl or shudder from track use. |
08-08-2017, 11:25 PM | #8 | ||
Rep 295
08-09-2017, 08:49 AM | #9 |
Rep 351
These are fronts only, but Stoptech makes 2 piece rotors that should work well on track.
http://f80.bimmerpost.com/forums/sho....php?t=1246320 |
08-31-2017, 05:27 PM | #10 |
I INDIC8
611
Rep 1,282
Drives: 2018 LBB M2, 6MT
Place to talk to on this is Girodisc. I believe they already have a rotor that's the right diameter (front brakes are 370mm, right? TTRS is the same, so it's just a matter of thickness and hat geometry at that point)
Girodisc rotors are solid and the price is fair too - $1k for a set of fronts for the TT, although I've seen them cheaper in a group buy IIRC. When you kill the ring, you just replace the ring and reuse the hat, true two-piece.
09-04-2017, 02:13 PM | #11 |
Rep 2,171
switching rotors won't make much of a difference to brake performance on the track.. if you want better perf / cooling you need bigger brakes (front BBK) or at the very least track pads.
09-05-2017, 10:26 AM | #12 |
Rep 3,681
The thought was more about finding a similar priced aftermarket rotor as OEM that would last longer, before dropping the cash on a BBK. Seems like that rotor doesn't exist.
07-04-2018, 09:15 PM | #13 | |
Rep 295
Non OE rotor options https://f87.bimmerpost.com/forums/sh....php?t=1481772 |
07-05-2018, 04:11 AM | #14 |
587
Rep 898
The alcon kit seems quite nice.. The kit is expensive but the replacement rotor rings are dirt cheap.
You need to factor in total cost of ownership. With aggressive pads expect to go through rotors within a track season if not sooner.
